#41 | |
You can't trust the Nu-Rex timing wrench the first time you use it. After setting the point gap correctly, you have to use a test light (a 6 volt bulb with test leads) or an ohmmeter to set the initial timing correctly (with the spark lever fully up). AFTER you set the initial timing with a light and tighten the cam screw down, taking out all slack by gently turning the cam clockwise, you can see where the Nu-Rex wrench falls on the distributor body relative to Pin #4 on top. I find many cases of the wrench going 3/8" or more PAST pin #4 when the timing is right. It is not because of a manufacturing error by Nu-Rex. This is due to the position of the cam follower on the modern points being in the wrong position on the breaker plate, compared to where it is with stock points. (A good reason to stick with original points.) After all the work you've done, this engine should be running by now. You have overlooked one small thing.
Jim Cannon Former MAFCA Technical Director ![]() "Have a Model A day!" |
#42 |
Did you check TDC with the pin on the timing gear and confirm by visually inspecting the piston through the spark plug hole? I’d start there to confirm the timing gear isn’t compromised, and then confirm that the points are opening and closing at the right point of rotation. It sounds like maybe something caused your timing gear or distributor drive to misalign, since it was running fine and then stopped, and you still have good spark and fuel.
#43 |
If you have an inline fuse, you may want to replace it….checking voltage with a meter or a test light doesn’t pull enough current and you may get faulty readings of power and voltage. I fixed one of my friends the other day that had similar symptoms since the fuse showed continuity but could not carry current…Also, make sure that the distributor is grounded to the engine…Just fyi…
#44 |
Thank you Sir! You win the prize! That is EXACTLY what the issue was!
#45 |
#46 |
#47 |
Yes, it is fixed, and we know how you fixed it. Congrats.
But the question is, what caused the issue in the first place? |
#48 | |
Take time and enjoy the ride. |
#49 |
Shoulda used the Ford method, with the timing pin.
One of my favorite expressions: "Slow down and get finished sooner."
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 05-11-2026 at 09:34 AM. Reason: Addition |
#50 |
