Old 09-21-2021, 03:41 PM   #661
V8COOPMAN
V8COOPMAN's Avatar
Default Re: photo1-1-window
Click Links Below __
T5 W/TORQUE TUBE
Old 09-22-2021, 06:04 PM   #662
V8COOPMAN
V8COOPMAN's Avatar
'40 Frame
T5 W/TORQUE TUBE
Old 09-24-2021, 06:26 PM   #663
V8COOPMAN
V8COOPMAN's Avatar
T5 W/TORQUE TUBE
Old 09-25-2021, 05:22 PM   #664
V8COOPMAN
V8COOPMAN's Avatar
'40 Merc Drive Shaft/Torque Tube
T5 W/TORQUE TUBE
Old 09-26-2021, 01:31 PM   #665
V8COOPMAN
V8COOPMAN's Avatar
Early/Late
EARLY Spindle Nut
LATE Spindle Nut
T5 W/TORQUE TUBE
Old 09-29-2021, 08:59 PM   #666
V8COOPMAN
V8COOPMAN's Avatar
T5 W/TORQUE TUBE
Old 10-04-2021, 02:02 PM   #667
V8COOPMAN
V8COOPMAN's Avatar
42-48
T5 W/TORQUE TUBE
Old 10-04-2021, 05:58 PM   #668
V8COOPMAN
V8COOPMAN's Avatar
Axles 2
T5 W/TORQUE TUBE
Old 10-05-2021, 11:33 PM   #669
V8COOPMAN
V8COOPMAN's Avatar
IVAN's Vicky
T5 W/TORQUE TUBE
Old 10-06-2021, 09:45 AM   #670
V8COOPMAN
V8COOPMAN's Avatar
1949 Dizzy
T5 W/TORQUE TUBE
Old 10-07-2021, 08:59 PM   #671
V8COOPMAN
V8COOPMAN's Avatar
BRAKE Switch
T5 W/TORQUE TUBE
Old 10-08-2021, 12:42 AM   #672
V8COOPMAN
V8COOPMAN's Avatar
Cracked Axle
T5 W/TORQUE TUBE
Old 10-09-2021, 02:36 AM   #673
V8COOPMAN
V8COOPMAN's Avatar
Stents
T5 W/TORQUE TUBE
Old 10-09-2021, 03:21 PM   #674
V8COOPMAN
V8COOPMAN's Avatar
Pics
T5 W/TORQUE TUBE
Old 10-12-2021, 01:57 AM   #675
V8COOPMAN
V8COOPMAN's Avatar
T5 W/TORQUE TUBE
Old 10-12-2021, 05:36 PM   #676
V8COOPMAN
V8COOPMAN's Avatar
POLARIZING A & B Type GENERATORS
__________________________________________________ ____
Type "A" circuit - The field winding is connected to the insulated brush inside the generator and is connected to ground through the contact points in the regulator.
Type "B" circuit - The field winding is grounded inside the generator and is conncted to the armature circut inside the regulator.
To polarize the generator with:
Type "A" circuit - Momentarily connect a jumper lead between the regulator BATTERY and ARMATURE terminals after all leads have been connected, but before the engine is started.
Type "B" circuit - Disconnect the lead from the regulator FIELD terminal, and momentarily touch the lead to the regulator BATTERY terminal. This should be done after all other leads have been connected and before the engine is started.
I have always followed Bruce's way (Type "B") with good results with 1960-61-62 ford 12 volt generators
T5 W/TORQUE TUBE
Old 10-12-2021, 07:50 PM   #677
V8COOPMAN
V8COOPMAN's Avatar
B type generator
T5 W/TORQUE TUBE
Old 10-13-2021, 10:26 AM   #678
V8COOPMAN
V8COOPMAN's Avatar
Mike Mead 40
T5 W/TORQUE TUBE
Old 10-13-2021, 11:21 AM   #679
V8COOPMAN
V8COOPMAN's Avatar
"B"-Type Gen/Regulator set-up.
T5 W/TORQUE TUBE
Old 10-16-2021, 01:07 AM   #680
V8COOPMAN
V8COOPMAN's Avatar
1935 Brake Light Switch
T5 W/TORQUE TUBE
