Old 11-26-2013, 09:00 AM   #1261
41ford1
41ford1's Avatar
Default Re: What I Did on My Lunch Hour
The 2 component RTVs/urethanes that V8coopman mentioned are a good solution. These are commonly use in aircraft components that see high vibration. The key is to have clean parts and to de-gas the material before and after pouring. De-gassing removes any trapped air from mixing. If you go this way it is important that the parts are fixtured concentric and square. If the assembly is not done carefully you will have an out of balance condition.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 11-26-2013, 11:23 AM   #1262
Vic Piano
Vic Piano's Avatar
Chuck. that's one option I'm considering, I haven't really had time to take a good look at the fan hub assembly as yet, after the holiday I'll get back into the garage and take a closer look. Vic
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 11-26-2013, 06:16 PM   #1263
42merc
42merc's Avatar
The Lincoln fan assembly as described sounds like a '40 Ford fan assembly. When mine developed some looseness I removed the fan & drilled the hub & installed four 1/4" nuts & bolts to compress the hub/fan together.
I was concerned with the fan getting loose enough to get into the radiator. A couple of thousand miles later it still works fine.
42merc is offline   Reply With Quote
Old 11-27-2013, 10:14 AM   #1264
Vic Piano
Vic Piano's Avatar
I took some better photos of the '39 LZ fan hub assembly because a picture is worth a thousand words and these photos should clearly show the assembly. I'm still open for ideas or, if someone has a good '39 LZ fan hub assembly they would like to sell...
Old 11-27-2013, 12:49 PM   #1265
41ford1
41ford1's Avatar
It looks like the only thing holding the fan to the hub is the rubber section. If the fan came completely loose it may fall back into the belts. It doesn't look like it could go forward towards the radiator. You probably want to do a fix ASAP. GE and Dow make some good 2 par castable urethanes that will work for that. I'll dig up some specific info and get it to you.
Old 11-27-2013, 01:02 PM   #1266
Vic Piano
Vic Piano's Avatar
Thanks Chuck, I appreciate that. The fan can't go back because of the harmonic balancer; there is very little room for movement forward or backward. As far as I can tell, the rubber cushion is an additional vibration dampener and serves no other purpose.
Old 11-27-2013, 01:31 PM   #1267
B-O-B
B-O-B's Avatar
Seems like you could cut one out of a piece of heavy duty rubber & glue it in place. Aren't there bolts holding that together? If not I would add a few. From what I can visualize the flat washer shaped piece has a shoulder that fits into the fan hub. Am I correct? Then everything is sandwiched together. Just thinkin here & that is generally bad.
B-O-B is offline   Reply With Quote
Old 11-27-2013, 03:16 PM   #1268
Vic Piano
Vic Piano's Avatar
B-O-B, that's pretty much exactly what it is, the rubber is just to ease the vibrations, it doesn't do anything structural that I can see...
Old 11-29-2013, 12:39 PM   #1269
Vic Piano
Vic Piano's Avatar
Here's a photo of the newest member of the Cigar City Flatheads, my Grandson Evan.
Old 11-29-2013, 12:45 PM   #1270
Steves46
Steves46's Avatar
Hi Vic. Hope you and your family had a wonderful Thanksgiving. I see little Evan is showing the finger he has you wrapped around! I like his T-shirt. Steve
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 11-29-2013, 01:01 PM   #1271
B-O-B
B-O-B's Avatar
Baby sure is sweet looking must not take after granpapa!! heh heh he
Vic what is that red thing in the background looks a bit outa focus. Glad to see all survived turkey day.
Also check the post numbers for me. whoa
Old 11-29-2013, 01:22 PM   #1272
Lawson Cox
Lawson Cox's Avatar
Great looking kid. Almost as cute as my grandchildren. lol
Old 11-29-2013, 01:22 PM   #1273
Vic Piano
Vic Piano's Avatar
Steve, you got that one right!
B-O-B, That red thing is the '51 F-1. That number (666) is only bad if you believe in that sort of thing... LOL. Hope you guys had a good Thanksgiving.
Old 11-29-2013, 02:17 PM   #1274
49fordv8f4
49fordv8f4's Avatar
McMaster-Carr sells machinable urethane rubber in different durometer hardness that you might use to repair the hub.
Mark
That is a good looking grandson!
49fordv8f4 is offline   Reply With Quote
Old 11-29-2013, 08:18 PM   #1275
Vic Piano
Vic Piano's Avatar
Mark, thanks for both comments, I appreciate it. Vic
Old 11-29-2013, 09:54 PM   #1276
41ford1
41ford1's Avatar
It looks like Evan is grandpa Vic's number One Ford guy. He'll be twisting wrenches with Vic in no time.
Old 11-29-2013, 10:29 PM   #1277
VeryTangled
VeryTangled's Avatar
And eating Pizza? Nice lookin' kid Vic, Congrats to you and the wife!
-VT/JeffH
VeryTangled is offline   Reply With Quote
Old 11-30-2013, 07:45 AM   #1278
Vic Piano
Vic Piano's Avatar
Thanks Lawson, Chuck and Jeff, I sure have been having fun with Evan, hate to see him have to go back home to Atlanta tomorrow.
Old 11-30-2013, 08:22 AM   #1279
BILL WZOREK
BILL WZOREK's Avatar
Vic:
That's a bigger smile then when you are driving one of your Flatheads !!
BILL WZOREK is offline   Reply With Quote
Old 11-30-2013, 08:51 AM   #1280
Vic Piano
Vic Piano's Avatar
Bill, he's got me grinning…
