#101 |
Yeah, I was going to say the same thing....I had at least twice that amount come out of one side of the engine in my '34....
#102 |
This is only a small amount I scraped out of my block, I did it twice. Using compressed air to move the smaller stuff everything around the work area turned brown...
#103 |
#104 |
Yes, but no longer. See my previous post....
#105 |
OK, wanted to follow up with the results of my work. New head gaskets, added water, antifreeze, water wetter and Barrs copper block seal for that small crack. Also, re-torque after warm up twice. Temps get to 185-190. After running it on the freeway and I shut it off, it crept up to 200+ while not running, that seems strange....Now I'm going to install thermostats and see if they help/slow the fluid down even though I never ran them before. I appreciate ALL suggestions given. Thanks to all that took the time to read and respond. I will post the results soon but now I'm into my 46 woodie that overheats....That's a post for another time. It's always something......
#106 |
#107 |
#108 |
#109 |
Mike ,there was a recent thread about deposits in an engine that looked just like your water pump. The conclusion was that the combination of Water Wetter and NO Rosion caused the deposits. Apparently you can not mix some of these chemicals.
Glad you solved your problem. John |
#110 |
The rising temperature after shut down is perfectly normal.
#111 |
Does shake n bake get all the sand out of a block?
#112 | |
#113 |
I just had a flathead engine baked, shot peened and shaked. I dug around in the block and blew air through it and did not get any left over debris out of it. I'll flush with water to triple check before it goes on a radiator.
#114 |
Shake& Bake. Walt in Me did an engine for me and he had it cleaned up there somewhere. It looked great before he got into the rebuild. I was really pleased With what I saw. I would take any other engine to that place. and I should have gotten the name and phone. kerk
#115 | |
#116 |
Hey Kurt, I thought I was the only one in the world with a Zoo flush gun. they rule!
#117 |
I have my 36 radiator at toms right now. I hope he does a good job. I almost went to hoffmans down a couple of blocks. I still waiting to hear back, he's had it about a month.
