Old 01-26-2020, 01:27 PM   #1
tubman
tubman's Avatar
Default Re: 8BA doesnt have power
From what I remember, 8BA carburetors did not have a "spark valve" (that thing that looks like a power valve that screws into the carb base). That is on later carbs (2100's and 2110's). If you do have one of those, it should run fine, if it has the proper distributor vacuum.
Old 01-26-2020, 03:30 PM   #2
flatjack9
flatjack9's Avatar
Correct. The 8BA carbs do not have the spark valve in the base.
Old 01-26-2020, 02:43 PM   #3
FlatheadTed
FlatheadTed's Avatar
Try what Chap 52 says (,Valve timing ),,remove a spark plug and look at the position of the valve you should be able to see the inlet valve ( I think ) and what's its position in relation to the TDC mark, .You could also pull the front cover to check the marks .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 01-26-2020, 05:38 PM   #4
FlatheadTed
One other thing to consider if you have run it with old fuel it can coat the plugs even with fresh fuel in it ,we had a 29 Dodge in the shop it was missing we did everything ,it sounded like a carb issue bolted the carb up to a 26 Chev it ran fine so that eliminated that , put new plugs in it and Bingo !
Old 01-27-2020, 12:21 AM   #5
Art Newland
Art Newland's Avatar
When I swapped the engine into my F1, I ended up with a coil/external resistor miss-match that wouldn't allow it to pull hard or rev above approx 2500 rpm. Acted just like a fuel starvation issue. I by-passed the resistor and all was good. I now use the blue Bosch that Bubba recommends.
"whatever works!"
Art Newland is offline   Reply With Quote
Old 01-28-2020, 06:59 PM   #6
trentclark
trentclark's Avatar
ill be checking back in when weather gets better to do more work. I did pm CharlieNY to see about a carb rebuild.
I have (4) 94 carbs but only one is rebuilt. All have the same base with AA-1 on it. and dont see any valve or other component on them. Ill pull the cover and head and make sure the timing is correct. Im an punctilious re-builder and if I got this off, its major confession time.
trentclark is offline   Reply With Quote
Old 01-28-2020, 07:12 PM   #7
trentclark
trentclark's Avatar
Art, I have a Napa IC14 coil which is internally resisted. I have a flamethrower that I might put on it just to see if the coil or its internal resister is bad. thats something I have not checked yet. thanks God Bless
Old 01-29-2020, 12:37 PM   #8
JSeery
JSeery's Avatar
Believe the Flamethrower coils come in both 1.5 & 3.0 ohms, so you would want to check and see what it is.
Old 01-29-2020, 04:27 PM   #9
FlatheadTed
Just check that you don't have the early inlet manifold were the heat riser hole lines up with the 94 ,
Old 02-03-2020, 04:32 PM   #10
trentclark
trentclark's Avatar
Flathead Ted, what does "check that you don't have the early inlet manifold were the heat riser hole lines up with the 94" mean.
I did swap intake manifolds with this rebuild but still have the old one. what do I look for? I don't know what the heat riser hole will look like. Thanks for the help, God Bless.
Old 01-29-2020, 10:12 PM   #11
Tinker
Tinker's Avatar
Yeah the flame thrower is not going to help you on a standard dizzy. Backup and fix one thing right at a time. Not a big deal till you start driving it a while.
If you want the vac advance, look at charlie to do your carb and dizzy.
If you want mechanical advance, charlie or bubba can do that. Skip on coil. including cans.
Surrender and let them set it up. It's a good starting point, till you find someone local or even then. Sometimes it takes time. I'm a fan of starting and running stock first, then mod.
Old 02-03-2020, 04:46 PM   #12
Mart
Mart's Avatar
See that hole half way between the two front carb studs? You don't want an intake with that hole if you are running a 94.
Mart.
Old 02-03-2020, 05:22 PM   #13
trentclark
trentclark's Avatar
Mart, thanks! ill check it out.
Old 02-03-2020, 10:57 PM   #14
trentclark
trentclark's Avatar
can someone help me post photos? thanks.
Old 02-03-2020, 10:59 PM   #15
Tinker
Tinker's Avatar
https://www.fordbarn.com/forum/showt...dding+pictures
Old 02-03-2020, 11:53 PM   #16
trentclark
trentclark's Avatar
testing
Old 02-03-2020, 11:54 PM   #17
trentclark
trentclark's Avatar
Hey it worked. nothing to see here just testing. Thanks Tinker!
Old 02-06-2020, 12:01 AM   #18
trentclark
trentclark's Avatar
mart, flatheadted, no heat riser hole. stock manifold doesnt have one. something stupid is going on. ill keep tinkering.....
BTW, I dug up the old 94 that I had on it as a teenager and drove this truck all the time. it has a hole drilled in the carb above the accel pump plunger. not sure who did this, wasnt me but it ran like a champ. is there a reason to do this. Here is a photo.
Old 02-06-2020, 09:33 PM   #19
Art Newland
I just assembled a "Franken-Holley 94" for the engine on my stand and it had that hole in it also, It was a "EC" model.
"whatever works!"
Old 02-06-2020, 12:06 AM   #20
trentclark
trentclark's Avatar
I have a goodguys event comeing up in March. I have to drive this to the event regardless. ill push it if I have too. God Bless. thanks for your help.
I have not heard from CharlieNY or Bubba. I hope they are doing fine. I want to visit these guys fairly soon and see what they do. I can spend some time with them and want to carry on their knowledge. let me know if you hear from them.
