Old 03-23-2011, 03:36 PM   #101
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Not getting fire!! Won't start. PLEASE HELP FAST!!
Originally Posted by mickeyb View Post
is this car running yet
Tune in tomorrow for another episode of "AS THE CRANK TURNS"
Old 03-23-2011, 04:14 PM   #102
Mike V. Florida
Mike V. Florida's Avatar
yes and no, see message number 76.
Old 03-23-2011, 04:33 PM   #103
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Okay so far as NEED HELP QUICK...that went out the door 4 days ago...where are you at this point since i know you did not drive to your event?
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 03-23-2011, 06:48 PM   #104
Maclab58
Maclab58's Avatar
My gawd! what a saga!
Maclab58 is offline   Reply With Quote
Old 03-23-2011, 07:05 PM   #105
IrishHills
IrishHills's Avatar
He must have got it running and left town...
IrishHills is offline   Reply With Quote
Old 03-23-2011, 07:12 PM   #106
Louis
"As the Bowl Swirls ".
Louis is offline   Reply With Quote
Old 03-23-2011, 07:29 PM   #107
Roadster62
Roadster62's Avatar
Electrical threads are like a visit to the snake house at the zoo, can't stand either, but always look at them. Bet no two people will have the same answer to this question. If every wire was riped out of a Model A and the distributor was out and on the work bench, what are the steps in getting the car running?
Roadster62 is offline   Reply With Quote
Old 03-24-2011, 06:36 AM   #108
Mitch//pa
how long is this movie? "as the crank turns"
Old 03-24-2011, 07:45 AM   #109
zzlegend
zzlegend's Avatar
I am up early. Dont want to miss another episode. Drama, suspense, humor, excitement, this show has it all.
zzlegend is offline   Reply With Quote
Old 03-24-2011, 04:42 PM   #110
mickeyb
mickeyb's Avatar
Man has this been a trip.made me tired and im just reading
File Type: jpg 33604_1531776369062_1074352901_31278844_6557579_n.jpg (71.3 KB, 27 views)
mickeyb is offline   Reply With Quote
Old 03-24-2011, 04:55 PM   #111
John Butts in CT
John Butts in CT's Avatar
If you're really tired, there's another thread about sleeping an an "A."
John Butts in CT is offline   Reply With Quote
Old 03-24-2011, 07:23 PM   #112
crotex
I have the motor running. I disassembled the carb and cleaned every piece. I found that it had a bad float along with needle and seat. I went to my buddy's shop and some out of a carb he had. I got it running and driving good for a while but now it is giving me problems again. I think the float may be bad again.
crotex is offline   Reply With Quote
Old 03-24-2011, 07:34 PM   #113
Mitch
Sounds like it may be sediment in the gas fouling up the fuel supply and may have redeposited junk in the carb to put you back to the problem you had before. If a lot of rust, etc. is in the tank, a filter will plug and fuel flow will slow. If no filter, then you'll probably get the stuff in the carb.
Hope you best.
Mitch is offline   Reply With Quote
Old 03-24-2011, 08:00 PM   #114
John Butts in CT
I'm with Mitch.
There are lots of threads about dealing with gas tank crud; have a look.
Glad to hear you're making progress, crotex. Believe it or not, Fordbarners are very supportive. They just like feedback and updates from time to time.
Best regards.
Old 03-24-2011, 09:03 PM   #115
TinCup
TinCup's Avatar
So what was the fix for spark at the plugs? That's what started this parade.
TinCup is offline   Reply With Quote
Old 03-24-2011, 09:12 PM   #116
Mitch//pa
got lost in part 1 spark-- ill try to stay alert on part 2 fuel
Old 03-25-2011, 01:00 AM   #117
crotex
The rust sedimant is to a minimum now in the tank. I did not get to mess with the carb anymore today. I been busy redoing the floor in it instead. tomorrow I will take it off and check it out again.
Old 03-25-2011, 01:06 AM   #118
Mike V. Florida
So the electrical is all put back together? What was the final problem/solution?
Old 03-25-2011, 02:28 AM   #119
mickeyb
mickeyb's Avatar
now the floor but it's only wood
Old 03-25-2011, 10:49 AM   #120
msmaron
msmaron's Avatar
So maybe this post should now be edited and remove the "NEED HELP FAST" part...
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
