Old 05-11-2015, 07:35 AM   #121
Gwill65074
Gwill65074's Avatar
Default Re: 1932-34 Model B Four Cylinder Group started!
Where is the link to subscribe to the B forum?
Gwill65074 is offline   Reply With Quote
Old 05-11-2015, 08:21 AM   #122
jerseyboy
jerseyboy's Avatar
On the black bar above, click on community, then click on view all groups.
Look for the four banger group. ( Page 1, eleven down)
Keep 4-banging!
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
Old 05-11-2015, 11:21 AM   #123
larryf
How do I sign up for group?
larryf is offline   Reply With Quote
Old 05-11-2015, 11:29 AM   #124
hb32
hb32's Avatar
Have a dual Burns intake, a pair of Stromberg 81`s, a cast iron Mallory distributor and a Winfield yellow head to my B motor and will get the cam reground for a little more performance. Still have 4 broken studs to remove as well.
hb32 is offline   Reply With Quote
Old 05-11-2015, 11:57 AM   #125
Juggler
Juggler's Avatar
Hey HB - I've got more or less the same bits as you - waiting for the cash to get the bottom end built. Let us know how it goes!
Contact Jim Brierley on here for a cam, although I think the last SU1R he had in stock is now in the UK in a friend's speedster
Cheers
Juggs
Juggler is offline   Reply With Quote
Old 05-11-2015, 12:01 PM   #126
hb32
hb32's Avatar
Cheers
Juggs
Yeah the cash thing....
I have been in contact with Jim and that is exactly my intention to get my cam reground as well as Bubbas for a possible electronic conversion for the Mallory.
After lots of research and comments from the Barn and HAMB, going to leave the bottom end as is and see what happens.
Old 05-11-2015, 12:13 PM   #127
1932BB
Juggler,
contact me through P.M. for SUIR B cam.
1932BB is offline   Reply With Quote
Old 05-12-2015, 11:41 AM   #128
jerseyboy
jerseyboy's Avatar
larryf,
Click on the image for the Model B Four Cylinder group.
Towards the top of the page there will be a red band, on the right end of the band it will say join. Click on that and your in!
Keep 4-banging!
For gas somehow,
Old 05-12-2015, 11:45 AM   #129
jerseyboy
jerseyboy's Avatar
[QUOTE=hb32;1083763]Have a dual Burns intake, a pair of Stromberg 81`s, a cast iron Mallory distributor and a Winfield yellow head to my B motor and will get the cam reground for a little more performance. Still have 4 broken studs to remove as well.
hb32,
have you posted any of this on the group page? This is just the thread about the group.
Keep 4-banging!
For gas somehow,
Old 05-12-2015, 12:48 PM   #130
johnneilson
It has a fuel pump boss like a Mod B..........
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 06-25-2015, 01:45 PM   #131
hb32
hb32's Avatar
Managed to get the 4 broken studs out. No luck with the welder and ended up drilling them. Going to pull the motor shortly so I can assess the bottom end as well as to stuff some later gears in the transmission.
Also looking for an aluminum side cover.
Old 06-25-2015, 04:50 PM   #132
FrankWest
FrankWest's Avatar
Originally Posted by SteveB31 View Post
I have a question for the B engine experts.
When a B engine is installed in a 1932-34 Car, it has the exhaust manifold that has a 45 degree outlet at the back. That I know.
When installed in a truck, did they use a Model A exhaust manifold with the 90 degree bend at the back?
I have a 1933 model B ford with special heater exhaust manifold that point straight down like a model A manifold. So I guess different exhaust pipes can be custom fit to suit. In fact I have not heater in my car and want to install a standard exhaust manifold, and wonder what types of exhaust piper are available.
FrankWest is offline   Reply With Quote
Old 06-25-2015, 06:23 PM   #133
bobd
I have a 32 motor in my 30 pickup. I want to sign up but can't figure out how. Can you help me. I rebuilding the 32B carb and have some questions.
bobd is offline   Reply With Quote
Old 06-25-2015, 07:32 PM   #134
Synchro909
Synchro909's Avatar
I have a diamond B engine in my '28 Tudor and another ordinary B engine sitting in a garage for attention sometime. The one that is going is fully inserted and pressurised, 5.5 A head and a Stromberg down draft carburettor from the 1950's-60's from a Holden grey motor (GM's local car). It sits on an A manifold to which I have braised a fitting on top to take the carb. The motor doesn't go as well as I think it should but I have a B inlet manifold coming for it. I'm hoping the larger bore will help. Alternatively, I have fabricated a new manifold that would feed a much bigger motor.
My favourite engine is an A, fully inserted, Burlington crank and the same carb but on a B manifold, electronic ignition and B grind on the cam shaft. It goes much better than the B engine. I'm about to have counterweights made for an A crankshaft and do another engine with even more punch. Each counterweight will have an extra piece on the rod side to get the most I can out of it.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 06-26-2015, 02:29 AM   #135
fordlovr
fordlovr's Avatar
I saw this while on holiday in Australia recently, in the carpark at a classic/vintage race meet, looks like it may need a bit of work! or maybe no work at all.Each to their own.I like it.
fordlovr is offline   Reply With Quote
Old 06-26-2015, 07:33 PM   #136
Synchro909
Synchro909's Avatar
That's the way a car should look. No need to worry about keeping people's hands off it!
I think the owner of this one belongs to the Feral Sports Car Club. Google them and see what fun vintage motoring can be but be prepared to spend some time engrossed in their adventures.
Old 07-12-2015, 02:08 PM   #137
chopnchaneled
Just joined, Just bought a 31 a coupe with a b engine that will need going thur.
Have had a's that were street rodded and original ones, Been wanting to do a b for a long time.
Thanks for having me.
chopnchaneled is offline   Reply With Quote
Old 09-19-2015, 03:08 PM   #138
32forddump
32forddump's Avatar
I have a model BB dump truck with the B in it and I am about to install a model b with a 32 transmission in a model a roadster. I'm also adding a overdrive driveshaft as well. I need to figure it all out.
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/
32forddump is offline   Reply With Quote
