Old 12-28-2017, 10:15 PM   #81
KULTULZ
KULTULZ's Avatar
Angry Re: Two-Door Ford and Mercury Wagons
Originally Posted by scicala View Post
So I'm assuming a 1960 Courier is the same as a Ranch Wagon minus the 2nd row seat.
Sal
Your question shot completely over my head ...
As best as I can determine (using period ads and the MPC), both vehicles had the folding 2nd rear seat assy.
It seems to me (IMO) that it would have made the vehicle build cost for FORD more with a special delete design and resulting less usefulness of the vehicle.
File Type: jpg 1960-61 FORD- Rear Seat - BODY TYPE 59 - 71 (6 PASS).jpg (91.5 KB, 456 views)
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 12-29-2017, 02:11 PM   #82
scicala
scicala's Avatar
Default Re: Two-Door Ford and Mercury Wagons
So it sounds like the only difference between a Courier and Ranch Wagon in 1960 was the model emblem on the quarter panel. Not doubting it at all, but sounds strange and redundant.
Sal
Old 12-29-2017, 03:21 PM   #83
KULTULZ
KULTULZ's Avatar
Post Re: Two-Door Ford and Mercury Wagons
Sal
I would imagine the Interior Trim Level/Option List was different and the suspension ratings.
You may find this interesting also-
1959 Tudor Ranch Wagon (59C)
1959 Tudor Ranch Wagon "Country Sedan" (59D)
1959 Tudor Ranch Wagon "Courier" (59E)
Old 12-29-2017, 09:43 PM   #84
scicala
scicala's Avatar
KULTLZ,
Thank you for the '59 model numbers.
When I looked closely at the picture of the blue '60 Courier that you posted in post #80, I could see there didn't appear to be a 2nd row seat, and also it appeared the front seat was only on the driver's side. I realize these are actuall artist drawings and not photos, but still usually accurate.
Sal
Old 12-30-2017, 01:19 AM   #85
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Two-Door Ford and Mercury Wagons
KULTLZ,
Sal
You have a good eye for detail. I guess that is why you are a carb specialist...
I went back into the period MPC and the 1960 FORD Courier (59E - only) shows two separate seats as opposed to the regular one piece tilt forward back bench seat.
I would a$$-u-me that the passenger side folds down. Not sure as that detail is not mentioned. Maybe a Shop, Owners and/or Assembly Manual of that year would give more detail.
See Ill below.
File Type: jpg 1960 FORD- Front Seat - Body Type 59E.jpg (80.5 KB, 457 views)
Old 12-30-2017, 01:50 AM   #86
KULTULZ
KULTULZ's Avatar
Exclamation Re: Two-Door Ford and Mercury Wagons
- http://www.dailyturismo.com/2017/06/...d-courier.html
According to the seller "this wagon was call a courier for it came with no back seat and hard to fine." The Courier was a Sedan Delivery version that skipped back seats and instead gave you more room to haul your junk.
I may find myself corrected (again).
The folding rear seat MPC Ill only refers to Body Type 59. It does not actually infer either 59C and/or 59E.
I need a 60 Shop Manual...
Old 12-30-2017, 01:51 AM   #87
mercman from oz
mercman from oz's Avatar
Here is an enlarged picture from the Ford Car Parts Manual Posted by KULTULZ. At the bottom, you will see the Body Code Number 59E, which is the Code Number for the 1960 Ford Courier (Sedan Delivery).
Old 12-30-2017, 01:54 AM   #88
mercman from oz
From this Chart, you will see that the 1960 Ford Courier is actually referred to as a 2 dr Commercial Ranch Wagon, Body Code 59E. The regular 2 dr Ranch Wagon is Body Code 59C. All very interesting.
Old 12-30-2017, 02:28 AM   #89
KULTULZ
KULTULZ's Avatar
The 59C and 59E Body Codes applied to both the 1960 and the 1961 FORD 2DR Wagons.
Old 12-30-2017, 02:52 AM   #90
mercman from oz
I know that Ford produced a Ford Falcon Sedan Delivery in 1961. Did they also produce a "full-size" 1961 Ford Courier? The attached picture is too small to enlarge.
Old 12-30-2017, 02:54 AM   #91
mercman from oz
Here is a larger picture of the 1961 Ford Falcon Sedan Delivery from the Sales brochure. It is not the best quality as it started out as a small picture.
Old 12-30-2017, 03:23 AM   #92
KULTULZ
KULTULZ's Avatar
Smile Re: Two-Door Ford and Mercury Wagons
Yes. It was the continuation of the 1960 Courier. Both with side glass.
The Ill does not show the badging (RANCH WAGON - COURIER) well, so I cropped it below.
The badging was moved to the rear gate for 1961.
I had a good photo but cannot find it...
EDIT-
FOUND IT!
Just a side shot and not identified as either a RANCH WAGON or COURIER, but they both looked the same...
File Type: jpg 1961 FORD- BODY TYPE 59 _2 - Badging.jpg (44.2 KB, 8 views)
Last edited by KULTULZ; 12-30-2017 at 01:06 PM. Reason: USUAL CRS - POOR SPELLING SKILLS- ADD LOST PHOTO
Old 12-30-2017, 12:21 PM   #93
scicala
scicala's Avatar
Thank you KULTULZ and Mercman.
You have cleared things up enough to satisfy me. Great info.
Sal
Old 12-30-2017, 01:12 PM   #94
KULTULZ
KULTULZ's Avatar
Wink Re: Two-Door Ford and Mercury Wagons
Now, you want to start a new controversy?
What is wrong with this picture(s) (supposedly a dedicated restoration)-
Old 12-30-2017, 02:09 PM   #95
parklane
parklane's Avatar
Maybe that as a sedan delivery, it should be the cheap model, rather than the Fairlane trim??
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 12-30-2017, 03:27 PM   #96
dmsfrr
dmsfrr's Avatar
The front bumper over-rider is from a Mercury?
Aftermarket spotlights, chrome wire wheels & rocker panel trim...
dmsfrr is offline   Reply With Quote
Old 12-30-2017, 04:24 PM   #97
KULTULZ
KULTULZ's Avatar
You are sharp! You stole my thunder...
Actually, it is the 57 Ranch Wagon Del Rio trim level.
Old 12-30-2017, 04:31 PM   #98
KULTULZ
KULTULZ's Avatar
Actually, that is an optional grille guard.
I think the spot lamps/mirrors were again optional/accessory. The wires are later BIRD K-H and the rocker panel kit was optional and also available in a kit.
You guys are killing me.
BTW- I have a perfect NOS left hockey stick fender extension if anyone needs a service replacement.
_________________________________
1957-1958 FORD - B7A 7010175-A
Old 12-30-2017, 04:56 PM   #99
mercman from oz
My thoughts are that the Front Bumper is correct, with a Genuine Ford Accessory piece above the Bumper Guards, however, I have never seen the side chrome on the bumper on 57 Fords. Also, it has Custom 300 side trim with the added Gold between the two chrome strips. The Brochure for the Ranchero that I checked doesn't list the 300 trim, just the base Custom trim? Maybe, the 300 trim was available on later models? These are my thoughts on this Sedan Delivery.
Old 12-30-2017, 05:45 PM   #100
KULTULZ
KULTULZ's Avatar
Question Re: Two-Door Ford and Mercury Wagons
Side chrome on bumper?
The TRIM is taken from the 57 2DR RANCH WAGON DEL RIO.
The 2nd image below shows how the base RANCH WAGON and SEDAN DELIVERY came through.
The actual car is described here- https://silodrome.com/ford-courier-sedan-delivery/
File Type: jpg 1957 FORD Ranch Wagon 'Del Rio' _8 - 59B TuTone.jpg (42.2 KB, 31 views)
