#61 | |
---- "INFLAMABLE"??? SInce that is the same thing as "FLAMMABLE" what ARE you speaking about, Skip ? We were using WD 40 as a propellant in "Potato Guns" maybe thirty years ago, which meant it was "Flammable" then, and I guess even somewhat explosive, and it still is listed as "Flammable." While I do recall it was safe for shipboard use, that didn't mean it wasn't flammable. ![]() WHEN was in NON FLAMMABLE?? |
#62 |
#63 |
After watching posts on MMO for the past few years, it is quite evident that this is about as controversial as engine oil......those that have tried and like it, and those that think it is useless.....don't think any of them are changing no matter what is said either way!
#64 | |
Terry |
#65 |
Some of the guys up here use two cycle outboard motor oil in their gasoline. I still use the Marvel at 4oz to the tank, each time I top up.
#66 |
Fearless Last edited by Tom Foster; 02-14-2011 at 01:13 PM. Reason: incorrect word |
#67 |
I have used MMO in the crankcase (1qt) of all (eight) new motors since 1970, for the break-in change: no adverse effect. I have run it as a winter additive in dire weather, no prob. Also I have u sed it in the gas tank in both old motors and new.
One particular case was a 351 Windsor in a E250, I bought it with a hundred and eight thousand on it. It would back fire, diesel, etc when turned off. The symptoms left and power on hills improved with about seven fill ups. My first experience was a '49 Dodge I had in 1965 it was a smoker I used MMO in the crankcase, the problem was decreased though not eliminated. |
