Old 03-22-2022, 05:16 PM   #81
aussiesteve
Default Re: Burned '32 PU came to new home today
Originally Posted by deuce lover View Post
I take that back.I now remember seeing a'32 deluxe panel with stainless cowl lights back in the mid 1970's.It also had the engine turned instrument panel.It belonged to Neal East.
Neal still owns it
aussiesteve is offline   Reply With Quote
Old 03-29-2022, 10:29 PM   #82
al's28/33
al's28/33's Avatar
Newc, does your foot pedal spoon arm have the ball link for a hand operated throttle control too ? I have been curious to locate clear photos of the linkage from the floor pedal up along the inside of the firewall to connect to the hand lever behind the dash panel. I know you have a 4-cylinder but I have also seen another '32 V8 with this same linkage. My '33 does not have that part, but my truck was converted from a 4 banger to a V8 long before I got it and the guy butchered up my linkage. Now I am trying to discover what set-up I can attempt to recreate. THANKS.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 03-30-2022, 05:45 AM   #83
DavidG
DavidG's Avatar
The presence of the ball on the side of the pedal shaft for the linkage rod to the bell crank attached to the foot of the instrument panel is unique to LHD '32s (first photo below) and absent on '33-'34 accelerator pedals (shown below in the second photo).
Old 03-30-2022, 11:46 AM   #84
DavidG
DavidG's Avatar
Alan,
In addition to the accelerator pedal differences between '32 and '33-'34, it gets a bit more complicated in '33-'34 where the differences between fours and V8s extend beyond just the accelerator cross shaft on the engine compartment side of the firewall.
The controls for the choke and throttle functions on '33-'34s equipped with four-cylinder engines are not rods directly or indirectly originating at the instrument panel or dash, unlike those for V8s, but rather are flexible cables or wires within outer spiral-wound steel conduits. Accordingly, they are attached to the dash or instrument panel in a fixed manner, as with the '32 controls, using a chrome or nickel-plated escutcheon held in place on the back of the panel with a lock washer and large hex nut. (As compared to the rubber grommets that the '33-'34 passenger car V8 control rods pass through.)
The '32-'34 four-cylinder choke cables are pretty well known as to their construction with there being only a difference in the length of the three versions (B, BB, and 46 prefixes, 34 1/4", 32 3/4", and 39 3/4", respectively.
The '33-'34 four-cylinder throttle cables are of the same construction as the early B '32 starter switch control cable and various '32-'34 RHD control cables, namely a single wire inside a spiral-wound steel conduit.
There is an extra arm on the cross shafts that pivots. The end of the wire core of the throttle control attaches to the outer end of the arm. Pulling out the throttle knob causes the wire to pull that arm toward the firewall and pushing in the knob releases the arm with the return spring on the cross shaft returning the shaft to its starting point. The '33-'34 passenger car four-cylinder throttle cross shaft is illustrated in the photo below. (The throttle control wire from the dash is not present, nor is the cover over the opening in the firewall between the accelerator pedal and the cross shaft.)
Ford carried over the knobs from '32 (except for adopting black colored knobs for commercial vehicles) for both fours and V8s for the '33s and only changing the shape of the knobs for the '34 V8 passenger cars, not for vehicles equipped with four-cylinder engines, which continued to have the carryover '32 knobs.
Old 03-30-2022, 01:17 PM   #85
Newc
Newc's Avatar
I have found that the V8 Ford Club books are invaluable for any work- Also 3rd Gen for correct parts. Newc
Old 03-30-2022, 02:53 PM   #86
al's28/33
al's28/33's Avatar
David, thank you for posting these pictures and your explanations. Your first picture in post #83 above shows that extra linkage from the pedal arm going up behind the dash .... can you provide another picture showing how that link connects to the pull out knob ??
Old 03-30-2022, 03:32 PM   #87
DavidG
DavidG's Avatar
Will do next week; I'll be on the road in the interim.
Old 03-30-2022, 09:26 PM   #88
Newc
Newc's Avatar
Next week--The painted Cab comes back!! Trouble getting the front fenders done- shops are tooo busy. I should have scheduled them earlier. Newc
Old 04-15-2022, 04:45 PM   #89
Newc
Newc's Avatar
Well; Got the cab back from the painter and installed on frame. Lots of work ahead-Goal NW Nationals in July. Never a burnt car again! enjoy! Used a 'Gantry' fellows! Real job with steering and bed in place- had to disconnect steering box! Action photos wrong pixils for upload!. Newc
Old 04-16-2022, 04:00 AM   #90
Mart
Mart's Avatar
Looking great, Newc.
Old 04-16-2022, 11:26 AM   #91
petehoovie
petehoovie's Avatar
Old 04-16-2022, 12:30 PM   #92
Krylon32
Your truck is looking great. I have built 4 32 pickups but I have a short memory as I could never fit in them very good. I need to be about 4 inches shorter and 50 lbs. lighter. That being said I am considering buying another that is done.
Krylon32 is offline   Reply With Quote
Old 04-16-2022, 07:00 PM   #93
rich b
rich b's Avatar
Looks like the truck is really coming together. Great job so far.
rich b is offline   Reply With Quote
Old 05-16-2022, 08:33 PM   #94
Newc
Newc's Avatar
In a time race now. NW nationals or bust--July 11th. More photos wiring 12volt stuff -turn signals headlights ect. Wind lace is in, rear window correct screws . remember touring class almost concoures, but 12 volt. Wheels are 17". Gotta do the fenders myself-Painters !@#*& Newc
Old 05-16-2022, 10:11 PM   #95
GB SISSON
GB SISSON's Avatar
Really been enjoying this NewC, and I love the color. You pulled that thing outa the fire!
Old 05-17-2022, 06:21 AM   #96
mfirth
Love it, you're doing a GR8 thing here.
mfirth is offline   Reply With Quote
Old 05-17-2022, 09:02 AM   #97
TJ
TJ's Avatar
Can't wait to see it at the Wenatchee meet.
Old 05-17-2022, 09:09 PM   #98
al's28/33
al's28/33's Avatar
Superb !!!!!! Excellent work.
Old 05-17-2022, 11:43 PM   #99
deuce lover
deuce lover's Avatar
Is that wrinkle finish look inside the cab going to remain ?
deuce lover is offline   Reply With Quote
Old 05-18-2022, 05:58 PM   #100
Newc
Newc's Avatar
The inside finish is the under coating sprayed all over the cab interior. Painter just sprayed over it. Original??? I don't know. Newc
