Old 02-13-2021, 03:53 PM   #41
Gene F
Gene F's Avatar
Default Re: 4 post lift
Height of building when all the way up. Don't forget to consider the roof, so you don't colapse your vehicle.
Gene F is offline   Reply With Quote
Old 02-14-2021, 12:12 PM   #42
katy
katy's Avatar
Originally Posted by LEM View Post
Anyone use the max Jack to post lift? I like the idea of being able to unbolt from Floor and with the attached wheels move the post out of the way when I need the room in my small garage.
https://www.maxjax.com/
Neat, would be neater if'n one didn't have to bolt it down.
Old 02-17-2021, 09:21 PM   #43
MickyD
MickyD's Avatar
I had a 4 post bend pac and loved it. My only mistake was having the 115 v motor instead of the 220. I believe it might of been just a upgrade with wiring. Anyway it was very slow going up and down but it was very sturdy. I had to use my engine hoist to move it around to put it together. I made the mistake of getting the roller wheels later and if I had got them when I had ordered it, they would have been a lot cheaper in cost.
MickyD is offline   Reply With Quote
Old 02-17-2021, 09:39 PM   #44
TerryO
TerryO's Avatar
[QUOTE My only mistake was having the 115 v motor instead of the 220.][/QUOTE]
Yes the 110V is slower but with the lift being portable you can plug it in any 110 receptacle.
TOB
TerryO is offline   Reply With Quote
Old 02-17-2021, 10:04 PM   #45
denis4x4
denis4x4's Avatar
Backyard Buddy has provided excellent service for 20 years and it’s made in the USA.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 02-17-2021, 10:33 PM   #46
holdover
I have two 4 post lifts. A BendPac HD9 and a HD 12 that is extra long to accommodate crew cab long bed pickups and my AAs. Just ordered a Rolling Trolley Jack with 6000 LB capacity for the Bendpac HD 12, now I have the best of two worlds, the ability to easily pick up one end for suspension work and with the adjustable arms pick an end up from the frame, suspension or body pads. For the last 13 years I have used the HD 12 with its adjustable ability to set ramp distance apart, with jack stands to do just about everything the Rolling jack will do, the Jack will just make it easier. I use the HD 9 mostly as a storage lift to increase garage capacity. Too old to work off a creeper. But beware you'll find out you have a lot more friends!
holdover is offline   Reply With Quote
Old 02-18-2021, 09:01 AM   #47
TerryO
TerryO's Avatar
I don't know if that is still true. Advantage Lifts is now the manufacturer of the Backyard Buddy lift and they have the Advantage lifts built in China, so the Backyard Buddy may be built in China as well...I don't know for sure...
TOB
Old 02-18-2021, 09:24 AM   #48
jwmckenzie
TOB
The web page for the Backyard Buddy lift, clearly states it is Made in USA.
https://www.advantagelifts.com/pages/ah-lifts
jwmckenzie is offline   Reply With Quote
Old 02-18-2021, 08:51 PM   #49
TerryO
TerryO's Avatar
Thanks for the info...I hadn't looked at their site in a good while, I just remembered reading that Advantage had bought Backyard Buddy...
TOB
Old 02-19-2021, 09:56 AM   #50
jwmckenzie
They seem to understand that some customer prefer to buy USA, and a brand name matters. My though is they bought the "Backyard Buddy" brand for it's reputation, so are not going to change the Made in USA part of that reputation.
Old 02-19-2021, 11:17 AM   #51
Mike the Grump
I've been watering and fertilizing the garage for years hoping it would grow to accommodate a lift. So, far it hasn't worked.
If you get one, congrats.
Mike the Grump is offline   Reply With Quote
Old 02-19-2021, 01:09 PM   #52
Chris Haynes
Chris Haynes's Avatar
Originally Posted by brokenspoke View Post
How often do you remove the wheel, suspension?
When rotating tires, doing a brake job, Packing wheel bearings, ETC.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 02-19-2021, 01:13 PM   #53
Chris Haynes
I'm too old to crawl on the ground to place the arms on a two post lift
Wow! Sucks to be you. :-)
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-20-2021, 12:11 AM   #54
cokefirst
I have a reasonably large shop that I purchased for a song back during a recession several years back. I have four, 4 post lifts and a 2 post for repair. I use the 4 post lifts for storage and the 2 post one for repairs. I have used my 2 post lift to do repair on my 2005 F250 Diesel and my 1931 AA truck. All of mine are Chinese and I have owned one of the 4 post models over 20 years with No problems. I found that they make an extra wide, extra tall model and that is what I buy for my 4 post models now so that I can put old Broncos and Expeditions on it. I understand the distaste for Chinese manufacturing, but to be hones, I have had no trouble with mine and they appear to be very sturdy.
If you want US made, you can go for a Mohawk or other us made item but the cost will be 2-3 times as much. As long as these work and are sturdy, I am OK with the foreign manufactured products.
cokefirst is offline   Reply With Quote
Old 02-20-2021, 02:10 PM   #55
Chris Haynes
I bought my lift from Bendpac. They offer several different two and four post lifts.
https://www.bendpak.com/?msclkid=23f...ontent=General
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-21-2021, 08:33 AM   #56
Chris in WNC
Chris in WNC's Avatar
My aversion to Chinese lift manufacturing is based on safety.
The Backyard Buddy web site used to have detail photos of lifts showing design differences that make you think twice about the Chinese ones.
I do understand that Chinese manufacturers cut corners mostly at the behest of US buyers who want lower prices.
If you specify what you want and are willing to pay for, it their quality is acceptable.
no more model As for now........
Chris in WNC is offline   Reply With Quote
Old 02-21-2021, 09:24 AM   #57
SwampLedge
The Advantage 9000 # capacity four post lifts are manufactured in China and are now ALI certified.
SwampLedge is offline   Reply With Quote
Old 02-21-2021, 10:19 AM   #58
Stingray70
Stingray70's Avatar
I haven't bought one yet but am leaning heavily toward the backyard buddy. I am so pissed at the Chinese I will happily pay the extra $2k to get one made here.
I appreciate all the responses here. It has given me much to consider.
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 02-21-2021, 12:54 PM   #59
TerryO
TerryO's Avatar
The Advantage also has 5" post compared to Backyard Buddy's 4"...I wonder if BB uses US steel or China steel.
TOB
Old 02-21-2021, 05:30 PM   #60
Bruce of MN
Bruce of MN's Avatar
Bruce of MN is offline   Reply With Quote
