#41 |
Good sentiments.
Glad you got the bearing problem sorted out. Mart. |
#42 | |
Also, you're selling this to another person - nice to know that the work you did was done well and what YOU'D want if you were the buyer. 'Do Unto Others' . . . such a simple and powerful mantra to stick too! Nice job by you . . . |
#43 |
Got the pistons, water pumps, and timing cover installed.
Does anyone have any experience in swapping the crank pulley to a '42-'48 pulley? I have a couple questions about the spacer that needs to be made for the swap. |
#44 |
You have been working on a 37 the crank is smaller diameter than the 21A double belt pulley.
#45 |
#46 |
Problem is, it doesn't seem like my distributor is indexing on my cam. It looks like the cam is in too deep for the distributor to index on it. I'm using the stock Helmet distributor, and a Isky Max-1 cam. Is this typical? is there some kind of spacer I need our something? |
#47 |
Im just guessing that your cam is made to suit the 42 to 48 distributor. As you have the earlier distributor, you will need an adapter.
#48 |
Yup, I've found what I need. Would have been nice if they told you that you needed that if you were putting the cam in an earlier engine.
#49 |
You are going to find that when you are mixing parts between years you will have some mismatch issues that you need to research. Flathead parts interchange fairly well, but you will run into difficulties if you try to just assemble various year parts without carful researching it first. Are you using good reference material (books)? This type of information should be covered in a good flathead rebuild book (the multi year type). Some suggestions I find useful are:
#50 | |
I do a lot of mixing parts, and always research it, but it didn't occur to me in this situation, because I wasn't really mixing parts. But, I'm on track now. Speaking of mixing parts, I mentioned in a previous post about making an adapter for putting the '42-'48 double sheave pulley on this engine. I've machined the adapter, and thought I'd show it here if anyone was interested. |
#51 |
Nice.
#52 |
So, I finally got this engine all together and painted. I wanted to take this opportunity to that you guys for the help and advice I've gotten here so far.
Now that the engine is closed up, I can get back to the metal work on the car. Here are some photos, I'll be sure to post a video of it running when I get there. |
#53 |
Well, I haven't been able to get much work done on my car. I was out of town for 3 weeks dealing with a family issue. But, now I'm back and excited to make some progress. Just for fun here is a photo after adding some more goodies on the engine.
#54 |
Hi Everyone, cretin, Wonderful thread. Your progress is to be commended.
