#41 |
I once drove my Model T to the moon, but I didn't like it there, no atmosphere.
#42 |
mleder.....I agree. Has anyone come up with a modification that is not too 'in your face'? I installed heat and sound insulation and a carpet because the engine noise was irritating on a drive over more than an hour (and it made the overall look far more elegant). I would love not to have to pull everything up every time I need access to the battery. I have considered behind the rear seat in my Tudor (it has a factory installed 3rd door at the rear because it had been ordered by a baker who used it sometimes for deliveries)...but that is a very long route for the thick cables.
#43 |
I have my battery on the rear pass runningboard of my 68c. The access is wonderful and the previous owner had those long cables to the rear bumper! I was going to move the battery back where it belonged, but the rear runningbd had minor rot and I was too lazy to chg out the runningbd. I will build or buy a box for the battery in the spring. It is a great location. Love it! |
#44 | |
![]() If I had to gripe about one thing, I would say the steering box. 7 tooth were harder to rebuild but the 2 tooth is less durable. Aftermarket parts (such as the shortened pitman arm) can amplify steering play and cause "death wobble" if your box is worn. But thankfully there are a few left out there who know how to rebuild them
Feb '31 Standard Coupe Member of the Little Rhody Model A Club & MARC Last edited by Mike1291; 11-28-2024 at 11:24 PM. |
#45 |
The Model A was a big improvement over the Model T. The biggest improvement I would make is Cast Iron drums over the steel drums of the day, which simply fade as they heat up. The other safety factor which would be changing out the glass sediment bulb for a cast one, I once saw one break and start a fire. That's about it. it's an A.
#46 |
Bob Bidonde |
#47 | |
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#48 | |
We see it today with the EV propaganda. Knock yourselves out buying that junk, I never will. Back to Model A's--- a friend is restoring a '30 Coupe and he had a REAL hard time trying to find a cast iron sediment bowl. He didn't want a glass one. Those dudes seem to be getting pretty scarce! And yes I agree with the post about those in-line plastic fuel filters hanging above the exhaust manifold like the Sword of Damacles.... run
#49 |
Jeff,
the first time I heard about the sword of Damacles was in a 3 stooges movie- maybe 12 yrs old! The best history lessons......... |
#50 |
I read that the Nader book didn’t kill off the Corvair, the Ford Falcon did. From what I recall, the Falcon cost less to build so it cost less to buy. The Ford also got better fuel economy. At the time Americans viewed small cars as economy vehicles and the Falcon was cheap. The Corvair cost more so than as compared to larger cars and it was a hard sell to convince Americans to pay that much for a small car.
David in San Antonio Late ‘30 Deluxe "Wretched Roadster" 1931 Slant Windshield Fordor “Earl Gray” Alamo A’s Club |
#51 |
My Dad paid $2000 for his 1964 zero options Corvair.
It was ironic that the Nader book came out before the '64 models did and they had the leaf spring/sway bar across the back that kept the swing axles from tucking in during a maneuver. I remember following an older Corvair and it was surprising how much the axles tucked and got the tires on edge. Edit: I see the book came out in late 1965. not a year earlier. My thought must have been that he didn't update it with available late information. Last edited by Bruce of MN; 12-04-2024 at 05:16 AM. |
#52 | |
#53 |
The thing I dislike about the Model "A" Ford is reproduction parts that are made inferior to the originals. Thanks' to the people that make thier repro parts correctly!
Overall, I think Edsol did a phenomenal job once Clara got Henry on board! |
#54 | |
Then that pie fell off the ceiling as that lady looked up got her right in the face Moe had hurriedly scampered away!
#55 |
My least favorite aspects of the Wretched Roadster: the contortions and awkwardness of removing the floorboards, and the lack of room for my feet and legs to move while driving. I drove a Model T touring car for about 20 minutes and that was so cramped I could hardly fit behind the wheel. So I guess the A is a big improvement though pickup drivers may argue the point.
#56 |
just thinking about that as i read the thread! but as kids, never seemed to bother us!
for 909: only a Model A... is a Model A!
"My Model A... work never ends, only the day ends!" |
#57 |
I like Most everything about my Model A Simplicity in design. However I really get my socks in a bunch over 1 design "flaw" the extensive use of Cotter pins on every nut!! when new i bet this was a fantastic safety feature, but 95 years down the road these little pains can make a 10 minute job turn into a half hour battle !!
#58 | |
Dave you're not alone.... I'm well over 6' tall and any Roadster I have ridden in or driven was a horror! The older I get the worse it becomes. And getting in and out of the thing that in itself is agonizing. With the top up anyway. I developed a way to 'swing' my right foot over the top of the brake pedal if that makes any sense to you, because there is no way to lift your leg to get to that pedal. I never remember our Tudor having that issue
#59 | |
1910 Model T Touring 1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
#60 | |
https://www.snydersantiqueauto.com/p...7804&cat=41699
The Master Cylinder Enjoying life at the beach in SoCal... |
