04-08-2013, 10:49 AM | #61 | |
Re: generator or alternator
04-08-2013, 10:56 AM | #62 | |
04-08-2013, 07:40 PM | #63 | |
04-08-2013, 08:23 PM | #64 |
I have an alternator on my rig, cost me about a hundred bucks for the kit 3 years ago. Not a bit of trouble with it since then.
04-08-2013, 09:00 PM | #65 | |
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls '41 Fordor Deluxe / 2-duece flattie '66 1/2 Dodge Charger '14 100th Anniversary Challenger Limited Edition. Semper Fidelis |
04-09-2013, 02:40 AM | #66 |
04-09-2013, 06:03 AM | #67 | |
My powerhouse generator and an alternator both generate alternating current, but my powerhouse changes it to DC though the commutator and the alternator changes it to DC through the 6 diodes. So both send out DC current. My Honda EU1000 produces alternating current and sends out alternating current, and yet it's called a "GENERATOR". Is this an oxymoron or what? BTW, here is what Audel's has to say about the generator: Last edited by Tom Wesenberg; 04-09-2013 at 06:34 AM. |
04-09-2013, 06:23 AM | #68 |
Four pages so far and not one response from machine girl. They must be still thinking "What to do".
04-09-2013, 10:36 AM | #69 |
You can convert an alternator to a single wire yourself. Pick up a GM alternator and buy the single wire conversion kit from NAPA. Made the support from the outside pieces from a spring shackle, purchased the pulley from Model A suppliers. If you want the full instructions send me an email [email protected]. Purchased my alternator from Fleet Farm for about $50.00 including core charge. That was a few years back.
04-09-2013, 10:57 AM | #70 |
I prefer blondes
04-09-2013, 11:45 AM | #71 |
I have an alternator on my pickup simply because I wanted to be able to run 12v accessories. Oh and it was already done by my grandfather before I got it. But I also picked up a delco remmy 10s for an old GM car, Vega maybe, and just swapped out the internal regulator for a self exciting one wire. Simple and cheap to do total cost was about $50. Don't forget though if you change to 12v there is more that will have to changed than the generator, i.e. light bulbs, negative ground, coils and things of that nature. Good luck!
04-09-2013, 01:05 PM | #72 |
04-09-2013, 01:34 PM | #73 | |
04-09-2013, 04:06 PM | #74 |
But redheads are extra fun..............
04-09-2013, 04:20 PM | #75 |
Hello, "machine girl." You still there? Stick with a stock 6 Volt Positive Ground generator. Run your GPS and MP3 Player off their own batteries (and what a joy it is to pull up to as bank drive-through window with Scott Joplin or an FDR speech blaring from the speakers). Plenty of juice to run LED brake lights and turn signals. ZERO problems since 1967.
04-09-2013, 06:35 PM | #76 |
04-09-2013, 09:24 PM | #77 |
I'm sure "machine girl" must be amazed by all the suggestions. I'm a relative newbie myself, but am a retired electrical engineer. My take is as follows:
I like originality as much as possible. However, as I often have to drive at night (like coming home from all our club meetings), I must admit that the stock lights were a bit anemic. I changed to 50/32 cp headlights & cranked up the brushes, but soon realized that I was pushing the generator beyond it's capability. Thanks to Tom for pointing out that the long generator is only good for about 12 amps continuously. Even dropping back to 32/32 cp headlights would put me over the 12 amps, when taillights & ignition are figured in. Besides, I feel that the 3 cp taillights are rather dim, considering that the driver behind me is probably preoccupied with his/her cell phone. Having to continually adjust the third brush, or put up with excessive battery charge & frequent bulb failures, is also an issue. Again, I salute Tom for his internal voltage regulator, but meaning no disrespect whatever, it isn't original, although it is nicely out of sight. Re bulbs, I like the originality of plain incandescent bulbs. The light from halogens & LED taillights just doesn't appeal to me personally, nor do the very high prices! So, my solution is to stick with 6 volts, positive ground, but use a low current alternator. As I wince when I look at modern alternators in an A, I went with a Wagner 40 amp unit, which looks a lot more like a generator with it's fan & black painted housing. Why only 40 amps? Consider that the wiring was designed for a generator of less than 20 amps...And I have NO plans for AC, GPS, phones, nor MP3's. I use the 30 amp repro ammeter, so the stock look is retained. The usual 30 amp safety fuse works fine. I did find two VERY nice wiring harnesses from Sacramento Vintage Ford using heavier gauge wires (12 instead of 14). One goes from the terminal box to starter and generator, the other is the instrument panel harness. Together they are only 20 bucks and look totally correct. I use 50/32 cp headlights, 10 cp taillights & parking lights, and 32 cp brakelights. I'm amazed how bright all the lights are with full voltage on them, and I don't have to worry about moving brushes or overcharging. That's my solution; works for me. |
04-09-2013, 09:56 PM | #78 |
Ain't all this ultimately about the battery? Buy a microprocessor controlled, desulfating battery charger (not a trickling battery tenderizer) and use it periodically on your A (and modern cars) and it won't make any difference what is under your fan belt - your battery will last longer AS LONG as what is under your hood is not boiling your battery...
04-09-2013, 10:09 PM | #79 |
This Is just getting crazy!
04-10-2013, 12:13 AM | #80 |
Page 5 coming up shortly
