#1 | |
Super Moderator
I always figured it was some "backyard hack" to install a replacement exhaust. You know... why do it right when it's so much easier to hack out a chunk of the brace?
#2 |
Go for it, one of my favorite cars. I did a repaint in Black laquer, some new glass 37 DeSota bumpers etc. Nice car, sold it for 600 bucks, Raising a family, added another mouth.
#3 |
Thanks for taking the time to do a thread. A lot of work is involved in putting one together. It is like writing a book, but with very short chapters.
1910 Model T Touring 1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
#4 |
Kube, Do you do all the restoration yourself? Example being for instance; the horns, generators and windings, rebuilding the clocks and parts like that? Where do you draw the line?
Once again, thanks for bringing us along. Mark
Thank Godthis is only a hobby! |
#5 | |
Super Moderator
I do most of the work. However, some things are simply out of my hands. Plating and most machining come to mind. I used to be able to do the engine machining when employed as a tool maker. Unfortunately, after I'd retired, I'd lost access to the necessary machines. Clocks you ask? More often than not, they simply need to be cleaned and lightly oiled. I do rebuild the horns myself as well as generators, starters, transmissions, differentials, etc. I now send my distributors, some fuel pumps and carburetors out to Charlie Schwendler. I used to do my own but find the minimal cost (of Charlie's work) along with the high quality, well, I just figure it is no longer worth my time / efforts to do them any longer. I don't mount my tires or cut my own glass.
#6 |
#7 | |
Super Moderator
Your words are too kind and undeserved. Thank you. I appreciate your comments. I'm blushing
#8 |
Looking forward to seeing what you do on your lunch hour.
#9 |
Mike,
A detour, but I wanted you to know that you are not alone. |
#10 |
Super Moderator
Wow! I'd like to think great minds think alike but there is only one great mind at work here - yours.
So, I'll chalk this up to coincidence. Very cool Dave. Thanks for sharing! What's your frame going to end up under?
#11 |
Nice ..wish I had more free Time & Garage space to work on mine..
#12 |
Mike, Nice work! those frames sure are a pain to sand all the little crevices to remove the pitting, as you know. Assembly seems to be the easy part on a Early Ford V-8, but the sanding, blocking and paint related tasks are where he work really is in my opinion.
On a side note, what brand primer do you use? Also what about paint? If you have never checked out Tamco Paint, I would recommend it highly as it seems to out surpass the PPG counterparts. I would bet most everything I own that that beautiful frame David posted a photo of was done with Tamco Products. Hat's off to you, and excellent work! |
#13 | |
Super Moderator
You are of course correct in regard to the task of sanding these frames. I could check my notes but off the top of my head, I'd say I have well over 100 hours in this frame to date. And to think this was a nice frame to begin with! I've been using ChromaBase primer and Nason Ful-Thane color for years upon years. Cost is reasonable and it has proven to last very well for years upon years. I doubt I'll change but appreciate your advice. This stuff has worked so well, for so very long... plus, I know just how to handle it.
#14 |
Mike,
Under these things, but there is a fundamental difference in that what you show is your handiwork and in my photos, the handiwork is that of a couple of long-time good friends who happen to be world-class painters and paint preparers. My role is researcher, parts finder, and final assembler where the devil in the details. Last edited by DavidG; 11-13-2019 at 09:31 PM. |
#15 |
Super Moderator
My gosh man! Good for you!
Ya know, you'd made a comment in an earlier post that "I am not alone". You are correct but beyond you and I, well, we might be alone ![]() I've had more than one person suggest that you and I are the only two remaining doing this type of (read OCD) work. Here's a photo of the inside of the cab on that '40 PU I'd recently completed. I ask you: How many guys (other than the two of us) that block out the interiors?
#16 | |
This is but one example of what I was talking about in Post #99. DD |
#17 | |
#18 |
Mike, as with anything when you find something that works, stick with it! Out of curiosity do you use Nason on the sheet metal as well?
I haven’t sprayed much DuPont products other than some chromabase (base coat) as it’s hard to find around here. I assume Nason is a DuPont product? Again excellent work in a world where most frames receive krylon from walmart! |
#19 | |
Super Moderator
The Nason is simply that - Nason. No affiliation with DuPont that I am aware of. I've been using DuPont Chromabase on the sheet metal for the last six cars or so. Typically four coats of color and three or four coats of clear. I figure on sanding off one coat of clear prior to buffing. I have learned to manage the ChromaBase fairly well and have grown comfortable with it.
#20 |
Mike,
Re. the '40 p.u.; super duper! |
