01-28-2013, 05:12 PM | #101 |
Re: Who Can Diagnose THIS Total Mystery? Win A Prize?
Long shot in the dark?
Have you tried eyeballing it in the dark? Possible shorting you cannot see in the light? You mentioned changing the high tension lead as "it was a little loose" Sometimes with a leaky boot, you can build up a carbon track on the tower of the coil or across the distributor cap. When conditions are right the energy goes to ground on the easiest path. This would give you a fairly good charge of unburnt fuel in the pipe and a neighbor waking backfire. Of course you've changed the coil out, but have you had a good look at the cap? Good luck in the hunt, I hope you find it soon! |
01-28-2013, 05:22 PM | #102 | |
Here are a few I don't remember if anything was done. Brent gave a step by step procedure for when if happens as did H. L. Chauvin. Do we know if this was followed? There were a couple of thoughts vapor lock. Was cool water poured on the Carb when it acts up? Was the ground to the engine checked? We can get this!!!
01-28-2013, 06:01 PM | #103 | |
How do you know your problem is the same thing thats happening in fl ? Maybe the same symptoms but possibly not the same failure. i suggested putting inline a simple spark tester to visually ck the intensity and pattern of it when it acts up. mike k suggested to use that carb float tool to see if the bowl is running low on fuel. these simple things can lead you to attack which system if any of the two are the trouble. If it was diagnosed properly which advice was given of how to do that in the above replies to determine which system is at fault ELECTRICAL / IGNITION / MECHANICAL or FUEL it could have been solved easily without replacing everything that has already been thrown at it. If that isn't parts changing what is and apparently whats been done in Washington was just that. anybody can replace parts and hope it's fixed but what service is that to the less knowledgeable who asks for help here. take your modern car to a repair facility would you want parts thrown at it till its fixed? that could become mighty expensive and these old A's can add up also. sorry if your upset but thats the way i see it. continue on shooting everyone down on all the things that have been thrown at it. and yes i can properly diagnose and repair this vehicle, determine which system is at fault without tossing parts on it, and then test the appropriate components. so continue on you have done a good job so far thats why this poor guy is in fl with a broken truck. Congrats you won the prize mitch//pa Last edited by Mitch//pa; 01-28-2013 at 09:27 PM. Reason: Typo |
01-28-2013, 06:04 PM | #104 | |
You guys here in the Barn have been terrific to offer your time and expertise to both Gary and me (not to mention so many others with problems tough-to-resolve). Thanks to each and every one of you for the support...and if anybody has an additional thought, please chime in. I'll let you know if/when we find a crab apple in the fuel tank <grin> or any other cause of this mind numbing mess. |
01-28-2013, 06:18 PM | #105 |
Maybe not a crab apple but what if it's as simple as crap gas. Tony S. had problems with his car running and draining the tank and refilling it solved the problem.
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 01-28-2013 at 10:30 PM. Reason: Spelling |
01-28-2013, 06:23 PM | #106 | |
www.whidbeymodelaclub.com |
01-28-2013, 06:24 PM | #107 | |
First, having checked the fuel tank, the filters, etc, including draining the tank and cleaning/replacing all filters, I do believe (as Ray Horton suggested back in Post #25) that it is NOT a fuel problem but something electrical and, as Ray and others suggest, most likely SOMETHING in my distributor. So, here's my plan: The easiest, first thing is to replace the entire distributor and cap with one known to be in perfect working shape. (Somebody here in the club must have one I can borrow.) I'll take the old one out, put the new one in and go for a long drive. If that solves the problem, I'll rebuild my own distributor with a new plate, new points, new wire, new condenser because ONE of those was the problem, right? If the replacement distributor doesn't resolve the problem, I will then also replace my new coil with another known-to-be-working and see if that ends my trouble. I'll also check the fuse plate because that's a very easy thing to look at and maybe even remove if there's any signs of trouble that some of you pointed out. And if THAT doesn't work? I'll push it over a cliff! No, wait, there ARE no cliffs in Florida. Okay, THEN I'll start with the great diagnostics suggested by Brent, H.L. and others, one by one. Reasonable? Other ideas? Last edited by sgwilson904; 01-28-2013 at 06:27 PM. Reason: Spelling |
01-28-2013, 06:42 PM | #108 |
Sounds Like valves sticking when hot.
01-28-2013, 06:49 PM | #109 |
"If that solves the problem, I'll rebuild my own distributor with a new plate, new points, new wire, new condenser because ONE of those was the problem, right?"
Well, I would look everything over very carefully and see what I can observe what might be the problem. There are several components in your list of new stuff, and if you spend that money (about $40) and replace everything you won't know which component that it was that was faulty. Is it a 5-cent washer that's shorting out on the upper plate or a $5 point block that's cracked? It's almost assuredly not every one of those items listed! Likewise, you can test your coil before spending $16-$20 for a new one. Use the scientific method and inspect and test one component at a time, then replace as your observations suggest. Reading this thread might also help: https://fordbarn.com/forum/showthread.php?t=95936
01-28-2013, 07:25 PM | #110 |
Just did a check of the valves and compression test today. This was done by a well known Model A Mechanic who is 80 years old and an expert at it. He could find nothing. Thanks for your Idea.
01-28-2013, 08:36 PM | #111 |
Auto Machine. St. Charles, IL.....630-584-1188
01-28-2013, 08:50 PM | #112 |
01-28-2013, 08:53 PM | #113 |
SGWilson, in your original thread you mentioned this "Pulling the choke rod out about two-thirds of the way (flooding it with gas) will cause it to sputter a little less and limp a little farther." This to me is an indicator that it is a fuel problem. Possibly vapor lock. Could you tell us how much longer it runs when you pull the choke rod out? Good Luck. Joe B.
01-28-2013, 09:44 PM | #114 | |
01-28-2013, 10:10 PM | #115 | |
It does sound like typical ethanol problems on warmer days. The condenser and coil are often heat related when they fail, but I think you changed both of them. |
01-28-2013, 10:14 PM | #116 |
Whats the PRIZE?
01-28-2013, 10:19 PM | #117 |
01-28-2013, 10:22 PM | #118 |
01-28-2013, 10:44 PM | #119 |
looks like a HEAVY CHEVIEEEE....LOL
01-28-2013, 11:07 PM | #120 |
plugged exhaust? Check heat riser??
