#81 |
Ok....got the wishbone ball to pop down. The rubber ball is whole so I don't see a problem. Re-installed everything and put cotter pins in.
#82 | |
When you finish this job and test, let us know it you solved your original problem. Worth mentioning again: Check steering box attachment for TIGHT and adjustment ! Check pitman arm for THGHT ! |
#83 |
Went to a cruise-in today that was about 25 miles away. We drove on the highway and plenty of side roads with bumps, patches, and a few holes and no wobble. Of course this means nothing as I could have gotten lucky today. Only time will tell.
#84 |
The ball being loose sure could have been a contributor.
#85 |
Don't you have a couple of CASTELLATED nuts? DD
#86 |
#87 |
Pitman arm feels tight. Not sure what steering box I have or where to adjust it.
#88 |
Pic 2
#89 |
Pic 3
