Old 04-09-2023, 03:49 PM   #1
B-ster
Default Distributor install issues lyb
Trying to get a distributor installed in my Lincoln y block. It's wicked tight. Bottom of the shaft won't go into the hole where it connects with the oil pump shaft. It came out of a 60 fyb 292 motor and I changed the gear on the shaft. I did mushroom the end getting the gear off but ground it down. If the shaft is supposed to turn, there has to be some clearance in there. What should I do? Thought about holding the distributor body in a vise and turn the shaft with a drill while holding sandpaper on the shaft slowly taking some metal off it evenly until it goes in the hole. Ideas???
B-ster is offline   Reply With Quote
