Old 06-04-2020, 02:31 PM   #101
Tom-MI
Tom-MI's Avatar
Default Re: Incorrectly mounted Spare Wheels on 1932-1935 Fords
Here is a picture of a 40 spoke Kelsey wheel mounted on a '35 coupe. The valve hole is not at the 12 0'clock position but isn't very far off.
Tom-MI is offline   Reply With Quote
Old 06-04-2020, 04:05 PM   #102
JimG
JimG's Avatar
That's where mine is. The position is defined by the mounting bracket. This position puts the drain hole right at the bottom of the wheel, as Mercman has pointed out.
JimG is offline   Reply With Quote
Old 06-04-2020, 05:07 PM   #103
mercman from oz
mercman from oz's Avatar
Thanks for the picture of your Kelsey Hayes Spare Wheel. Yes, the Valves are not exactly at the 12 o'clock position, but close to it. When the Valve is at the top, the Drain Hole is at the bottom. Hopefully, the message will get through. It does not cost anything to mount the Spare Wheel correctly with the Valve position at the top, so hopefully, other owners will check the position of their Valve location and correct it if necessary.
Old 06-04-2020, 08:27 PM   #104
rbone
Went out and looked at the spare on my '34 today. Guess I was lucky when I mounted the spare tire many years ago. The valve stem is exactly at the 12 o'clock position.
rbone is offline   Reply With Quote
Old 06-04-2020, 10:24 PM   #105
mercman from oz
Congratulations rbone, you got it right. I am glad that this Thread prompted you to look. Regards Mercman <><
Old 06-05-2020, 04:55 PM   #106
keith oh
keith oh's Avatar
I'll be damed, would have never thunk about the stem position.
keith oh is offline   Reply With Quote
Old 06-13-2020, 02:32 AM   #107
[email protected]
Model As also are supposed to have the spare installed with the valve on top or twelve o'clock position.
shadyside1983@gmail.com is offline   Reply With Quote
