Old 06-04-2024, 10:44 AM   #41
Mart
Mart's Avatar
Default Re: 2024 video releases from Mart's Garage. All in this one thread.
Early Ford Axle Keys. Easy to make so I made some!
Time for a breather and just some little jobs.
Just some little jobs this time around. I decided to make some new Early Ford type axle keys. I needed one for the 33 coupe and can use others on my other vehicles. It wasn't difficult and could be dome by anyone at home with basic tools.
The garage roof was annoying me with debris blowing in and getting on top of the cars. I did a round of little jobs just to tidy up the area and take care of some building maintenance.
Back to a little more car related nonsense next time.
https://youtu.be/IYp9xV0OM6M
Old 06-04-2024, 11:04 AM   #42
petehoovie
petehoovie's Avatar
Old 06-07-2024, 11:52 AM   #43
Mart
Mart's Avatar
Tonights bit of light entertainment.
Geoff's bracket needed straightening. We get it sorted.
I paint the bootlid on the 100E. Green be Gone!
Geoff popped by on his lightweight Panther, just recently put on the road after restoration.
Thanks for dropping by Mart's Garage!
https://youtu.be/2oDWV2Cs4lI
Old 06-07-2024, 01:46 PM   #44
petehoovie
petehoovie's Avatar
Old 06-11-2024, 02:21 PM   #45
Mart
Mart's Avatar
Mart's 57 T-Bird: Can I modify it so it starts in Park? Neutral safety switch upgrade! (Update 2434)
One of the quirks of these older Automatics was only being able to start in Neutral. This was a contributing factor to a little mishap I had when I accidentally selected reverse while working on the car. Luckily no damage was done. When I showed this, a comment from a viewer prompted me to do some research. I found a description of some mods done to the switch to allow the car to be started in Park as well as Neutral, which is more the norm in later vehicles. So follow along as I modify my switch using the forum post as a guide.
https://youtu.be/XI-9OaINqVM
Old 06-14-2024, 11:27 AM   #46
Mart
Mart's Avatar
Twin carbs on a flatty. Just how difficult can a fella make it?
Mart's 1933 Coupe: Hot Rod Dual Carbs for Pendine! Part1. (Update 2435)
I have decided to run my 33 coupe at this year's VHRA Hot Rod Races at Pendine. I have ran it before in it's current configuration, so I wanted to see what a difference a dual carb setup would make. The rest of the engine is unchanged and pretty well stock. The manifold does not fit as is so follow along while I make a series of modifications. Lots of lathe and milling machine work involved in this job. Hopefully once completed we will see an improvement on the beach!
The engine in the coupe is the crusty flatty. The one I featured in a video series a few years ago. Check it out the playlist if you want to see an engine that in reality should have been scrapped.
I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap!
https://youtu.be/PGxjbxzN6KY
Old 06-18-2024, 11:03 AM   #47
Mart
Mart's Avatar
More machining madness on the not quite a bolt on twin carb conversion!
Mart's 1933 Coupe Pt6: Hot Rod Dual Carbs for Pendine! Part2. (Update 2436)
I have decided to run my 33 coupe at this year's VHRA Hot Rod Races at Pendine. I have ran it before in it's current configuration, so I wanted to see what a difference a dual carb setup would make. The rest of the engine is unchanged and pretty well stock. The manifold does not fit as is so follow along while I make a series of modifications. In the last video I evolved a plan and started the machining. In this one I continue along the same path and get the carbs bolted on using custom studs. I then turn my attention to the next conundrum which is how to mount the generator. Lots of lathe and milling machine work involved in this job. Hopefully once completed we will see an improvement on the beach!
https://youtu.be/I6Il8VXbmLQ
Old 06-19-2024, 01:44 PM   #48
corvette8n
corvette8n's Avatar
Mart, next you’ll be melting aluminum cans and casting your own manifolds.
Old 06-25-2024, 04:11 PM   #49
Mart
Mart's Avatar
Guess what? I did some filming at Pendine!
Pendine 2024. Mart's 1933 Coupe at the VHRA Hot Rod Races! Part 1! (Update 2438)
Hello! Welcome to Mart's Garage. I have decided to run my 33 coupe at this year's VHRA Hot Rod Races at Pendine. I have ran it before in it's current configuration, so I wanted to see what a difference a dual carb setup would make.
So Join me and Geoff, Rusty and Trev on the trip down to Pendine, South West Wales. This Video covers the drive down and the first part of Saturday. I show most of the cars and my first run down the beach. I do see an improvement over my previous outing so the twin carbs appear to be doing the trick! Make sure you look out for part 2!
https://youtu.be/RF-S5tNFiIo
Old 06-28-2024, 10:51 AM   #50
Mart
Mart's Avatar
Pendine 2024. Mart's 1933 Coupe at the VHRA Hot Rod Races! Part 2! (Update 2439)
So Join me and Geoff, Rusty and Trev at Pendine, South West Wales. The last video covered the drive down and the first part of Saturday. I did see an improvement over my previous outing so the twin carbs appear to be doing the trick!
So watch to see what result my other runs gave and how Sunday turned out.
https://youtu.be/I8nHd6HXFVM
Old 06-28-2024, 04:17 PM   #51
FrankWest
FrankWest's Avatar
Mart
I love your video's. You are the best!
FrankWest is offline   Reply With Quote
Old 06-29-2024, 09:03 AM   #52
corvette8n
corvette8n's Avatar
Looks like your work paid off in gaining you some mph. Is Pendine only once a year?
Old 06-29-2024, 09:47 AM   #53
Als48
Yes, Mart. Keep the videos coming. I always look forward to them on Fridays. Great job on the dual carb setup, as well. Pendine seems to be a fun venue. Watching it and many other of your videos that I can connect with you, having a similar work and hobby background. I would like to meet you sometime, as I've been to France and Great Britain a couple of times. But getting older, at 78, I kinda doubt I'll be in Europe again. My sister was in Scotland last year with a couple of her daughters, one of which lives in Denmark, so we do have connections there.
Al Hook
Als48 is offline   Reply With Quote
Old 07-05-2024, 10:44 AM   #54
Mart
Mart's Avatar
New video up!
Mart's 1933 Coupe: Hot Rod Dual Carbs for Pendine! Part3. (Update 2441)
https://youtu.be/iIDvMoSOA4w
Plus here's a short one I put up on Tuesday. A neat little Thames van rescued in the 80s.
https://youtu.be/p46HwOc2GjY
Old 07-09-2024, 10:22 AM   #55
Mart
Mart's Avatar
Beautiful Prototype D type Jag at Gaydon May 2024. It Sounds great too! (Mart's Update 2442)
Tonight it's a quick walkabout at the Gaydon Gathering May2024. I captured some footage of the wonderful 1954 D Type Jaguar Prototype OVC 501. I hope you enjoy it as much as I did. It's a fantastic vehicle.
Click the link to read the fascinating story of the Jag D type prototype and it's Le Mans history.
https://www.jaguarheritage.com/vehic...-jaguar-d-type
Check back next time for more tinkering and headscratching at Mart's Garage!
https://youtu.be/Jo6NW9RT5wk
Old 07-12-2024, 10:39 AM   #56
Mart
Mart's Avatar
Hot Rod Dual Carb conversion for the 33 coupe! Part4. (Update 2442)
https://youtu.be/0qqdNosllGc
Old 07-16-2024, 10:39 AM   #57
Mart
Mart's Avatar
Tuesday tinker time. Bit of electrical troubleshooting on the 32 Sedan.
https://youtu.be/2Qt5WFwzmvI
Old 07-19-2024, 10:57 AM   #58
Mart
Mart's Avatar
Wheel Cylinders. Why can't they make them right? 41 Ford pickup brakes. (Mart's Update 2445)
https://youtu.be/4QhP2xwqxjA
Old 07-21-2024, 09:55 AM   #59
FrankWest
FrankWest's Avatar
Hello! I hope you are still interested in my videos. I thought I would put them all in this one thread, rather than an new thread for each video.
So lets see how it goes.
2401: Mission Creep 100E part 63! A Little Bit O This and a Little Bit O That (2401)
https://youtu.be/oX-ngqlDa6M
2402: Mission Creep 100E part 64! Replacing the failed rear mount.
https://youtu.be/hBEKJ3mLqkk
2403: Mission Creep 100E part 65! New Old Dip Switch, plus Gifts!
https://youtu.be/DCYLJIpW5fA
Get your kicks in vid 66.
https://youtu.be/1MMTHloJgSE
100E Vid 67. Low volt investigation and fix plus windscreen removal.
https://youtu.be/2Yl1w48J7YQ
Mart
I always love your videos. You are the best.
Old 08-03-2024, 10:32 AM   #60
Mart
Mart's Avatar
Releases will be occasional rather than regular from now on. I want to step off the Youtube treadmill. So here's the first non regular release:
https://youtu.be/tfGYN3KmAVQ
Mart.
