Old 08-21-2015, 02:10 PM   #81
alchemy
alchemy's Avatar
Default Re: 1932 Ford Chassis without the Reveal.
HB32 please take a nice clear pic of your K member and pedal set, and post it. Also a nice shot of the smooth frame sides.
I love early '32 parts and am always looking to learn more about them.
While you are taking pics, how about the driver's side of the firewall, the underside of the roof's visor, and the gauge panel and column drop?
alchemy is offline   Reply With Quote
Old 08-21-2015, 02:41 PM   #82
hb32
hb32's Avatar
Cab and running boards are still on but will do what I can. Pedal set is out getting ready to mod the brakes for hyd`s.
hb32 is offline   Reply With Quote
Old 12-06-2016, 04:02 AM   #83
OHV DeLuxe
Light duty pick-up barnfind in Norway, all the familiar cross members, no reveal.
OHV DeLuxe is offline   Reply With Quote
Old 12-06-2016, 08:58 AM   #84
deuce lover
deuce lover's Avatar
Arrow Re: 1932 Ford Chassis without the Reveal.
32 chassis and body parts on a farm where I am living in the south of France.No reveal on this frame.The pic of the firewall pad is of a 4dr sedan,not part of the one with the chassis.
File Type: jpg 32 Ford French chassis - no reveal.jpg (170.6 KB, 98 views)
deuce lover is offline   Reply With Quote
Old 12-06-2016, 09:14 AM   #85
rockfla
rockfla's Avatar
Deuce Lover & OHC Deluxe
Are you frames stamped where they were made i.e France, Germany. England?????
Old 12-06-2016, 10:06 AM   #86
deuce lover
The frame here in France has lots of surface rust.I couldn't even find numbers on the frame from the steering box forward.Only number visible is on the engine block.
Old 12-06-2016, 10:21 AM   #87
DavidG
DavidG's Avatar
At least some of the Ford Werke frames were stamped as shown below.
Consistent with Ford's conservation practices of the period, nothing useful was scrapped unless there were safety or reliability issues. So those early frames were used up on commercial vehicles like other parts that were obsolete for passenger car use such as the adjustable shock absorbers.
Old 12-06-2016, 10:35 AM   #88
Fordors
One thing is illustrated by these photos for sure- Never say never when it comes to our beloved old Fords.
OHV Deluxe's pictures show a larger rear window and different body lines so that must be a body built by an aftermarket firm, and in deuce lover's pictures I wonder if that is a roadster pickup cowl, or possibly a Commercial drive-away chassis? I think I see at least one regular Ford running board bracket but there are also two other brackets just outboard of the center crossmember. Interesting stuff, thanks for posting those.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 12-06-2016, 10:38 AM   #89
rockfla
rockfla's Avatar
@ Deuce Lover
Not sure what parts of the frame you have access too BUT if it helps each piece of the frame is stamped on ours (as in David's post above), front cross member, both frame rails, transmission cross member, rear cross member and all the bracing from the frame rails to the cross members!!!!
Old 12-06-2016, 11:32 AM   #90
Bulligen
Bulligen's Avatar
I had a Martens frame in the late 70s, It was 3 piece welded, it was pretty nice. At the time it was a great choice for a hot rod frame. I do remember at least one other place that was making replacement frames but with no reveal. They were pretty low cost. I don't know what the sense of that was, as the beauty of the frame is the contour of the reveal? I will bet that frame is one of those!
Bulligen is offline   Reply With Quote
Old 12-06-2016, 11:51 AM   #91
deuce lover
Originally Posted by rockfla View Post
@ Deuce Lover
I will have to ask the owner of the barn for the key and go look at that frame again.What is cool in that barn is a 1935 Delage 8 cyl Limousine.Its as big as a Pierce Arrow.Have to use flash lights as there is no power in that barn.He seems to think it is a commercial chassis.It has the early firewall and the 4cyl is the smaller one.Horsepower rating very different to USA models.This is the 12cv.The larger 4cyl was a 19cv.
Old 12-06-2016, 12:19 PM   #92
DavidG
DavidG's Avatar
If it has the little four than at least the engine was built in Dagenham. If memory serves me right, at that time Ford France was a subsidiary of Ford Motor Company Limited of the UK.
The cowl does not look to be of Ford origin given the lack of a bead on the lower edge.
I like the four-rod rear brakes which reflected the French requirement of the time of separate controls for the hand brake. The photo below is of an early V-8 chassis in a Parisian showroom which also sports the four-rod rear brakes.
Old 12-06-2016, 06:06 PM   #93
vulture
vulture's Avatar
The knowledge on here is amazing ..... I am always learning thank you
Wanted Roadster Pick up thank you COLOR]
vulture is offline   Reply With Quote
Old 12-06-2016, 06:11 PM   #94
hb32
hb32's Avatar
Good to see this thread brought up again as I was thinking myself and the original poster were the only ones.
Old 12-14-2016, 12:54 PM   #95
alchemy
alchemy's Avatar
That sure looks like a 33-34 rear crossmember in that frame. I wonder what's up with that?
Old 12-14-2016, 02:06 PM   #96
hb32
hb32's Avatar
Nice to see that you also have the hard to find commercial rad cap.
Old 12-14-2016, 02:17 PM   #97
hb32
hb32's Avatar
Just noticed that I neglected to post pics of mine.
Not great and nothing removed as in fenders or running boards.
Old 05-10-2025, 07:51 PM   #98
Wolfsong65
Howdy! My father was Mike Martens. He passed away in February of 2024. Here are pictures of the original article about his frame making with plenty of pictures. He is in front of the roadster he and my mother built and took to the 1972 Third Annual NSRA Nationals in Detroit. He won Best Fiberglass Rod with that car. At the time, his were the most authentic reproductions being made. He was the first one to make them, and sold them all over the country. I was very young at the time, but I remember that they were three pieces welded together to form them together, not press shaped. They definitely had a great profile. He also did some other custom frames, but the 32-34 frames were his bread and butter. He was also the furst lifetime member of the NSRA.
Wolfsong65 is offline   Reply With Quote
Old 05-10-2025, 07:56 PM   #99
Wolfsong65
Here are the pics
Old 05-11-2025, 06:03 PM   #100
325w
Had a chance buy a 30 coupe on one of theses frames. Passed because of no reveal
325w is offline   Reply With Quote
