#41 | |
![]() You're right. The same area requires the same throw to displace the same volume. Last edited by Badpuppy; 05-29-2020 at 10:09 AM. Reason: To conceal my fuzzy thinking. |
#42 |
There is still no final decision on the speaker set itself. I'm still completely open, but I want to listen to the advice of the car hifi specialist. Www.carhifi-berlin.de takes care of the production of the kick panel and its installation including the loudspeaker.
The plan was to use a two-way system, the large speaker in the side panel under the tank. The tweeters in the corners above the windscreen. |
#43 |
@DRG-ler Note my edit above. Best to consult the pros.
#44 |
Is everything ok.
