Old 11-29-2018, 07:21 PM   #41
1927Tudor
1927Tudor's Avatar
Default Re: 1952 F-1 Project
Thanks gents....
The frame was sandblasted and painted with a product that is used locally by a company that sandblasts and paints semi trailers and other big pieces.... picture attached...
File Type: jpg 68B19B1D-C372-451B-A24D-F32AC23384D5.jpg (39.6 KB, 62 views)
1927Tudor is offline   Reply With Quote
Old 11-29-2018, 08:31 PM   #42
tubman
tubman's Avatar
"Acrilithane"? Wow! That must be some good stuff!
Old 11-29-2018, 11:31 PM   #43
1927Tudor
1927Tudor's Avatar
It’s almost like a ceramic coating when it’s dry...
Old 11-30-2018, 10:10 AM   #44
Ol' Ron
Ol' Ron's Avatar
20 years ago I helped a fellow rebuild a 52 PU. He was a good body man and painter, so the cab and bed came out great. I put a 302/C4/3.08 in it and it was a great driver. got good gas mileage. After a year or so he came to me and said driving this thing is like a truck. The steering is hard. I checked out the steering box and had the frint end aligned. It wasn't out much. Yes it didn't steer vary good. so I installed a Mustang IFS and he was very happy. The truck was called Peaches
Old 12-06-2020, 01:52 AM   #45
Mark in Japan
Looks Great!
Any updates?
Mark in Japan is offline   Reply With Quote
Old 12-08-2020, 03:28 PM   #46
mercman from oz
mercman from oz's Avatar
You are certainly doing a great job with the restoration of this neat old 1952 Ford F1 Pick-Up.
Look forward to seeing more pictures. Keep up the great work.
Old 12-08-2022, 08:00 PM   #47
1927Tudor
1927Tudor's Avatar
Well, it’s been a few years since I posted…. Here are some pictures of the last 4 years…..
Old 12-08-2022, 08:05 PM   #48
1927Tudor
1927Tudor's Avatar
And some more…
File Type: jpg BC038E58-0550-4F12-917F-A412FBA1241E.jpg (47.6 KB, 25 views)
File Type: jpg 711906E0-8440-4746-9FD7-146436D6AC02.jpg (49.8 KB, 23 views)
File Type: jpg 11FDA352-D62A-44B7-BC5F-CDD0B10BA620.jpg (36.9 KB, 27 views)
Old 12-08-2022, 08:11 PM   #49
1927Tudor
1927Tudor's Avatar
And now a question….. I can’t find any information on installation of the ignition housing and tumbler assembly. The truck didn’t have one when purchased… the spring loaded housing fits into the dash, the tabs line up with the slots in the dash, but it’s a puzzle as to what holds it in place. It will not rotate at all. The bezel fits over the tabs, but it too does not rotate…. Anyone have an idea? Thanks…
Old 12-09-2022, 02:22 PM   #50
TJ
TJ's Avatar
As I recall you push the switch forward enough to get the bezel installed and the spring pulls it back in place. The bezel is bigger than the hole and it holds the switch in place.
Old 12-09-2022, 02:58 PM   #51
petehoovie
petehoovie's Avatar
Somewhere in the woods...
Old 12-09-2022, 08:45 PM   #52
1927Tudor
1927Tudor's Avatar
Solved! The repop bezel needed gentle encouragement with pliers in order to open the gap enough to allow it to rotate enough to lock.
File Type: jpg B139CCC9-6039-4BE3-A347-BF8BDD123B6F.jpg (66.1 KB, 30 views)
Old 12-09-2022, 09:58 PM   #53
petehoovie
petehoovie's Avatar
