Old 10-25-2020, 07:40 PM   #1
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1940 Brake Bleeding
Originally Posted by Talkwrench View Post
speedbleeders are one of the best things I ever bought. After reassembling the diff and installing it I pumped the pedal slowly, always slowly and not all the way to the floor on a single circuit system. Cracked the far RHS bleeder open and I heard a rush of air, then a further 5 pumps making sure the clear tube has fluid with no air lock it off over to the other side 5 pumps done! Didn't even worry about the front, nice hard pedal and all done myself, easy.
I believe pushing pedal SLOWLY is the 'key' element here. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-26-2020, 11:37 AM   #2
Hal Beatty
Hal Beatty's Avatar
I'll second what Talkwrench said... I installed a set of speed bleeders on my 40 and they worked great! Took about 10 mins. to get the brakes bled, and not having to listen to the wife, girlfriend or daughter bitch about having to pump the pedal was priceless.
Hal Beatty is offline   Reply With Quote
Old 10-26-2020, 12:28 PM   #3
tubman
tubman's Avatar
You got both? You lucky dog!
Old 10-27-2020, 02:39 PM   #4
Hal Beatty
Hal Beatty's Avatar
Not at the same time... I always knew better than that
Old 10-26-2020, 01:41 PM   #5
JSeery
JSeery's Avatar
I always considered brake bleeding a social event!!!
Old 10-26-2020, 02:54 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
But don't forget "social distancing"......6 ft. and the mask! Bleed-on! DD
T5 W/TORQUE TUBE
Old 10-26-2020, 05:23 PM   #7
JSeery
JSeery's Avatar
Drivers seat to wheel cylinders should do it.
Old 10-26-2020, 06:54 PM   #8
JSeery
JSeery's Avatar
I've never had the pleasure of working with non-US brake parts, but from the post here on the Barn it appears they can have multiple issues.
Old 11-01-2020, 08:31 AM   #9
mike42
mike42's Avatar
There is a God ! First.....he invented Jack Daniels.........second I’m finally getting some pedal pressure after starting at rear wheel, but then I went to the front right. No leaks, but some pressure. Ordered new rears from C&G and will be here Monday.
Getting 3” of snow here today so I may not be able to start on the rears.
Thx all......Mike
mike42 is offline   Reply With Quote
Old 11-01-2020, 02:23 PM   #10
JSeery
JSeery's Avatar
Thx all......Mike
Sounds like progress, but something is still not correct. Bleeding brakes should not be that big a deal at all.
Old 11-01-2020, 01:27 PM   #11
1931 flamingo
1931 flamingo's Avatar
RIGHT rear, LEFT rear, LEFT front, RIGHT front. JMO
Paul in CT
Old 11-01-2020, 04:51 PM   #12
19Fordy
19Fordy's Avatar
Originally Posted by 1931 flamingo View Post
right rear, left rear, left front, right front. Jmo
paul in ct
Nope! RR, LR, RF, LF
Probably just a typo.
Old 11-01-2020, 06:38 PM   #13
Max
Thats not how we do it "Down Under"
Max is offline   Reply With Quote
Old 11-01-2020, 08:07 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Is this how y'all do it "Down Under"? DD
T5 W/TORQUE TUBE
Old 11-01-2020, 03:08 PM   #15
FortyNiner
FortyNiner's Avatar
It shouldn't but some of the struggles are familiar. Without speed bleeders I messed around for weeks.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 11-01-2020, 06:46 PM   #16
glennpm
glennpm's Avatar
Start with wheel cylinder farthest away from the master cylinder and end at the closest.
Old 11-01-2020, 09:07 PM   #17
19Fordy
19Fordy's Avatar
I think it would help future generations if we again taught auto mechanics in our high school shop classes. All this "needless bleeding" would stop.
Old 11-01-2020, 09:38 PM   #18
Talkwrench
Talkwrench's Avatar
Damn that would make it so much easier!
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 11-02-2020, 05:00 AM   #19
mike42
mike42's Avatar
You guys are beautiful !! LOL
The only reason I went from right rear to right front is that I already had jack stands set up on both. Too lazy to take jack stand down and use at left rear. Plus it was 25º out yesterday with 45 mph wind gusts !!
We got 4" of snow yesterday and we're now going to be in the 50's and 60's later this week. Unreal and stupid, but...that's Michigan weather. I'll be back at it again this week some more.
I know this shouldn't be this tough to do, but when you've never done it before it's not all that easy.
Thx all....Mike
Old 11-02-2020, 10:00 AM   #20
19Fordy
19Fordy's Avatar
Mike42:
Here is the correct order for bleeding drum brakes starting with the wheel farthest from the master cylinder and then bleeding each of the other wheels in decreasing distance order from the master cylinder.
1.Right Rear 2. Left Rear 3. Right Front 4. Left Front
Bleeding Process
Begin at the wheel furthest from the driver and proceed in order toward the driver. (Right rear, left rear, right front, left front.) While the actual sequence is not critical to the bleed performance it is easy to remember the sequence as the farthest to the closest. This will also allow the system to be bled in such a way as to minimize the amount of potential cross-contamination between the new and old fluid.
