Old 05-23-2020, 11:55 PM   #41
B-O-B
B-O-B's Avatar
Default Re: white steam from breather and water tailpipe
Looks like head gasket to me.
B-O-B is offline   Reply With Quote
Old 05-24-2020, 12:14 AM   #42
Rfd456
Long block. It’s go cat. I told him and he’s not really interested. Would coolant get into the oil if I had a bad head gasket?
Rfd456 is offline   Reply With Quote
Old 05-24-2020, 12:16 AM   #43
Rfd456
Also. I pulled my lower hoses off and only the drivers side of the engine drained. The passenger side is still full of coolant. Could the passages be clogged?
Old 05-24-2020, 12:19 AM   #44
Rfd456
Here are a couple more photos of the cylinder in question
File Type: jpeg E0A1E9EC-0062-4EE9-B60C-C6B5683F43CE.jpeg (26.6 KB, 92 views)
File Type: jpeg 96C5A8C7-BBF8-4E1F-9E8D-615C68E2206A.jpeg (22.5 KB, 83 views)
Old 05-24-2020, 12:19 AM   #45
Tinker
Tinker's Avatar
Well go cat go dadeo.
No, less the rings were bad and you had a leaky headgasket. or a crack.
Milky oil??? You never mentioned the bore?
Old 05-24-2020, 12:19 AM   #46
Rfd456
Head gaskets are Best. They look perfect
Old 05-24-2020, 12:21 AM   #47
Rfd456
My new oil turned to mayonnaise just doing a compression check on the motor
Old 05-24-2020, 12:25 AM   #48
Tinker
Tinker's Avatar
You might have a internal issue. Sorry
Buy a set of new gaskets for 30$ and run them out. If it's still the same, well. Cheaper then a new rebuild at this point. If still bad, well... 30$ is the least of it.
Still strange you have decent compression? Might want to a leak down or name the builder.
Old 05-24-2020, 12:40 AM   #49
flatheadmurre
flatheadmurre's Avatar
If the coolant doesnīt drain there must be a serious clogging in the pump or something...
At this point some kind of "block bandaid" aproach comes to mind...not much to loose if you have a crack..
Whatever you descide donīt run the engine with water in the oil for any extended period of time.
I would pull the pump where coolant donīt drain and check whatīs going on.
Then caustic cleaner in the block to get rid of oil...a lot of flushing...evaporust for whatever rust is left...a lot of flushing...block sealer !
Done right this wonīt hurt your internal engine parts and may save the block...if not itīs mostly your work involved and not to much money.
Fingers crossed you can save the block...
Old 05-24-2020, 12:45 AM   #50
Rfd456
thanks a lot. I will try this. Could this be an issue that cause all these problems I am having?
Old 05-24-2020, 12:53 AM   #51
Tinker
Tinker's Avatar
Try a new overbore best gasket and spray tac it. Then go from there.
A block sealer may work too. Not that you spent 9k on a rebuild.
You may will still have issues. It's life dude.
Old 05-24-2020, 12:53 AM   #52
flatheadmurre
Start by getting the coolant passages clear...get pump off...check that the block has been cleaned in the waterjackets.
One step at the time verifying what has been and not been done.
Old 05-24-2020, 12:54 AM   #53
flatheadmurre
You will still have issues. It's life dude.
If the coolant doesnīt drain out of one blockside adressing the coolantflow first maybe ??
You are way to fast here man
Old 05-24-2020, 12:56 AM   #54
Tinker
Tinker's Avatar
You also. I edited my post as you were posting Still hopeful a gasket change might do it. Milky oil is subject. Think not
I'm going off this is a total rebuild. Clean tested block.
Old 05-24-2020, 01:02 AM   #55
flatheadmurre
But as i read it coolant is still in one side of the block after bottom hoses was removed ?
That means there is a serious blocking in the pump or block on that side...that must be adressed before anything else.
Old 05-24-2020, 01:05 AM   #56
Tinker
Tinker's Avatar
I agree. I think there is a lot of issues going on here for a rebuild. They keep changing. One thing at a time would be my suggestion. I might think the block was never cleaned or checked (for a rebuilt block).
Old 05-24-2020, 01:09 AM   #57
Rfd456
Ill be pulling off the pumps tomorrow and will post results. I am at a total loss for words. I WAS a total rebuild. I will post the receipt for the motor.
Old 05-24-2020, 01:15 AM   #58
Tinker
Tinker's Avatar
Water pumps aren't putting water in the cylinder, one thing at a time. Only way water gets into the combustion chamber ever is a head gasket or a crack. Best of luck.
Old 05-24-2020, 01:21 AM   #59
Rfd456
Here is the receipt for the rebuild
Old 05-24-2020, 01:23 AM   #60
Tinker
Tinker's Avatar
I'm not clicking on a pdf nor should anyone here. Besides it doesn't matter. Best of luck!!!
