Old 12-15-2017, 11:05 AM   #41
fortyfords
fortyfords's Avatar
Default Re: Temp Heat in Garage
I have used the jet type job heaters, big draw back is that they are very loud, kerosene really stinks, propane isn't that smelly but will get to you after 8 hours. Barrel stoves are cheap to set up and use if you have a good wood supply but on windy days you can get smoke fumes coming in. I have used one of those infrared overhead heaters but they must be used in a well insulated room to work good.
fortyfords is offline   Reply With Quote
Old 12-15-2017, 12:15 PM   #42
38bill
38bill's Avatar
FYI: Another thing to consider. Burning one gallon of LP or nat gas produces almost 1 gallon of water vapor. If you are using a vent-less heater you are adding a lot of moisture into the building.
38bill is offline   Reply With Quote
Old 12-15-2017, 12:34 PM   #43
Pat/Ohio
Pat/Ohio's Avatar
Originally Posted by carguybill View Post
I considered many options and ended up with an overhead heater, propane powered. Very happy with it. good insulation in walls and overhead help a lot to keep the operational costs down.
Attachment 342712
Attachment 342713
Rick, I use this same Reznoir propane heater. Hangs out of the way in the corner. You can see part of it hanging in this picture. My garage is 28' x 24', insulated. I keep the temp around 50 degrees when I'm not in there and around 65 degrees when I'm working in the garage. Cost me around $1,400 with installation and around $250 a year for propane. Not bad. I have had it for 10 years or so with no problems. Pat
Pat/Ohio is offline   Reply With Quote
Old 12-15-2017, 01:36 PM   #44
Johnnydidd
Johnnydidd's Avatar
I installed a heat-air conditioner unit works great in all seasons, cant remember size but runs off 220 volt, keeps very comfortable had it for 4 yrs I think I paid $600 to $700 for it
Johnnydidd is offline   Reply With Quote
Old 12-15-2017, 03:06 PM   #45
paul2748
paul2748's Avatar
I really take exception to them being "dangerous'. If you were standing four feet from the unit there's no way your pants can catch fire. If I'm a foot away from the unit I can't feel any direct heat from the unit My unit is about 12 inches from the side of the garage and the side does not get hot at all. There is no flame other then inside the unit.
Originally Posted by tubman View Post
"Construction Heaters" (such as shown in Post #33 above) can be quite dangerous. I had one and I was working in my shop, about 4 feet from the heater with my back to it. I had blue jeans on and they had a small, frayed, hole in the back of my calf. All of a sudden, I felt extreme heat on the back if my leg, and found my pants were on fire. Frayed cotton is one of the most flammable materials there is (Boy Scouts use it with their "flint and steel" fire starters). The end result is that the back of my leg was badly burned and it took two months and a skin graft to recover. I never used that heater again and sold it shortly thereafter. Because of their very nature, these thing throw a tremendous amount of heat and can start anything close on fire. I wouldn't have one (obviously).
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 12-15-2017, 04:41 PM   #46
RalphM
RalphM's Avatar
All depends on how close you are, I saw a guy one time trying to warm his “back side” on one of those propane heaters after he came in from the cold here in Alaska. After about five minutes he caught fire! I was laughing so hard it was tough to help put it out!
RalphM is offline   Reply With Quote
Old 12-16-2017, 08:49 AM   #47
ricklove
ricklove's Avatar
As a combined unit; for that kind of money, I'd prefer to do both at one time. Can you get me the unit manufacture, name, size, etc? Many thanks!
ricklove is offline   Reply With Quote
Old 12-16-2017, 10:08 AM   #48
tubman
tubman's Avatar
That's nice to know that this didn't happen to me. Still hurt a lot though. Those things are known as "Construction Heaters", not "Garage Heaters" for a very good reason. I will agree that they are cheap and throw a lot of heat, and perhaps OK for "temp heat", but I'll never use one again. Please be careful with yours. Good luck.
tubman is online now   Reply With Quote
Old 12-16-2017, 10:14 AM   #49
tubman
tubman's Avatar
Since I'm stuck in Minnesota for the winter, I decided to buy a 17,000 BTU infrared electric heater to quickly warm my work area. It does this quite well and was not too expensive ($109.95). It does have some disadvantages; first, it needs a 30 AMP 220 volt outlet. Luckily, I have one of those for my welder. The second problem will probably make itself evident when I get my first electric bill. The knock on electric heat has always been the cost; I'm sure I'm in for a dose of reality soon. Oh well, hopefully it's only for this one year.
Old 12-16-2017, 10:39 AM   #50
SofaKing
SofaKing's Avatar
I used a $10 infrared lamp in $9 reflector socket over my workbench and a pair of coveralls. Keeps your hands/front and small workbench area warm and provides extra light. I also moved it around for working in the cab or under the car.
SofaKing is offline   Reply With Quote
Old 12-16-2017, 11:10 AM   #51
Drbrown
Drbrown's Avatar
Electric heat source always the most expensive. Kerosene, even K-1, does not burn completely and deposits an invisible soot in the space (I know this well).
Don't use anything that obtains combustion air from the garage itself. Compared to other gases, gasoline and LP gas fumes are heavier than air and settle to floor level which is why most building codes require a garage attached to to house have its floor level at least 18 inches below the floor level of the house.
Drbrown is offline   Reply With Quote
Old 12-16-2017, 11:36 AM   #52
tubman
tubman's Avatar
After what "DrBrown" said, I will add again that I have a Carbon Monoxide/Gas Fume detector that plugs into a convenient outlet. It's cheap insurance (though they can be annoying if you want to do "just a short test run" of your car).
Old 12-16-2017, 11:54 AM   #53
5851a
If you have the electricity for it they do make small electric hanging furnaces. You would want insulation though. I use a hot dawg hanging but have natural gas since in town. To late for in floor heat but next time, I do remember froze toes.
5851a is offline   Reply With Quote
Old 12-16-2017, 12:33 PM   #54
tubman
tubman's Avatar
Having experienced it several times, I will agree with the assessment that in floor heat is the best way to go. However, it is about the farthest thing you can get when discussing "temp heat".
Old 12-16-2017, 02:48 PM   #55
Mtn Wudy
Mtn Wudy's Avatar
I’m right in the middle of “Garage Heat 2017”......
100 feet of gas line trench dug 18” deep.....
Pipe in and held pressure for a week...
Air return plenum built...filters ordered....
Furnace mounted,ready to get the sheet metal guy out here on Monday...
Last winter it was no fun trying to get anything done when the shop was 36 degrees ....
File Type: jpg 181D2DF2-4A01-452C-A49D-0B418AEA47CD.jpg (54.0 KB, 35 views)
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is online now   Reply With Quote
Old 12-16-2017, 02:49 PM   #56
Mtn Wudy
Mtn Wudy's Avatar
Now,,,,how did that happen...????
You get the idea anyway.....
Old 12-16-2017, 08:13 PM   #57
Ardun
Ardun's Avatar
I cut a hole in the heater ducting and put in closable vent. Works great in winter and summer for a 4 car garage.
Ardun is offline   Reply With Quote
Old 12-16-2017, 11:25 PM   #58
Drbrown
Drbrown's Avatar
Some low(er) heat/power consumption ideas:
If one has a hot water circulating home heating system it could be relatively easy to extend a supply and return piping to a garage area, incorporating shut-off and diverter/balancing valves .... however don't allow the water in the pipes to freeze. Hot water heating systems normally have a 15 lb or adjustable water pressure reducer at the boiler. This would work well with a ceiling suspended heating unit with electric fan and thermo control. Design your own device .... Got an old car radiator and electric fan ?
Not as good .... with a ducted home heating system a supply air duct might be extended to a garage, with shut off/volume control damper, but one would NOT want a return air duct as that could return contaminate air circulating inside the home.
Best idea .... put an old semi-worn-out but functioning flatie or diesel outside next to the garage with a small fuel tank. Use some steam hosing (sold by the foot) to connect it to its/a radiator inside the garage, and place a portable 24' box fan to blow air thru the radiator. Fill the flatie with antifreeze. Listen to its music as you work. Tell the wife to wear ear muffs. Idling the engine not good but its like putting a race horse out to pasture.
Old 12-17-2017, 09:30 AM   #59
Johnnydidd
Johnnydidd's Avatar
ricklove
i have unit mounted 6 ft off floor couldn't find model number it was built by Frigidaire, you should be able to buy at Sams its the largest unit they make for heat/air
Old 12-17-2017, 10:38 AM   #60
RalphG
RalphG's Avatar
I have an old oil furnace from a home in the shop where I work on stuff. It can get the temp up well into the workable range for me. I don't use it a lot. I have to be pretty inspired to get out there some days when its in the minus 20s outside. Also got a space heater. One of those "rocket" deals that burns anything from kerosene to tractor fuel. I'll use it in the big , well ventilated machine shed some. In a smaller, less ventilated shed it produces enough exhaust to make your throat burn after a while. They tell me kerosene burns a little cleaner.
RalphG is offline   Reply With Quote
