#1 |
Guys, this block already exist! It has already been cast, built and tested! The drawings are done, the CAD work finished, the casting procedure is done. It is a physical engine you can look at. There are still insurmountable road blocks to bringing it to market. These are not easy task to accomplish, we are not talking heads or oil pans here. I worked in a foundry for years and have built casting molds. It is not going to happen.
#2 | |
#3 |
The people that have build these engine are not able to get it on the market. They can build one-off engines but not production. If you were really wanting to do something like this get with them and see what is required to get the engine that already exist into production.
For some reason these links are not working, see post #15. The last link is a very detailed video. http://www.motorcityspeedequipment.c...ge_id=newblock http://autoweek.com/article/car-news...-just-wont-die http://autoweek.com/article/car-news...-just-wont-die http://www.hemmings.com/magazine/mus...d/1281426.html http://www.jalopyjournal.com/forum/t...athead.966947/ http://vintagemotorsusa.org/AluminumFlathead.html I would love to see one on the market, but just don't believe it is going to happen anytime soon. The Motor City block has been advertised as ready to be mass produced for years. "Ready this fall" "Early next year" etc. for years! Last edited by JSeery; 06-26-2016 at 01:06 PM. |
#4 | |
I know Mark and I know about his project. Whatever is preventing this engine from coming to market is a shameful travesty. As I have always said for what Ford Motor Company spends in a weekend on racing they could have pushed Mark over the top ten times over. |
#5 | |
#6 |
#7 |
#8 |
I thought Don Ferguson was or had casting new aluminium blocks? I'm sure I seen a car with one it it, the engine had Ardun heads and a Scot blower atop and I am definite I was told it was an Ali block which was completely new.
#9 |
A block for Ardun application is easier to cast than a block for flathead use. With the Ardun you don't need any of the intake or exhaust passages that add a lot of complication to the casting.
#10 |
I think the video shows why the project was aborted. In addition to Mark Kirby there was an additional brain trust involved in the project and they re-engineered the whole package. There isn't much they left on the table that is not unique to the MCFH aluminum block; d-ports, smaller, relocated head studs, roller cam and unique guides, proprietary heads needed for new stud locations, revised oil pan, water pumps, front cover, cam gears, Fluiddamper balancer and on and on.
It is for certain a complete work of engineering excellence, but all the upgrades made it out of reach ($$$$$) for the typical hobbiest and it's for that reason I think the project was shelved. Who wouldn't want one, but how many could pay for, or justify the cost?
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
#11 |
It appears that the video mentioned was shot in 2012; anyone seen anything since then?
http://vintagemotorsusa.org/events.htm |
#12 | |
#13 | |
In stock form, ZZ4's put out 350 h.p and 400 ft lbs of torque. Hard to walk away from that, even with a 300+c.i. normally asperated flathead. Same trams, same rear, I think that story is an urban legend. Last edited by Tim Ayers; 06-27-2016 at 07:29 AM. |
#14 | |
Thinking about it another way, the stock 221" Flatty in my '41 runs darn good for what it is. I doubt a 221" OHV V8 would put all that much daylight between us if the theoretical 221" OHV were similarly equipped induction wise. "Flatheads don't breathe" is the mantra you hear. Maybe at stop light to stop light speeds the L head engine doesn't give up all that much in breathing and make up for it with better fuel mixing and combustion efficiency. Not to mention the 4 3/8" stroke in the belly of that Flatty. That's a dimension that a small block Chevy could never swallow. Just sayin'. |
#15 |
That's the thing about that ZZ4 combo, it was designed with a really useful torque and power curve. I don't doubt MCF flatty gave it a run for its money, but it's a tough package to beat. Plus, some of them had the LS4 cam package that jumped the performance up even more.
I really want this MCF project to happen. I think it would be awesome to have some of these big boy flatties running around. Last edited by Tim Ayers; 06-27-2016 at 08:06 AM. |
