Old 07-04-2021, 10:50 AM   #41
Brendan
Brendan's Avatar
Default Re: Mystery Engine Knock
did you talk to your engine rebuilder? what did he say?
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 07-04-2021, 01:05 PM   #42
chrs1961815
chrs1961815's Avatar
It is a reground stock cam. The lifter pulls up fine and I can twist it around.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-04-2021, 01:16 PM   #43
Patrick L.
Patrick L.'s Avatar
Stretching or shimming a spring may be a good idea.
Old 07-10-2021, 11:28 AM   #44
chrs1961815
So some updates here: we took another look at changed our minds about the valves and decided to pull the engine where we found that the insert on cylinder number 3 was badly scored and damaged. Replaced the insert and sanded the crankshaft and put it back together with the same knock. It has still got us stumped. Back to the drawing board.
What I don't get is that the problen does not go away when shorting out cylinders and it is hard to start and keep running (has to have the throttle pulled all the way down along with the spark advanced more than it should).
Old 07-10-2021, 12:30 PM   #45
Ernie Vitucci
Ernie Vitucci's Avatar
Good morning...have you considered changing the distributor and taking a good look at the gear at the bottom of the distributor shaft? Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 07-10-2021, 12:53 PM   #46
Bob Johnson
Bob Johnson's Avatar
A real stumpper. Since you have taken the engine apart have you tried listening for the knock with the cylinder head removed and using the starter to rotate the engine? You said that the knock is more noticeable at idle so it might show up using the starter to rotate the engine. With the head off the starter should be able to turn the engine faster than with the head on. Plus you can see some of the moving parts.
Just a thought
Bob
Bob Johnson is offline   Reply With Quote
Old 07-10-2021, 03:32 PM   #47
chrs1961815
I have not changed out the distributor but I was considering doing that. I rebuild distributors and I rebuilt this one so it is pretty much as new as the engine.
As for Bob's suggestion, we have previously tried to see if we could hear it hand crabking and using the starting to turn the engine and had no luck. But last night I sat there cranking it with the starter for a while and was hearing a knock and the speed slowing down. That has got me stumped! Might be worth giving your suggestion a try. We have previously ran it with a half valve cover to watch the valves.
Old 07-10-2021, 03:51 PM   #48
jimTN
1. center or front main loose.
2. Flywheel loose.
3. Crank end play.
4. Camshaft end play or loose cam bearing.
5. Why did you have a scored rod bearing?????
jimTN is offline   Reply With Quote
Old 07-10-2021, 04:06 PM   #49
kimlinh
is the piston hitting the head? The engine may have been fine when it was first rebuilt but a cracked piston could be giving you trouble now. Buy the way, I hope I'm wrong.
kimlinh is offline   Reply With Quote
Old 07-10-2021, 06:40 PM   #50
chrs1961815
The head has been off many times along with the pan. Had it on a stand to pull the rod and piston and inspected everything else. Cylinder walls and pistons looked fine. Pistons have been checked to make sure they are hitting the head and they are not. I am running a pretty thick head gasket anyways.
As for the scored bearing, the rebuilder said that it could have been a lack of oil because of a tight clearance or a possible particle of debris or something got inside there. We will never know. He made sure there was plenty of clearance and I made sure that the journal and bearing were clean and had no dust or anything.
Old 07-11-2021, 08:39 AM   #51
McMimmcs
McMimmcs's Avatar
Originally Posted by Marshall V. Daut View Post
Check your "Private Messages" in the top right corner of this web page.
Marshall
Unfortunately private messages defeat the purpose of a forum! We all want to learn!
McMimmcs is offline   Reply With Quote
Old 07-11-2021, 11:33 AM   #52
McMimmcs
McMimmcs's Avatar
Did you have a professional rebuild the engine ?
Old 07-11-2021, 01:47 PM   #53
chrs1961815
Antique Engine Rebuilding supplied the rods, bearings, pistons, valves, valve guides, camshaft and crank. They fitted the crank and the mains. I put the rest together.
Old 07-12-2021, 04:26 PM   #54
Rob Doe
Chris, I just got here and didn't read from the start, just page 3. It seems to me that just one missing cylinder would not create the start problem that you describe. It wouldn't run well, but it would start and run.
Could you have a model B timing cover? Check #1 piston to see if it is TDC when your pin drops in. I can look in the plug hole and see the top of my #1.
Shooting from the hip here.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 07-12-2021, 04:29 PM   #55
Rob Doe
I read recently where a few guys get their timing gear improperly aligned on installation. But you said the engine had 1000 miles on it. It surely ran and drove okay for that many miles? Or were they put on before this rebuild?
Old 07-12-2021, 05:20 PM   #56
tinkirk
tinkirk's Avatar
What are using for a cam gear?
tinkirk is offline   Reply With Quote
Old 07-12-2021, 05:27 PM   #57
nkaminar
nkaminar's Avatar
Chris, If you still have the pan off, turn the engine over by hand and see if one or more big end rod bearing is moving back and forth on the crank. This would be an indication of a bent rod which would cause an engine knock and is hard to diagnosis.
Old 07-12-2021, 07:33 PM   #58
chrs1961815
Okay:
I am using a new fiber gear from AER. Last October my timing gear went bad (must have been a bad one from a few years ago). Since then I put a lot of miles on the new one and an inspection of it tells that it is not the problem.
The timing cover is an A cover for sure. I just changed it out after the problem started because the motor mount holes had stripped out. Same problem.
I am starting to lean toward a bent rod as it seems I have covered everything else. Rob is right about the hard starting and running - that is what is the weird part.
The crank ends of the rod can move side to side a bit on the crank but I was told this is normal.
Old 07-12-2021, 07:56 PM   #59
nkaminar
nkaminar's Avatar
The hard starting and knock are probably not related.
The rod moving side to side on the crank is not normal. Have a good machine shop check the rod, or rods, that is/are moving.
Old 07-12-2021, 09:02 PM   #60
chrs1961815
To be clear, it looks like the crank ends of the rods are not wide enough to fit the whole journal of the crank. They are a good 1/8 inch short. I don't see how it could not knock for a long time if this was the problem - I also don't see how twisting could do this.
I will compare some original rods to a crank tomorrow just to see.
