Old 05-11-2018, 06:59 AM   #41
JSeery
JSeery's Avatar
Default Re: Engine problem or normal?
Originally Posted by 1stford View Post
Just an update on my current situation. I pulled the heads and the block is cracked. Defiantly not he news I was looking for.
Where is the crack, can you post a photo?
Old 05-11-2018, 08:33 AM   #42
1stford
1stford's Avatar
Middle top of driver side.
File Type: jpg 54A21CFC-44D6-4611-A1F4-5ED567B8486E.jpg (38.4 KB, 38 views)
1stford is offline   Reply With Quote
Old 05-11-2018, 08:43 AM   #43
Mart
Mart's Avatar
While not ideal, a crack in that location (and other stud to water jacket) locations are not considered job stoppers.
Mart.
Old 05-11-2018, 09:14 AM   #44
tubman
tubman's Avatar
Although I have never seem a crack there (my "part number" cracks are always in their usual location), I agree with "Mart" that that particular crack is not a "game-stopper". While I'm no expert, I wonder if the installation of a quality thread insert ("Keen-Sert". "EZ-Lok", or some such)may not be a good idea.
tubman is online now   Reply With Quote
Old 05-11-2018, 12:15 PM   #45
1stford
1stford's Avatar
Maybe I could get more specifics on this. I’m ready to pull it and trash the block because I thought it was no good do to this issue. I’m getting exhauste gas into the cooling system, motor is in truck and didn’t think I had other options?
Old 05-11-2018, 03:58 PM   #46
Mart
Mart's Avatar
Maybe it is a job stopper, then, do you think the crack goes all the way into the exhaust port? It's hard to offer definitive advice via the computer without seeing the parts first hand and discussing with the person with the problem. I wonder if it would be worth rigging up for a pressure test??
The post above is the first mention of exhaust in the coolant.
Mart.
Old 05-11-2018, 04:36 PM   #47
flatheadmurre
flatheadmurre's Avatar
Under the deck the material is round and then becomes the exhaust runner.
Not to uncommon that deck and exhaust splits when it cracks in the thin part around the stud...and exhaust is coming up into the coolant. That can be fixed with a longer stud or thread insert.
If the cracks showing goes straight all the way down into the exhaust it´s more of a challenge.
Old 05-11-2018, 05:15 PM   #48
flatjack9
flatjack9's Avatar
I don't know if I would rely on the exhaust gas test. I had a friend who had a positive test. He removed the engine and tore it down to build a new block. I pressure tested the old block for him and found no problem. I rebuilt the engine and it has been running for 2 years with no problems.
Old 05-18-2018, 07:03 PM   #49
1stford
1stford's Avatar
I know this a question that really can’t be answered but the above message causes me to worry about pulling the motor. I’m at a point now where I’m ready to pull it out and go through it. Before I do has anyone had any experience like I listed above when they were running no thermostats? Didn’t know if not haveing them in, and there being no restrictions would cause guild to overflow when I give it gas at idol?
Old 05-18-2018, 07:49 PM   #50
FlatheadTed
FlatheadTed's Avatar
I don't think the little coolant lose is a issue ,they do drop a little as has been said you should be focusing on if its over heating or not ,its not wise to pull a motor to bits with out doing some testing, you put a catch can on the tube and see how much you get .A thermostat can add to your problems not nessarly help .The oil pressure I have a simler problem on a merc block, 5 at idal 15 at revs , so Manual gauge goes on next ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
