#41 | |
If not so balanced, at least mark the heavy side, to which the light side of the installed tire may be turned once initial balancing is performed.
Alan |
#42 |
All,
I finally just got the wide five plates finished. I had to go to a friend's shop and use his drill press and hydraulic press to get the studs pressed in. It turned into a lot of work. The press read up to 1500 pounds while pressing some of the studs in. I have had 8 made. As of 10-8-25, I have orders for four. When these are gone, they are gone. The inner holes are set at 5 1/4". These plates are intended for wide five tire changing and balancing. They are NOT intended for road use. They are bare steel. I recommend painting them with clear paint. If you use black, when it chips, it will show. They do fit in a USPS Medium size shipping box. US Shipping cost in a flat rate Medium size box is $21.95. The cost of the plate is $65 plus the $21.95. That makes it $86.95. Let’s just make it $85 including shipping within the US.
Steve in Denver |
#43 | |
#44 |
Lanny, I use the balance beads in my Model A tires, they're very popular in Model A circles.
#45 |
PM sent
Making the simple complicated for over 30 years. |
#46 |
