#41 |
He probably has more than one drawing a little current. If I remember, he doesn't get a light with them all in, only a little spark. With us not knowing the amp draw or voltage between the post and lifted cable, I'm with the bad battery opinion.
#42 | |
#43 |
Sorry for confusion...just take the cable off the battery and measure between cable and battery with all fuses out first.
If you get a reading there we take it ffrom there. If not measure over each fuse holder until you get a reading somewhere. |
#44 |
Gotta remember.......a few of our F'Barn friends are in far-away places, and although "WE" talk funny sometimes over here, some of those guys use "proper terms" at other times that we haven't learn't yet. DD
#45 |
36tudor>>>Electrical drain, battery won't maintain charge? >>>
OK. Here are 2 easy questions related to the battery itself. (1) With the battery cables connected, how long does it take for the battery to drain so it won't turn over? (2) With the battery cables disconnected, how long does it take before it won't turn over? Jack E/NJ |
#46 |
Jack E/NJ has suggested an interesting test that I have yet to try. |
#47 |
I don't see where you've ever fully tested the battery with the equipment at an auto parts store to see if it's defective. You may be chasing something other than that simple problem that could be diagnosed in a few minutes at the store.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
#48 |
Have found the best way (for me) to check flow/drain in wires is an induction ammeter such as this. Starting with the battery cables and each individual circuit you can check the drain down in the system down to the miliamp.
But of course if the battery is bad it's just a waste of time.
#49 |
Now that it's a little warmer and feeling somewhat limber I will drag the battery out from behind the backseat and get it tested.
#50 |
There may be no need to drag it out. If you can drive the car to the store the guys will bring the gadget out and hook it up to test it right where it is. I do it all the time.
#51 |
Thanks Henry, didn't know they could do that!
#52 |
Took the car over to AUTOZONE and had the battery tested, the opinion was the battery was good, showing 84%. Never could find a drain, will flip master breaker to the off position at the end of the day and preserve the battery for the next day.
