Old 10-05-2019, 01:05 PM   #41
Ross F-1
Ross F-1's Avatar
Default Re: Replace Flathead with Y-Block?
Believe it or not, Ford actually made an adapter to do this for trucks. They also made a kit to convert from the flat-6's to the OHV 6's. The parts lists for the kits runs to 2 pages...
Never seen one of these adapters myself.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-05-2019, 01:10 PM   #42
skidmarks
skidmarks's Avatar
I have the same book, also never seen one in all the junkyards I've walked through.
We did have a 54 F600 that was.converted from a 6 wheeler to a 10 wheeler full screw
skidmarks is offline   Reply With Quote
Old 10-05-2019, 01:41 PM   #43
philipswanson
The 312 wasn't any better. It was the worst of the bunch. The 292 was lousy but probably the best Y block. The 57 312 introduced the Holley spread bore carburetor which was a milestone but a terrible overall engine. The engine code was ECZ. I know, I had several back in the day.
philipswanson is offline   Reply With Quote
Old 10-05-2019, 04:28 PM   #44
Ol' Ron
Ol' Ron's Avatar
In the late 50's I built a 345ci "Y" block for the drags for a fellow. The engine had a C&T stroker assy with floating bearings. The roda were bored out to except them. Yes it was a welded crank. Clay smith hard faced cam and Hilbore Fuel injectors. I'd never run anything like this before and my stupid factor was very hi. Took awhile to get the tuning figgered out. The flame thrower ign gave us problems as the rotors would short out. solved this with stock coils. Engine was bolted uo to a cad.LaSal trand and 4.10 rear, Altho we never got it to a drag strip. It's the only vehicle I ever drove that could spin the tires while cruising at 60 mPH. The acceleration was more thar the Hemi 66 Dodge I ran
Yes if you put the time and money into one, they wii run
Old 10-05-2019, 04:30 PM   #45
A bones
A bones's Avatar
Originally Posted by DougE View Post
A Bones - I am posting identical threads in the H.A.M.B. 1952-59 Ford Social Group and not getting much response.
Doug this is good to know. Since I came off strong I apologize. You are getting a load of good input here. I'm sorry to say I'm in the agin camp.
As well, I have in my growing years committed conversions that just ate up time energy, and cash I regretted later.
Good Luck I understand the aspect of having that look when the hood goes up.
(seldom mentioned fact: Ed 'Big Daddy' Roth had a '55 Chevy with a 406 just for fun)
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 10-05-2019, 07:57 PM   #46
Newc
Newc's Avatar
Well;the latest V8 times has photos of the '49-up passenger bell housings and includes the '54-56 Y block bell housings! Looks like the same passenger trans pattern to me. Newc
Old 10-05-2019, 08:03 PM   #47
tubman
tubman's Avatar
Most adapters for these transmissions show them fitting '49-'64. "rotorwrench" has posted some good information on the previous page.
Old 10-05-2019, 11:33 PM   #48
40 Deluxe
looks like a pretty complete kit. It even includes the engine!
Old 10-07-2019, 01:11 PM   #49
Henry Floored
Henry Floored's Avatar
Hey Philip, I know you don’t care for the Y-block and you have your reasons but I must say I’ve never seen a Y block pull a press in rocker stud or have an oil leak at the corner of the intake like the kind that were invented with the advent of the small block chevy.
A Ford Y block beat out two small block Chevys a Pontiac and a Studebaker V8 at last weeks Engine Masters Competition. It finished behind a 390 and 289 Ford and a couple big block Chevys with the latter two only beating it by a little.
Remember this year the engines were required to run factory block and head castings.
Ford Y blocks have won this competition twice. No early Olds, Caddy, Buick or small block Chevy has accomplished that feat yet.
Henry Floored is offline   Reply With Quote
Old 10-07-2019, 02:11 PM   #50
tubman
tubman's Avatar
I always liked "Y"-blocks, especially the intake ports.
I always thought the 312's were the best of the bunch, too.
Old 10-07-2019, 03:49 PM   #51
40 Deluxe
Well, actually, that '57 Holley was a square bore. The Holley spread bore didn't show up until much later, as a replacement for spread bore carbs like the Quadrajet or the Carter Thermoquad or the Autolite 4300 or the Motorcraft 4350. Although at least the 4350 had a different bolt pattern.
Interestingly, the '57 312 also used Carter AFB and Ford/Autolite 4100 carbs.
It was the first year for these carbs too.
Old 10-07-2019, 08:16 PM   #52
Henry Floored
I’m glad you said that Tubman. I used to scratch my head when I first saw them. Then I thought about it........
I realized the valve seat (width of the valve) is in line with the wide dimension of the port. Thinking about it even further if you had two situations where you were pouring water over a ledge which way is better? In the case of the conventional vertical port the “fluid” is pinched in the minor width of the port then has to flare out to be able to flow around the valve.
In the second case the horizontal port in the Y block has the major intake port dimension in line or parallel to the entire periphery of the intake valve. The “fluid” column is NOT pinched and therefore it’s my opinion that at least theoretically this is a superior configuration.
Look at a modern 4 valve engine and tell me what you see looking down the intake port. Answer: generally you’ll see a horizontal and “in line” major port dimension.
Maybe just maybe the Y block is the only common 50’s engine that got it right.
Old 10-08-2019, 07:43 AM   #53
richard crow
like it or not the small block chevy is the best choice . light small ez to install & you can buy a eng much cheaper than any other eng. ps they don,t over heat
richard crow is offline   Reply With Quote
Old 10-08-2019, 08:15 AM   #54
tubman
tubman's Avatar
Plus, used adapters are everywhere. I paid $10 for the last one I bought.
Old 10-08-2019, 09:36 AM   #55
DougE
I've already said at least twice I'm keeping it all Ford. Suggesting some other brand is just a waste of space. Anyone else checking out this thread to find out the options for doing what I'm trying to do now has to wade through a bunch of non-useful information.
1952 Ford Customline 4Dr
New Braunfels, Tx
DougE is offline   Reply With Quote
Old 10-08-2019, 01:47 PM   #56
Zeke3
Zeke3's Avatar
A friend of mine is installing a Y-block in a 1940 Merc convertible street rod. He is planning to cut a pretty wide diagonal trough in the dash panel (aka firewall) for distributor clearance. Not sure if you would have the same issue with the '52 body.
Zeke3 is online now   Reply With Quote
Old 10-08-2019, 02:07 PM   #57
Mart
Mart's Avatar
Re top end oiling on the Y blocks. My T bird had no oil to the rockers on one side. The problem was worn cam bearings. New cam bearings were fitted and the oil problem was solved.
Mart.
Old 10-08-2019, 02:08 PM   #58
Tinker
Tinker's Avatar
Might want to check out Tim's page
http://yblockguy.com/
If you want to watch videos
https://www.youtube.com/user/mctim64
Sorry this does not help your question on installing a yblock, but some yblock info.
Old 10-08-2019, 06:14 PM   #59
Ford Freak
The sbc is a terrific engine , but it has its places . Those are in GM products .
The best way to ruin a Ford is to put a Chevy engine in it . Works every time ! LOL
Ford Freak is offline   Reply With Quote
Old 10-08-2019, 06:26 PM   #60
19Fordy
19Fordy's Avatar
Richard makes a good point. I recall in 1961 I had a 40 Ford with a 265 SBC and it ran great with zero problems. Didn't ruin the car at all. Just think of all the old Fords that were "ruined" with 331 Hemis, Olds Rocket 88's and Cadillac engines.
