Old 05-04-2012, 06:38 AM   #81
BrendonSC
Default Re: 1935-1941 Ford Pickup Parts
Sent you a pm about some stuff.
BrendonSC is offline   Reply With Quote
Old 07-21-2012, 03:31 PM   #82
jsteck
Originally Posted by Aircooled1 View Post
I have early 1935 through 1941 Ford 1/2 ton pickup parts available,from frames cabs fenders & beds to hoods grills & doors,banjo rear axles & transverse spring front axles to 16" wheels & early hydraulic brakes,flathead V8 motors & parts to top loader transmissions & parts,ask and I may possibly have the part you are looking for, EMAIL FOR PICTURES, located 125 miles North of Sacramento on Highway 99, email [email protected] or call 530-384-1651
Hi Aircooled,
I need the following for a 1935 pickup:
1. spare tire mount bracketry
2. metal trim moulding that goes on cab at windshield sides, these are each about a foot long or so.
3. either 3.25 or 3.54 ring and pinion set for stock rear end. must be very good condition, no whiners.
jsteck is offline   Reply With Quote
Old 07-26-2012, 01:27 PM   #83
gkgeiger
gkgeiger's Avatar
I'm looking for a nice pair of wide fives in the 5" width. PM if you have. Thanks,
Gene
gkgeiger is offline   Reply With Quote
Old 07-30-2012, 08:34 AM   #84
voblackwood
I need a complete glove box door and hinge for 36/36 pickup
Vernon Blackwood
281-923-5000
voblackwood is offline   Reply With Quote
Old 08-18-2012, 05:29 PM   #85
41-steel-
Hi, after a 40-41 pickup hood and grill if you could help with either, don't matter about condition...reply to [email protected] thanks
41-steel- is offline   Reply With Quote
Old 08-24-2012, 12:27 AM   #86
smellycrak
smellycrak's Avatar
Hi There
Would you have any door hinges I need 2 left hand side and 2 right hand side, if so how much and would you USPS them to Brisbane Australia?
many thanks kenny
smellycrak is offline   Reply With Quote
Old 08-27-2012, 07:22 PM   #87
smellycrak
smellycrak's Avatar
hi there
how much do you want for full set of 36 pickup hinges?
and will you post them to brisbane australia?
thanks kenny
Old 08-28-2012, 05:47 PM   #88
racer2378
do you have a set of 35-36 ford front fenders? any condition. thanks
racer2378 is offline   Reply With Quote
Old 08-29-2012, 07:03 PM   #89
Ray Balukas
Ray Balukas's Avatar
need a 37 pu right inner front fender well
Ray Balukas is offline   Reply With Quote
Old 09-15-2012, 11:34 PM   #90
hoss50
hey Aircooled, I need a pair of steel front fenders & also a pair of steel rear fenders & steel running boards for 35-36 Ford pickup. Have any good ones ? If so, how many pair? My email is [email protected] thanks!
hoss50 is offline   Reply With Quote
Old 09-18-2012, 11:28 AM   #91
the cooch
the cooch's Avatar
Hi! The '36 pickup seems to have a small panel between the rear fender-bed-running boards. I assume these are usually lost or damaged on old trucks but if you have some that are really rough they will work great on the "as is" driver. Thanks and way to go, keepin' the pickups rolling! P.S. I'm also interested in a specific flathead block from early pickups to rebuild. Thanks!
the cooch is offline   Reply With Quote
Old 09-24-2012, 08:36 PM   #92
DetroitMotion
Any leads on 38-39 one-ton fenders or running boards?
DetroitMotion is offline   Reply With Quote
Old 10-04-2012, 10:58 AM   #93
dfran12146
looking for 41 pickup frame....
dfran12146 is offline   Reply With Quote
Old 11-09-2012, 09:40 AM   #94
70cougar
How about a 37 windshield frame ?
70cougar is offline   Reply With Quote
Old 11-15-2012, 12:31 AM   #95
randeyc
In need of the upper and lower radiator splash pan. Let me know if you have one.
randeyc is offline   Reply With Quote
Old 11-15-2012, 12:33 AM   #96
randeyc
In need of the upper and lower radiator splash pan. Let me know if you have one. Forgot to add for a 37 pickup
Old 11-25-2012, 08:13 AM   #97
Roadster5040
Roadster5040's Avatar
Looking for 35-36 pickup truck column drop complete with key 713-826-2582 Tim
Roadster5040 is offline   Reply With Quote
Old 12-01-2012, 06:39 PM   #98
KARNUTS
I have a rare 41 ford pickup radiator from the n series flat head 4 cylinder if your interested or have people looking for one
Jeff
[email protected]
KARNUTS is offline   Reply With Quote
Old 12-11-2012, 09:17 PM   #99
borcutt
sent you an email about a grille.
borcutt is offline   Reply With Quote
Old 12-25-2012, 11:06 AM   #100
russtford
Need front fenders for 35 pickup. Also grill, any front sheet metal.
russtford is offline   Reply With Quote
