#1 |
Have you looked for a date stamp on the gas tank yet? I think JB suggested that in the other thread.
-Tim
No one wants advice - only corroboration. -John Steinbeck |
#2 |
Didn't see a date stamp on the gas tank. It has a couple coats of paint on it, I do see some indentions in the paint where the stamp should be but definitely nothing readable. Its possible the tank was replaced during restoration.
#3 |
Jim, 90 years later a gas tank could have been changed....or even a chassis.
Having a tail lamp bracket bolted to the lower body sub-rail is a '28 'item' vs. the common '29 tail lamp on the r/r fender. Manage your expectations regarding the Benson Archives which consists mostly of Ford blue prints etc. Information from body sub-contractors usually was retained & destroyed by the contractor as they went out of business or got sold. All that 'golden' info became land fill. You need to explore all the differences of your Father's car vs other '29 DD's, starting based gas tank dates. Enjoy your quest, jb |
#4 |
Hi JB, many thanks again. That was great advice. I went through all the original notes on this delivery, other research materials and then compared it to all the other production 1929 and beyond Deluxe Deliveries. Here is what I found. I also attached a picture of my deluxe delivery and also a 1929 Production Deluxe Delivery. The photo of the production engine is in line with all the other deluxe delivery engines I have see. There are quite a few differences between my Delivery and Production Deliveries. I welcome any feedback.
Vehicle Background • My Deluxe Delivery was assembled in Chicago, frame stamped. • This delivery was left in a “barn” in Indiana from 1955-2003 • Purchased by Lt. Col Tom Philpott in 2003 • Brought back to Georgetown, Tx for restoration. (This would be Tom Philpott’s 5th Model A restoration), he had owned, driven and restored Model A’s most of his life. • Tom Philpott was a very experienced Model A restorer. At the time of this restoration, he owned 4 other Model A’s including a 1931 Delivery. In his expert opinion, these parts were part of the original build. Key differences between this Delivery and what I have seen on production Deliveries: o This Delivery has an early model A (AR) chassis, hand brake is on the left side. This was used through June of 1928. o This Engine stamp shows May of 1928. o Having a May 1928 engine, allotting time for shipping the engine and then putting it on an AR chassis. This time frame lines up with a Oct-Nov. 1928 Prototype. o This Delivery has a solid front motor mount, they were used through Nov. 1928. o It has a cad plated generator end cover; these were not used after 1928. o This Delivery has a fan shroud, I have not seen one on any of the production Deliveries that I have found. Ford stopped using the fan shroud in Feb. 1929. o This Delivery has a square starter switch, Ford stopped using these in Oct. 1928. o This Delivery has the body mounted rear taillight bracket and drum taillight. o This Delivery was unusual in the fact that the metal body panels were bolted together and then nailed to the wood frame. We have not found any production deliveries with them nailed, the ones we have seen used rivets, which would make sense on an assembly line. In Oct. and Nov. of 1928, production lines were not set up yet for the production Deliveries. So, it is believed the prototypes were put together basically by hand. Nailing the body to the wood frame would be in line with that. In addition to using other unusual parts. Which were found on this Delivery. • During restoration he was visited by Ken Smith “Editor of the Lone Star Model A Ford Club”. Ken wrote an article in approx. 2005 about this Delivery. Here is quote from Ken after spending the day with Tom Philpott. “I visited Tom Philpott while he was restoring his 1928 Model A Delivery Truck. At that time the frame was off, and Tom showed me parts that didn’t belong on any Model A Ford that I had ever seen or read about. We spent some time examining the parts and believed the car was a prototype or very early test model”. • Tom also shared notes with Les Andrews during restoration, Les was confident he had one of the other 2 remaining Preproduction Deliveries. |
#5 | |
While anything is possible it is very unlikely that a left hand brake chassis would have been used as late as October or November of '28. Ford was quick to obsolete that brake setup to conform to various laws requiring separate service and emergency brake systems. Additionally engines shipped from the Rouge to Chicago could be delivered in a day or two. Those factories far from Dearborn may see as long as a month delivery time. -Tim
#6 |
#7 |
Just looked up Disneyland California a Adventure "Boudin Bakery tours" and there is a deluxe panel sitting there. Plenty of pictures too. LRF
#8 | |
![]() ![]() Brad in Maryland Last edited by Brad in Germany; 07-12-2023 at 12:03 AM. |
#9 |
