Old 09-05-2016, 04:43 PM   #41
psogden
Default Re: Difficulties installing & torquing rear drum - Help!
Again, appreciate all the comments from you all. 3 more better pictures attached after further cleaning axle. I do have one of those Blue Point "thread fixer" tools which works like cutting a nut in half, etc. Will use it on the axle. Think John has it right in suggesting the "give it another try" approach & if it doesn't hold--time for a replacement axle (we all know how easy that job is).
I keep wondering about the wisdom of the deceased and long time V-8 Club adviser, Dick Flynn, who wrote many articles on all aspects of V-8s and obviously worked on countless cars, doing everything there is to do on them. His advice on torquing axles (knowing the official Ford guidelines of 200 foot-pounds) was to torque to 150-160 FPs. He claims never to have had a failure doing this.
psogden is offline   Reply With Quote
Old 09-05-2016, 04:55 PM   #42
VeryTangled
VeryTangled's Avatar
Originally Posted by JSeery View Post
Think we are getting things a little mixed up here, JM was posting some examples of what he considered good threads would look like.
Yes, or maybe PERFECT THREADS. Yes. That.
This one, not so much. Variance in diameter and thread height. Maybe could work sorta.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 09-05-2016, 05:00 PM   #43
ford38v8
ford38v8's Avatar
I wouldn't have a problem with those threads at all. Just be sure your nuts are good!
Mr Dick Flynn has been a puzzlement to me for years. I'm sure he had forgotten more than I ever knew, but I also feel that some of his advice was questionable, which in itself puts a cloud over all his advice. That he professed that Amway products were the ultimate answer to every need was likely a big part of my skepticism, but then, I like Marvel Mystery Oil, so what do I know?
Alan
Old 09-05-2016, 05:03 PM   #44
VeryTangled
Yes, you can do that Tomorrow. You can't undo that.
-Jeff H
Old 09-05-2016, 05:46 PM   #45
34fordy
34fordy's Avatar
I may be fairly new to the Fordbarn but not to good or poor threads--Those threads in the picture look quite poor to me--I believe you will be lucky to "resurrect" them--Don
34fordy is offline   Reply With Quote
Old 09-05-2016, 05:51 PM   #46
JSeery
JSeery's Avatar
Looks savable to me.
Old 09-06-2016, 03:48 PM   #47
psogden
I am awaiting the arrival of original used Ford axle nuts before trying again with my little torqueing project. Expect them by the end of the week. Have done a lot of research on the Internet to try to locate any source for a Grade 8 5/8” – 18 slotted nut. I found nobody who carries a Grade 8. Some carry a Grade 5. One supplier told me that this nut is no longer manufactured. This leads me to the conclusion that 5/8”- 18 nuts being sold today by old V-8 Ford parts suppliers are not Grade 8 unless they are very old stock. My obvious conclusion is that the ONLY way to go is to use the original Ford nut—no exceptions. In other words, unless you have the absolute assurance that a non Ford nut is a Grade 8, don’t use it. After I explained that his nut failed, the vendor who sold me the nut that failed is removing them from stock and will no longer sell them. He was appreciative of my letting him know.
Old 09-06-2016, 06:22 PM   #48
VeryTangled
Originally Posted by ford38v8 View Post
... but then, I like Marvel Mystery Oil, so what do I know?
Bought a gallon jug that had to be on the shelf for years, thick dust. Filling my quarts. Still clueless and a dollar fewer in pocket!
-Jeff H
Old 09-06-2016, 07:14 PM   #49
Talkwrench
Talkwrench's Avatar
Isn't this good enough........?
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 09-07-2016, 05:09 PM   #50
supereal
supereal's Avatar
The correct Ford rear axle nuts are a specially hardened thick items that are to placed over a correct thick washer. No attempts to chase the threads should be attempted. If the threads are damaged, the axle must be replaced, or it is likely the end will separate and the wheel will fall off on the road. Don't put anything on the axel taper. It must be clean and dry to seat properly. We tighten the nuts with a breaker bar wrench with a pipe extension on the handle. Retighten after running the car around a hundred miles. Here is a good tip: mark the end of axle with a line to show where the cotter hole is with a file. If, after tightening, the hole doesn't line up with the slots in the nut, back off only to the next slot.
supereal is offline   Reply With Quote
Old 09-07-2016, 06:12 PM   #51
Capt Kirk
Capt Kirk's Avatar
Originally Posted by talkwrench View Post
isn't this good enough........?
lol!!!
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 09-07-2016, 06:15 PM   #52
Capt Kirk
Capt Kirk's Avatar
I've got an axle with really good threads on the end...well, the other end not shown in the pic.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Old 09-07-2016, 06:24 PM   #53
Capt Kirk
Capt Kirk's Avatar
My 14" cheater bar (pipe) is in perfect calibration, thank you.
Required torque divided by body weight gives you the required ratchet length. For axle nuts I use a 6" ratchet
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Old 09-12-2016, 04:55 PM   #54
psogden
Update. Cleaned axle threads a bit using Blue Point tool. Then, using correct 5/8” - 18 good used Ford nuts obtained from unidentified source, was able to torque both rear drums to 175 FPs. As suggested by John (JM 35 Sedan), will drive the car a bit, then add 10 FPs repeating until I reach 200. Thanks again to everybody for your input.
Old 09-12-2016, 05:11 PM   #55
JM 35 Sedan
JM 35 Sedan's Avatar
Sounds like you are off to a flying start! If I recall correctly, the nut you used before with suspect material and heat treat failed at 175 ft lbs.
John
Old 09-13-2016, 02:10 AM   #56
Mart
Mart's Avatar
Hopefully as you reach the desired figure, you will have a conveniently located slot in the nut to put the pin in. It's a pain if you've just gone past one slot and are almost 60 degrees away from the next.
Mart.
Mart is online now   Reply With Quote
Old 09-13-2016, 12:27 PM   #57
psogden
Yes, the original nut I used (non Ford--less than Grade 8) failed at 175. & I had a lot of residue from the stripped nut threads to clean off the axle--but seemingly did not cause any damage to axle threads--which makes sense if you think about it. I was careful to make sure my new nut lined up with the cotter pin hole on the axle & only needed to make very minor adjustment. The 60 degree aspect is significant, I agree.
Old 09-13-2016, 01:12 PM   #58
VeryTangled
Wow, Great result!
-Jeff H
Old 09-13-2016, 06:13 PM   #59
JM 35 Sedan
To me, it looks good enough for a circus tent peg assuming the other end is still attached.
John
Old 09-13-2016, 07:47 PM   #60
Talkwrench
Talkwrench's Avatar
Indeed! Was very happy to find a NOS to replace [Thanks Col] .
Never understood the great chunks filed or taken off the end of it .. ahh?
