Old 10-06-2024, 09:58 AM   #41
flatrod
flatrod's Avatar
Default Re: Flathead(8BA) Automatic Transmission Options/Question
Looking at your picture of your C4, I see it has a floor shifted lever, which is Mustang, but the neutral safety switch has been removed and a shifter arm bolted on, to make it something other.
If you want column shift, I would replace that arm with a factory column shift arm and go back with the stock neutral safety switch. You really do need and want a neutral switch. Also don't forget the kick down linkage. You have the Mustang cable part now but may want to change that to a column shift arm too. Lokar probably has a cable kit for that, so look there.
flatrod is offline   Reply With Quote
Old 10-06-2024, 12:25 PM   #42
tyd_76
Good morning. Great and awesome. I’ll check it out now. I sure appreciate it.
tyd_76 is offline   Reply With Quote
Old 10-06-2024, 12:29 PM   #43
tyd_76
Thank you for the info.
Old 10-06-2024, 03:14 PM   #44
tyd_76
