Closed Thread
Old 10-13-2011, 09:36 PM   #121
Modelakid31
Send a message via AIM to Modelakid31
Default Re: Model A/AA Ford Websites...Can YOU add to the list?"
By the way, Im located in Mass. when you get a chance you could add that next to my site.
Thanks Steve!
Modelakid31 is offline
Old 10-27-2011, 05:05 PM   #122
buyitsmart
buyitsmart's Avatar
Jerry's - The Model "A" Store
1215 Seminola Blvd., Suite 109
Casselberry, FL 32707
ph-877-350-0796 or 407-695-8911
Open Mon., Tue., Thur. and Fri. 9am-4:30pm EST
Jerry Isbell, Owner
One day shipping in Florida on "In-Stock" parts.
Wide selection, great advice...
buyitsmart is offline
Old 01-28-2012, 05:51 PM   #123
CarlG
CarlG's Avatar
Add eMail to Bill Barlow's listing:
BABBITT WORK
1. No known website: Bill Barlow (541) 389-2694 (Oregon)
[email protected]
CarlG is offline
Old 01-29-2012, 02:51 PM   #124
tomii
My own site, documenting my "restoration" project. FWIW...
http://modela.burke.tv
tomii is offline
Old 02-29-2012, 05:38 PM   #125
CarlG
CarlG's Avatar
Add eMail address: [email protected]
TRANSMISSIONS
2. No known website: Mitchell Manufacturing (800) 859-2088 (California)
CarlG is offline
Old 03-02-2012, 06:02 PM   #126
trulyvintage
trulyvintage's Avatar
Arrow Enclosed Ford Transport
Ford Powered
I tow my custom 28 ft. enclosed trailer with an F350
Covering all lower 48 states
Visit my website
Jim
trulyvintage is offline
Old 03-18-2012, 06:36 PM   #127
ronaldB1
Steve Plucker
March 18, 2012
ronaldB1 is offline
Old 03-18-2012, 06:38 PM   #128
ronaldB1
Steve Plucker
March 18, 2012
Dear Stevem,
Did you recv my
photo of my Dad's
28-31 Ford?
ronaldB1
ronaldB1 is offline
Old 04-10-2012, 05:39 PM   #129
ctlikon0712
ctlikon0712's Avatar
Per request, here are new part #'s equivalents that most parts stores and some Ford Dealers should be able to obtaine. Price is another matter... lol
This was from a post by Bruce Lancaster
Contact Set (HYPERLINK "http://www.napaonline.com/Search/Detail.aspx?A=ECHCS30_0221962666&An=599001+101930+ 50026+2026063"PointsHYPERLINK "http://www.napaonline.com/Search/Detail.aspx?A=ECHCS30_0221962666&An=599001+101930+ 50026+2026063")
Product Line: Echlin Ignition
Per Car Qty.: 1
Compare ECH CS30Price
Unit 19.99 Each
Voltage Regulator
Per Car Qty.: 1
Compare ECH CU1This part can only be purchased from your local NAPA .
Distributor Condenser
Per Car Qty.: 1
Compare ECH FA5
Price Unit 7.99 Each
Distributor Rotor
Per Car Qty.: 1
Compare ECH FA3
Price Unit 11.49 Each
Ignition Coil
Product Line: Mileage Plus Electrical
Per Car Qty.: 1
Compare MPE IC7SBPrice
Unit 18.29 Each
Ignition Coil
Per Car Qty.: 1
Compare ECH IC7
Price Unit 44.99 Each
Ignition Coil Mounting Bracket
Per Car Qty.: 1
Compare ECH ICB15
Price Unit 7.49 Each
Generator Brush
Per Car Qty.: 1
Compare ECH F403
Price Unit 2.49 Each
This is from NoSurf
Motorcraft DC-1 Condenser
Motorcraft DP104 Point Set
Points CS30 Echlin (original style)
Points CS751 Echlin (new Ford style)
Condenser FA5 Echlin
Rotor FA3 Echlin
This is from 30 Tudor
Electrical:
Rotor FA3 Echlin
Condenser-Mallory Dist MA3 Echlin
Starter Brushes F502 Echlin
Spark Plug 561 Champion (Wl6Y)
Spark Plug 3X Champion (avail on special order)
Coil (6 volt) IC9 Echlin
Coil (12 volt) IC14 Echlin (w/built in resistor)
Generator Cutout CU1 Echlin
Alternator (12 volt) 71273SE OCA (one wire, internal regulator)
Battery (6 Vo1t) 7200 Exide
Battery (8 Volt) 8201 Exide
Battery (12 Volt) 843578 Exide
LED Lights
Tail light - http://www.unitedpacificind.com/storage/file10.pdf
Marker lamps - http://vehiclelight.com/clli.html
Light bulbs - http://www.superbrightleds.com
Bulbs
Taillight Bulb (6 volt) 63 GE
Stoplight Bulb (6 volt) 1129 GE
Taillight Bulb (12 volt) 89 GE
Stoplight Bulb (12 volt) 1073 GE
Rev A to above:
Useful Electrical Parts info for Model A
Points: Echlin CS30 (original style)
Echlin CS751 (New Ford style)
Echlin DP104 (Modern Style with modifed Upper and Lower Plate)
Motorcraft DP104
Condenser: Echlin FA5
Echlin DC-1 (Modern style)
Echlin MA3 (Mallory Distributor)
Rotor: Echlin FA3
Coil: Echlin IC9 6V
Echlin IC14 12V
Spark Plugs: Champion 3X (Original Style available from parts Houses)
W14 Colder Plug than W16 and Autolite 3076
W16Y Later Champion
W18Y Hotter Champion if W16Y burns black
TT10 Motorcraft
Starter Brushes: Echlin F502
Generator Cut Out Echlin CU1
Fan Belt: Napa 5L430 43"
Napa 5L440 44"
Resistor for horn Ohmite RKS2RO when using 6V horn on 12V
Conversion kit for GM 10SI and 12SI altenators to 1 wire
Quick Start SE-590
Engine:
Overhaul Gasket Set FS800C Victor
Head Gasket Set HS800C Victor
Intake/Exhaust Gasket MS9800 Victor
Head Gasket 800C Victor
Valve (Intake & Exhaust) 211-1558 NAPA Engine
Valve Spring 212-1001 NAPA Engine
Valve Seat Insert (Int) 218-8535 NAPA Engine
Valve Seat Insert (Exh) 218-7535 NAPA Engine
Piston (Std) 224-2625 NAPA Engine (also avail. .080 over)
Piston Pin Bushing 223-3316 NAPA Engine
Cylinder Repair Sleeve 226-8024 NAPA Engine
Piston Ring Set (std) 506 Perfect Circle
K&N Air Filters: To fit Air Maze filter kits suppplied by Model A part's vendors: Part E-9257, Round Air Filter, Height: 5.5 in (140 mm), Inside Diameter: 2 in (51 mm), Outside Diameter: 3.5 in (89 mm)
See:httpHYPERLINK "http://www.knfilters.com/search/universal.aspx"://www.knfilters.com/search/universal.aspx
Drive Train:
Clutch Disk R604 Rayloc
Pressure Plate CA1524 Rayloc
Clutch Pilot Bearing 6203-2RSJ NAPA Bearing
Clutch Release Bearing N1087 NAPA Bearing
Clutch Alignment Tool 675-1626 Balkamp
Wheels:
Front Wheel Inner Bearing 15118 Timken
Front Wheel Inner Race 15250X Timken
Front Wheel Outer Bearing 9074 Timken
Front Wheel Outer Race 9196 Timken
Miscellaneous:
Gas Cap for 30-31 703-1020 Balkamp
Fan Belt 25-20426 NAPA Belts & Hoses (also try NAPA #5L430 or 5L440 which is 1" longer) Consider an industrial cog belt if you have a generator as it will fit around the smaller pully better - TR22425)
Fuel Filter Gasket 730-9510 Balkamp (for glass bowl 30-31)
Radiator Hose (1-3/4') 611 NAPA Belts & Hose
Radiator Hose- (2") 613 NAPA Belts & Hose
Spare Tire Lock 770-2441 Balkamp
Bearings (Courtesy of www.jmodlea.coffeecup.com):
PINION BEARINGS [799000Series]
Cone (2 used) Ford Number B4211 – Bearing Number 28156 [799085]
Pinion Double Cup Ford Number B4616 – Bearing Number 28314D, 28314XD [799086]
DIFFERENTIAL BEARINGS
Cone Ford Number B4221 – Bearing Number 28156 [799085]
Cup Ford Number B4616 – Bearing Number 28317 [799087]
MISC. BEARINGS {Ford Number}
GENERATOR SHAFT BEARING(FRONT) {A10093} - 6203 2RS
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline
Old 05-05-2012, 10:38 PM   #130
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
how about adding Uvira Inc. Aluminum plating of reflectors
Uvira, Inc.
310 Pleasant Valley Rd.
Merlin, OR 97532
Telephone: 1-541-956-6880
Fax: 1-541-476-9096
email: [email protected]
Mike V. Florida is offline
Old 05-10-2012, 08:58 PM   #131
Elcastor
Elcastor's Avatar
Hello Pluck,
Can you add the following for Plating - Silver
Chidgey & Sons
1099 W. Palm Ave.
El Cajon, Ca 92020
(619) 441-2505
They came highly recommended and their price was right. Thanks!
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline
Old 05-14-2012, 11:13 PM   #132
trainer800
We would love to insure that Model A/AA Ford - When you get a chance check out our website we specialize in Classic Cars http://mvragency.com/classic-antique-car-insurance.html
trainer800 is offline
Old 06-14-2012, 08:29 AM   #133
AL in NY
AL in NY's Avatar
Inserted Engine Rebuilder.........Boulden and Boulden, INC., 41 Main Street, Belfast, NY 14711 (585) 365-2493.........Bob Boulden
Modern Pistons for Model A..............Pete's Auto Machine,749 Coors Road, SW, Albuquerque, NM 87121 (505) 836-3110......John Coster
Electro-Plating/Anodizing/Powder Coating..........Mid-Hudson Platers. INC, 132 Smith Street, Poughkeepsie, NY 12601 (845) 471-5090.........John Seffield
AL in NY
AL in NY is offline
Old 08-01-2012, 01:49 PM   #134
mich455
www.jdmspecialty.com
the ceramic seal water pump they manufacturing for the last 10 years or so, is only available through their website only now
mich455 is offline
Old 08-26-2012, 10:13 PM   #135
duffer
duffer's Avatar
Just want to say thank you for all this really valuable information.
duffer is offline
Old 10-11-2012, 08:12 AM   #136
tomii
This is where I put all the work I'm doing on mine. This way I'll be able to remember how to put it back together. And maybe get tips from people who know what in the heck they're doing.
tomii is offline
Old 01-08-2013, 09:52 PM   #137
Fdohnke
Fdohnke's Avatar
Talking Re: Model A/AA Ford Websites...Can YOU add to the list?"
Just for the fun of it!
www.tresburrosgarage.com
Fred Dohnke
California
Fdohnke is offline
Old 01-17-2013, 09:24 AM   #138
boo
our local musium,ELLIOT MUSIUM, STUART FL. is opening this marck 3, was donated a huge AA/A colection 57 vehicles [donelly colection] mostly comercial vehicles. check out their web-site.
boo is offline
Old 02-17-2013, 05:07 AM   #139
pat in Santa Cruz
pat in Santa Cruz's Avatar
Superior Chrome Plating
1616 Pomona Ave., San Jose, CA 95110
408 947 7781
Chrome, Nickel, Copper plating, Polishing, Repair
http://www.superiorchromeplating.com/
pat in Santa Cruz is offline
Old 02-17-2013, 08:39 PM   #140
Cob
Administrator
Cob's Avatar
bttt
Cob is offline
Closed Thread
