Old 02-03-2013, 11:19 AM   #721
Vic Piano
Vic Piano's Avatar
Default Re: What I Did on My Lunch Hour
Originally Posted by copperpenny View Post
Darn...Can'tseeshi! www.antiqueautobattery.com. Sorry Vic
I looked at the site but didn't see a battery that looked like the one in the Lincoln...
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 02-03-2013, 11:20 AM   #722
Vic Piano
Vic Piano's Avatar
Old 02-03-2013, 11:31 AM   #723
VeryTangled
VeryTangled's Avatar
I think this is the info that copperpenny is pointing us towards.
(Public service announcement: Win7/Vista have a useful utility called SNIPPING TOOL. Anything you can see on the screen you can select a portion and save it to a .jpg. A slick way to start it is to tap the Windows Logo key on the keyboard, and type SN, the first search hit should be SNIPPING TOOL, and then press enter. Sometimes I use CTRL+ to zoom the screen before taking the snapshot.)
-VT/Jeff
VeryTangled is offline   Reply With Quote
Old 02-04-2013, 07:31 AM   #724
Vic Piano
Vic Piano's Avatar
The fun just never ends... Yesterday, while out driving the Zephyr, another motorist mentioned to me (at a stop light) that the car had no brake lights... I turned around and went home (using the headlight switch to activate rear illumination to emulate brake lights). I've got the '51 F-1 perched on the lift with a bottle jack supporting the bell housing so; I can't move the truck, which left me no choice but to crawl under the Zephyr. I checked for power to the brake light switch... that was ok... I checked for power out of the switch... that was ok as well... through my severely limited power of reasoning I deduced that the problem was isolated somewhere in the original 74 year old wiring harness. I checked the connections to the tail lights (they work) so the interruption has to be in the wiring for the brake lights... Upon closer inspection I found several sections of wire that were lacking insulation… I have a new Rhode Island Wiring harness for the car but I didn’t want to install it until after all the body work and painting were done so, I think I’ll fabricate a separate “harness” to run from the brake light switch to the tail lights and see if that cures the problem…
Anyone have a better idea as to how I can remedy this situation?
Old 02-04-2013, 06:24 PM   #725
Steves46
Steves46's Avatar
Vic, I think fabricating a seperate harness is the solution until you are ready to install the replacement harness. Steve
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 02-04-2013, 06:50 PM   #726
VeryTangled
Black tape over the icky parts.
Extra fuses and fire extinguisher.
-VT/Jeff
Old 02-04-2013, 08:18 PM   #727
Vic Piano
Vic Piano's Avatar
I think that's gonna' be the way to go... I won't have a chance to get to it durring the week and I'll be out of town on Wednesday so, it's lookin' like Saturday's play time will be divided between the '51 F-1 transmission swap and the Zephyr wiring and possibly some work on Mike's '41 Business Coupe. If you're not doing anything fun... come on up...
Old 02-04-2013, 08:21 PM   #728
Vic Piano
Vic Piano's Avatar
-VT/Jeff
I don't think there's enough "black tape" in the state of Florida to cover the "icky parts"... that's a looong harness...
Old 02-04-2013, 08:34 PM   #729
Shadetree
Shadetree's Avatar
Sounds like the Zephyr is on it's last legs. You should sell it to me....
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 02-05-2013, 06:50 AM   #730
Vic Piano
Vic Piano's Avatar
Bud, As with most of our "old cars" (not just the Flatheads), there are times that I'd consider giving them away however, that feeling always passes rather quickly... As for the Zephyr, you'll have to wait until I join Henry Ford, to have a chance at her...
Old 02-05-2013, 07:04 AM   #731
Mart
Mart's Avatar
Vic, are you running flashing indicators? If so the feed goes from the brake light switch into the indicator switch and then back out to the brake lights.
Just checking.
Mart.
Old 02-05-2013, 08:17 AM   #732
Vic Piano
Vic Piano's Avatar
Mart, no, the car is stock as far as electrical accessories go... (no turn signals) I just use my left arm (and middle finger when appropriate...) to signal my intentions to drivers behind me...
Old 02-05-2013, 08:50 AM   #733
41ford1
41ford1's Avatar
Just checking.
Mart.
This schematic is similar to my pickup installation. The switch I found at a swap meet had an additional power feed for the fronts. It allowed the use of the parking lights for directionals. There is no identification on the switch I have. It looks very similar to the one in the diagram which is a Signal-Stat 900.
41ford1 is offline   Reply With Quote
Old 02-05-2013, 09:10 AM   #734
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
For turn signal information, take a look at my club's website TechTopics. There are two articles there, one a collection of signal wiring stuff and a second on my installation on a '29 Tudor. http://www.CedarCreekAs.org
Bill Lee
BillLee/Chandler, TX is offline   Reply With Quote
Old 02-05-2013, 09:34 AM   #735
Vic Piano
Vic Piano's Avatar
Chuck & Bill, thanks for the turn signal information. I have installed turn signals in other cars but, for now, I kind a like just using my arm, hand, and finger as that method gives me a chance to express my true feelings toward other drivers... LOL
Old 02-08-2013, 07:41 AM   #736
Vic Piano
Vic Piano's Avatar
With the weekend fast approaching, we've got a full plate of fun scheduled. Steve, John, Chuck, Cliff, Mike and Don are all planning to be at the garage. The itinerary includes installing the '49 Merc O/D transmission in the '51 F-1 (just so we can temporally move the truck off the lift) and put the Zephyr up so we can fabricate and install a wiring harness for the brake lights. We'll also check out Steve's '46 Coupe to see if we can locate the source of the "chatter" and possibly get Mike's '41 up on the lift to check the rear end... All that work (fun) will definitely call for a PIZZA...
On another subject, have any of you ever used car detailing products from Griot's Car Care? I sometimes get their catalog in the mail but, until this week, I've never bought any of their products as (in my opinion) they are rather pricy... I was at the local car parts store and they were having a SALE on Griot's products. I bought a 35 ounce spray bottle of "Speed Shine, the five minute detail" and a package of micro fiber cloths. I used it on our '39 CS and really liked the result
(not sure the photo is a good representation of the shine) so, I tried some on the '39 LZ (the paint job on the LZ is over 50 years old and to say its not in the best condition is an understatement of gargantuan proportions). Well, now I'm sold on this product. Guess I'll have to watch for the next sale!
Old 02-08-2013, 07:57 AM   #737
oldford2
oldford2's Avatar
Vic,
Did you figure out how the rear mount is made?
John
oldford2 is offline   Reply With Quote
Old 02-08-2013, 08:11 AM   #738
Vic Piano
Vic Piano's Avatar
John, We won't be able to configure and/or fabricate the "rear" mount/cross member until get the transmission in and see where everything sits. We’ll also have to see if the solenoid will clear the existing cross member or if we’ll have to “trim” a little off to make room…
Old 02-08-2013, 08:45 AM   #739
BILL WZOREK
BILL WZOREK's Avatar
Vic:
Which of Griot's products did you use?
I went to there site and they offer a large selection of Cleaners / paint Prep. / wheel cleaners.
How was the ease of application / removal ?
BILL WZOREK is offline   Reply With Quote
Old 02-08-2013, 09:07 AM   #740
TomT/Williamsburg
TomT/Williamsburg's Avatar
Vic - car looks really good as I've seen this one up close and personal. I've used a couple of "quick shine" products over the years - I call them a "24 hour" shine in that they usually do a great job say for a show or cruise night but are not a long lasting one.
Last couple years I've been using a Gliptone product on my 40 coupe - it can be applied in direct sunlight, hot cars, cold cars, and using microfibre towels the shine is contagious to say the least. It looks like Pepto Bismal as it's pink in color but it sure does shine up my 35+ year old paint job on my coupe!
TomT/Williamsburg is offline   Reply With Quote
