Old 08-11-2014, 04:55 PM   #1
Bruce in southern OH
Bruce in southern OH's Avatar
Default Re: Yes, they are still out there NUMBER 2
Ken/everyone the speedometer cable runs from the passenger side rear housing, along frame rail, out in fender well for about a foot and into the inside of car and is connected to the back of big speedometer. I thought I saw the cable going to the drive shaft, but it was the emergency brake cable going in that direction. Now what would be missing from the Columbia system? The dash going to floor and transmission pans were removed when I got car. ( parts are with the car ) Several wires and small metal clad cables/wires disconnected on back of speedometer, what would these have gone to??? I did remove the front drum grease seals this evening, will order front and rear drum seals tomorrow, bearings do say Ford B-1201 and seem to be in very good condition, I will repack them and continue to work on brakes.
cable from Columbia rear housing
Ken, is this the front body mount you spoke of????
Bruce in southern OH is offline   Reply With Quote
Old 08-11-2014, 09:14 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Bruce, When you say metal clad cables there is a heater cable that is attached to the pass side of the console,post some pics of whats there.. The speedometer cable being from the axle housing tells me its probably factory installed,there is nothing missing if you have the shifter valve on the steering box with the cable that goes inside to the dash. Here is some pics of the frame isolators,if yours look ok then use them but keep in mind if they are bad or have become un vulcanized there aint much holding the suspension in the car.
Ken/Alabama is offline   Reply With Quote
Old 08-11-2014, 05:57 PM   #3
copperpenny
Bruce, they are called "frame insulators." Lincoln part number 96H 5044. There are 4 on you car.
copperpenny is offline   Reply With Quote
Old 08-11-2014, 07:17 PM   #4
Thanks, seem to be in fair shape, not dissolving or brittle, looks like they were not subject to grease or gas over the years.
Old 08-12-2014, 06:09 AM   #5
Vic Piano
Vic Piano's Avatar
Bruce, Unlike Ford & Mercury, if an LZ was ordered new in '39 with a Columbia, the unit was installed at the factory. If it was an afterthought, it would have been installed at the dealership. The Columbia I have for our '39 (came out of a Coupe) does not have the speedometer cable attached to the rear axel, it is attached to the transmission, with a "gear kick down" unit mounted to the firewall. As Ken mentioned, there is a rod that attaches the "vacuum switch" (mounted on the steering box) to the clutch peddle assembly, the rod passes through the "belly pan" that shields the clutch and brake peddle assembly. In addition to the cable that (in my car) has a bracket that mounts under the dash to the left of the steering column drop. The cable in my car is split, with one end going to the vacuum switch and the other to the speedometer "kick down" unit on the firewall. My car is a "late production" as was the coupe that the Columbia came out of.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 08-12-2014, 03:38 PM   #6
Ken/everyone, here are photos of the heater parts I have with car. Next I did order the grease seals today, will wait on them and then reassemble drums with bearings packed. I am going to leave lower adjustment star screw loose and test wheel cylinders before adjustment. If wheel cylinders work well I will adjust and try to drive car with stuck clutch, I am hoping it frees up.
heater parts that I have, came with car
Old 08-12-2014, 09:13 PM   #7
Ken/Alabama
Bruce, The heater blower shown at the bottom of the picture isnt for your car,I dont reconize what it fits but definatly not your Zephyr. The one in the top of the picture and the elbow with the silencer looks correct. The piece of flat curved steel with the large and small hole doesnt belong to the heater at all, it goes on top of the transmission over the shifter tower to serve as a support for the sponge seal that goes between it and the removeable transmission cover. The sponge seal isnt available for the Lincoln but I made one from buying two of the sponge seals for 37-39 Ford car part # 78-7012130 and using them. Included a picture of the metal ring and where it goes.
Old 08-13-2014, 03:41 PM   #8
Working on the rear brake drum removal, drivers side came off easily, passenger side will not move, Have a good hub tool, used a wrench with a cheater. Brakes are released, drum spins freely. I left the drum under pressure from hub tool and build a dam and filled with PB Blaster to soak the axle. I will look on search for drum removal tips!!!
ALSO , need Vin# location, got my title today from previous owner and will have to have vin# verified.
Hub puller with PB Plaster
Old 08-12-2014, 04:57 PM   #9
Mike B
Hey Bruce, your stuck clutch.
Rotorwrench tipped me off to:
Get the rear up on jack stands
2nd gear start the car in gear.
Get the speed up to 30-ish MPH...foot in Clutch and hit the brakes hard.
Mine freed up the 2nd try.
Mike B is offline   Reply With Quote
Old 08-12-2014, 06:32 PM   #10
Mike B. as soon as I get front drums/tires back on I will might try that, I have to remove the rears first and clean up brakes, bleed them and check wheel cylinders, give me some time and I will report back as soon as I have brakes, thanks for another idea, BJ
( have clutch pedal depressed now with a board )
Old 08-13-2014, 05:06 PM   #11
Mike B
Hey Bruce, I'd put a nut on the stud there so as not to flatten out the threads.
Old 08-13-2014, 05:39 PM   #12
Ken/Alabama
The VIN is located on the front crossmember on the drivers side .
Old 08-15-2014, 08:43 PM   #13
Thanks Ken, good location for number and it matched my title. Today I repaired the passenger side front brake line. Still with brakes bleed the brake pedal would not move, pedal would move if I bleed the wheel cylinders. Pulled front two drums and took brake shoes off and found problem.
Wheel cylinder cups rotted
Cleaned up wheel cylinder
End view of wheel cylinder
Will add grease hose to wheel cylinder after installation of bleeder and shove out parts with grease gun, then drive out other parts with a dowel. Will hone the cylinders and order rebuild kit. Want to get some brakes so I can drive car to free up the passenger side rear brake drum ( stuck ) and also get clutch free and working. Next week I hope!!!
Old 08-16-2014, 04:58 AM   #14
BILL WZOREK
BILL WZOREK's Avatar
Bruce:
Very nice way you discribe & with pictures of what you are doing.
Now We still want to know what's in the trunk ???? ( with pictures )
BILL WZOREK is offline   Reply With Quote
Old 08-16-2014, 12:54 PM   #15
Bill, thanks for reminder, I received the key for the glove box about two days ago and 32Phil made me a couple of spares for the ignition. The trunk key he cut from the code I furnished worked great.
Opened trunk, had two rags / towels behind the spare tire, pulled the towels off and this is what I Found.
Couple carbs, light bulb set, little Gulf bank can, old gauge, and a sealed rebuild can.
box of ignition parts for unknown use, need a old parts book
lots of hub caps, two Cadillac, Early V8, three SS wheel covers, three early 50 or 60 wheel covers,
old envelope that was torn open
Loaded my cart with misc. items, small hoses, old radio, back up light, extra rear drum, two NOS head light glass and a chrome trim ring and all the used parts from the V12 motor rebuild. Might not be all small items but close.
Old 08-16-2014, 03:47 PM   #16
Cody_1948
Cody_1948's Avatar
HOLLY $#!T way tooo cool, Love the car,
Cody_1948 is offline   Reply With Quote
Old 08-16-2014, 05:20 PM   #17
Ken/Alabama
Hey Bruce, is the jack and tool kit still in the car. ? And does your car have a spring on the spare tire rack??
Old 08-16-2014, 07:52 PM   #18
Vic Piano
Vic Piano's Avatar
Ken, my '39 LZ was a mid to late production car and it does not have the spring on the spare tire rack... I have seen them on '39 LZ's, do you know if it was an early production part that was discontinued?
Old 08-16-2014, 08:38 PM   #19
Ken, is there a compartment for the jack and tool kit, if so where???? No, spring that I know of, you just pull the tire and it leans forward toward you, BJ
Old 08-16-2014, 09:53 PM   #20
Ken/Alabama
I think in the sedans the jack would be under the rear seat. Not all Zephyrs had a spring on the spare tire rack, it's a early,late thing.
