10-10-2022, 06:27 PM | #41 |
Re: 59AB Going into my '33 Truck, Generator Question
Ok that's not like the one I was thinking of.
Remove the pulley and bring it all back to the surface you can see there where it is marred up by the old washer. If it were me I would take it back a few thou more to a nice new clean surface. A lathe is ideal for this sort of work. Thinking about it I was getting mixed up with the 40 type pulley where the fan bolts on. Mart. |
10-10-2022, 10:49 PM | #42 |
That type pulley I believe you will see spot welds that hold the outer pulley on. Lathe or grinder cut it down to the point it is loose, then gone. As for the hight at the front, try to put the crank end in the same place it was originally, so the hand crank would line up as it did even though you will not use that ratchet bolt. The crank will be longer so the bolt will hit the crank guide loop. cut that off, or use a cheaper more available model A U bolt/spring retainer
10-11-2022, 07:23 AM | #43 |
Thank you both!
Brad Williamson |
