#41 |
#42 |
how do we join!!!!
#43 | |
Keep 4-banging!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
#44 |
Yup, you recall correctly, from my memory. Sadly, Vince is not the only great talent/contributor who was 'put off' by the petty BS from some. Hope they reconsider, because they helped others, maybe without their even knowing.
#45 |
That's to bad wish ryan would open up a site for us model a-b modifieds. the hamb is good but to universal. would be nice to specialize. I bet it would be a big hit!
#46 |
#47 |
He put in a lot of work on his Ford Garage site!!!
A big help to lot's of people including me. John Cochran |
#48 |
I have A 34 B motor in my 31 160b the motor was rebuilt by Ron Miller
#49 |
Lets keep this thread going & maybe something will happen, Just purchased some new inserted rods, as running full presure, & inserts have holes in them now pluggiong top & bottom holes, taking the dipper off too, Derek
#50 |
I'm in
#51 |
Subscribed!
#52 |
Why don't one of you that have such a car start it again?
#53 |
YES!!!B motors, insert bearings ,downdraft carbs,overdrive transmissions, alternators, hot cams, the fun would never end!
#54 |
The HAMB can be hard to deal with because it is so big and diverse, but the A-B folks have done a pretty good job of centralizing much of the information: There is a Monthly thread started every month that cumulates much of each month's discussion and provides links for other good 4 cylinder material. Once you lock into that series of threads life becomes easier...here's the January 2014 one, which contains at the top quite a few archive worthy links:
http://www.jalopyjournal.com/forum/s...monthly+banger Model B stuff always needs a bit of looking, as the engines are considered orphans by both the Model A and the V8 people...no momma, no poppa, no uncle Henry. |
#55 |
OK it's re-started as a public group
1932-34 Model B Four Cylinder Group Just remember it has the same rules as the rest of Fordbarn. Have fun
#56 |
I'm in!!
Mike I just joined. Do I get a free puppy? Although I only have a lowly A motor, hope that's OK?
Blackwall Panthers Nor Cal chapter |
#57 |
Mike , thanks , think i just joined by following the instructions , Anyone have flow tests & how large a dia intake valves one can fit with out breaking into water jackets ? Just picked up a sacrifice block where a machine shop just cut through each valve hole to fit seats, went so large they got into water jackets then tried to braize each hole up , what a mess ,stuffed a good block , We may slice it to get an inside picture of the casting. Hot in NZ
#58 |
What is the link to get on board ?
#59 |
#60 |
that worked!!!
