Old 11-14-2022, 01:19 AM   #41
ford38v8
ford38v8's Avatar
Default Re: Bushing dropped out of crab distributor?
Originally Posted by bigd1101 View Post
Now that's interesting......never seen one.
Who'da thunk there could be such a thing as a flathead enthusiast who has never seen a crab distributor.
Alan
Old 11-14-2022, 11:24 AM   #42
GB SISSON
GB SISSON's Avatar
Hey, easy on this guy.... He's got one of those modern spark o matic jobs. It's not too late for him to improve his system by installing a 'crab on a stick' into that post hole. Seems I read about some conversion where this was done.
Old 11-14-2022, 11:32 AM   #43
ford38v8
ford38v8's Avatar
Now THAT would be interesting!
Alan
Old 11-14-2022, 11:53 AM   #44
tubman
tubman's Avatar
Mallory made a "crab" cap that fit their standard distributors for marine use. I looked for one for years and finally found one.
Old 11-14-2022, 01:20 PM   #45
Tim Ayers
I found one of these crab capped marine Mallory dizzys at Hershey this year. I just assumed the cap was the same as a flathead cap. Is that not the case?
Old 11-14-2022, 02:26 PM   #46
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Mallory flatcap marine is a different housing !!!!!
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 11-14-2022, 02:43 PM   #47
Tim Ayers
Sure, I just assumed that it would have been designed to use the flathead cap they made.
I've found a few caps available at Marine supply houses. I don't plan to keep mine.
Old 11-14-2022, 03:06 PM   #48
cas3
Good to hear from you Bubba ! Hope you are doing OK.
Old 11-14-2022, 04:46 PM   #49
GB SISSON
GB SISSON's Avatar
Are we talking about putting a crab cap on a load o matic distributor? What I recall was seeing an adapter to add a long post onto a ford '42-'48 front mounted type distributor so a normal human could see it and work on it. OK, so an 'old' human could see it and work on it. .....
Old 11-14-2022, 08:05 PM   #50
rotorwrench
rotorwrench's Avatar
Mallory likely made most of the distributor caps as well as a lot of other ignition components for Ford since the front mounted distributors were mostly Mallory designs approved by Ford. Henry liked Marion Mallory. It may have been the Irish background.
After Hank the Deuce took over, the new 1948/49 8BA designs changed over to the Holly Load-O-Matic systems.
