Old 04-05-2025, 11:42 PM   #81
GB SISSON
GB SISSON's Avatar
Default Re: 9" rear in a jailbar truck
I got a chance today to start stripping parts off the axle assembly. I have watched a few youtube episodes about removing the old wheel bearings and their pressed on keepers. I wasn't sure I liked cutting deep slots through all these pieces without nicking the axle shaft so I went another route. I had an idea to cut a length of steel pipe, weld a 3/4" nut on the end and then weld a couple scraps of 1/8 x 3/4" strap to the other end to weld the keeper ring and crank a 3/4" bolt through the nut into the splined end of the axle shaft. 'Weld heat expands ring and I simply wrench the ring upwards'. Much to my dismay , every nut, bolt, pipe and washer I could find was galvanized. In a hurry, didn't remove enough zinc so had a weld fail. Once I repaired that, my 1/2" impact sheared off the drive bolt which I made from a piece of galvanized 3/4" all-thread that I shouldered down to accept a 1/2" lug nut plug welded on the end. I found a big square galvanized nut to weld on instead but was sick of grinding off the zinc. In the final analysis, the cut-off wheel seemed like a darned good idea and no nicks at all. Next remove all parts from the housing. I DID get some satisfaction from removing the oil seals with a heavy steel bar from a fireplace flue damper plate. It has a series of hook notches and made light work of it, neatly pulling each seal in three jerks.
Old 04-06-2025, 12:32 AM   #82
petehoovie
petehoovie's Avatar
Old 04-06-2025, 08:07 AM   #83
pistonbroke
Gary, I never cut all the way though. Just enough so I can split it with a a good chissel and hammer. The collers are much softer than the bearing. Tim
pistonbroke is offline   Reply With Quote
Old 04-06-2025, 11:03 AM   #84
GB SISSON
GB SISSON's Avatar
Yes Tim. I understand that from the video. And the collar was tougher to break off with the air chisel. The bearing races as expected, broke like glass. I cut at about a 45degree angle so as not to cut into the bearing retainer plate as I was using a standard (but worn down) 4" cutoff blade. In looking at my failed puller, I may have inadvertently created the world's fastest caulking gun, so all is not lost
Now the question segment: The brake tubes on this 1971 axle look smaller than on my '47 jailbar. Should I try to find a conversion size or adapter for the rubber hose and keep everything on the axles at 3/16" or whatever that is I'm looking at?
Old 04-06-2025, 12:21 PM   #85
cas3
If you are staying with the original MC, I would look for a wheel cylinder that same bore, that uses a 1/4" line. If going to a dual MC, then start plumbing the whole truck like a 71 ford, 3 1/6
Old 04-06-2025, 01:07 PM   #86
GB SISSON
GB SISSON's Avatar
Ok Skip, I'm leaning towards single master. All wheel cyls and lines are new along with the master. For added safety I have a remote resevoir I made from a gas engine drip oiler to mount on the firewall that never got installed. What about all the other aspects of this new 1/4" style of wheel cylinder? Bolt spacing, center indexing circle etc? Anyone here have a source or number for such a cylinder, or pair of cylinders?
Old 04-06-2025, 05:47 PM   #87
cas3
I think the hole and the bolt spacing is pretty generic on car size stuff. My 61 has 3/16 Lines, maybe earlier f100's, or f1's, not sure when Ford got away from 1/4" lines.
It may work fine as is with just the rubber line to the diff with 2 different size ends if there is such a thing. I'm not a brakeoligist, maybe some one else has some thoughts.
Old 04-06-2025, 07:04 PM   #88
GB SISSON
GB SISSON's Avatar
I'm not a proctologist, but I've been working on a rear end most of the day. Is there a brakeologist in the house? The little hole bored into the wheel cylinder at the inverted flare fitting is pretty goldang small, so that must limit flow to a point? When Henry switched from 1/4" lines to 3/16" he not only saved money on the lines themselves, but fittings and a half ounce of brake fluid too. If I was a hick I'd just get a double barb fitting and use half of each hose. Double hose clamps on each barb (for safety) of course.
Old 04-06-2025, 09:25 PM   #89
Scotty's 52 F3
Scotty's 52 F3's Avatar
Gary, my F3 has 1/4" brake lines and the 72 F250 Dana 60 has 3/16 lines to the wheel cylinders. I kept it that way by modifying my Tee fitting and using two adapters. Been working trouble free for many years and yes it stops well.
Here's the stock hose and block. The long nipple is from the 1972 F250. That hose was cut off by the PO and wouldn't have worked anyway. I had to drill out the block so the nipple would fit. It originally had a hose going up under the bed for a vent. The small breather is the original from the Timken rear.
https://cimg8.ibsrv.net/gimg/www.for...bd343ba6b5.jpg
Scotty's 52 F3 is offline   Reply With Quote
Old 04-06-2025, 09:27 PM   #90
Scotty's 52 F3
Sorry, I was not able to copy and paste from my post over on FTE. It lets me include a link to the pic though.
Block drilled out. Adapters are Edelman #258340.
https://cimg9.ibsrv.net/gimg/www.for...a9064a5716.jpg
Old 04-06-2025, 09:29 PM   #91
Scotty's 52 F3
I cut the nipple down, drilled and tapped it to 1/8" NPT so I could put the stock breather in. I really don't want to run a hose up under the bed. Washer is a crush washer to seal the bolt.
https://cimg2.ibsrv.net/gimg/www.for...0759929f4e.jpg
Old 04-06-2025, 09:30 PM   #92
Scotty's 52 F3
I'm happy with this. Everything is stock 52 F3 up to the block. The rest is 72 F250. Done!
https://cimg3.ibsrv.net/gimg/www.for...ef5a8c145b.jpg
Old 04-06-2025, 10:37 PM   #93
petehoovie
petehoovie's Avatar
Old 04-06-2025, 11:33 PM   #94
GB SISSON
GB SISSON's Avatar
Wow! Lots of great info and I'll give it a go. Is the end of our 1/4" hose a tapered pipe thread into the block? IIRC the '71 block is factory swedged to the brass block. So I cut it flush, bore and tap? I see no problem with a vent hose under the bed, so I'll save a step, and Pete, I still think your enlargements are either more clear or larger than clicking onto the FTE small photo.
I have the housing in primer now. Stripping brakes next, but those darn contractors are in a dither now with summerfolk soon to be coming in droves. This coming week is shot, but my best vehicle repair bay is taken up anyhow with an ongoing restoration of a maritime artifact for a client.
Old 04-06-2025, 11:40 PM   #95
cas3
Scotty has good info, better than hose clamps where you may have to rebuild the chicken coop again
Old 04-07-2025, 12:16 AM   #96
GB SISSON
GB SISSON's Avatar
Ya just won't let that one go
https://www.youtube.com/shorts/6unhaM7Seww
Old 04-07-2025, 12:31 AM   #97
Scotty's 52 F3
Gary, I think that was my original 52 F3 block and I just screwed a new hose in it. It was already tapped.
Edit; I went back and found pics of that block on my original Timken axle. It had a bolt through the hole I drilled out for the vent fitting.
Old 04-15-2025, 04:48 PM   #98
GB SISSON
GB SISSON's Avatar
After 3 days of running around and trying to reason with fedex chatbots about how 517 Picketts lane is on an island etc...I came across a fedex stepvan pulling out of a gravel driveway and cut them off. The driver and I exchanged some info and I told her it arrived just across the sound on Friday... Then I described a plywood crate yay by yay 98 lbs. And she said 'wait a minute' and there it was ! She folloed me up the half mile of steepness and she grabbed the hand holds and carried it over and set it on the slab. I was on my way home with brak-kleen and other stuff to redo the backing plates, YAY! Got me a punkin', Thanks Lanny
Old 04-15-2025, 05:18 PM   #99
tubman
tubman's Avatar
Looks like your box made it through with flying colors!
Old 04-15-2025, 05:35 PM   #100
L-head
If you really want to wander out in left field, considering the amount of 3/4 and 1T axles assemblies you own, why not consider building a "quick change." Use 2 left side original cast iron side bells and a Frankland center section. Your gear choices would be unlimited. Hard to beat the look of a qc under a truck or car.
L-head is offline   Reply With Quote
