Old 05-21-2016, 06:38 PM   #41
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Default Re: Rebuilt Returned Re-Waxed Re-Attached and
Originally Posted by Cape Codder View Post
'31 Model A - Can you explain the installation of your trunk carrier. I noticed that the wood is up with the suitcase on top of that. Others I have observed the wood does not show until the trunk is removed and carrier folded up. Is this trunk carrier different then the many parts houses sell?
I turned the platform over, folds the same way but wood slats on top keep luggage more dry than sitting them down into a frame. Water collects around the edges and rots whatever is sitting "in" the frame out. When I was in the Army, we set all our equipment on top of pallets to keep it all dry, not down inside a pallet. If no one runs with any trunk or luggage, for show, slats showing when folded is fine....when carrying a trunk/luggage, eventually it will harm the bottom outside edges. Either way, it's bolted down as is my suitcase, the bag is strapped to the suitcase and around the back support bar. I carry nothing in the suitcase except fillers to keep it from collapsing, in the bag I car a car rain cover and luggage rain cover.
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 05-21-2016, 06:45 PM   #42
31 Model A
31 Model A's Avatar
If you run with or plan to run with a suitcase bolted down, it's all for show anyway, I use a long carriage bolt X4, small enough head to seat itself into the hole provided, run it through the bottom of the suitcase and then through a 1X2X the depth of the floor of the suitcase, then put an oversized washer and then the nut. Gives a secure means of support. Those case straps you see are not holding the bag to the frame, I just have the straps looking as if it does.
Old 05-21-2016, 07:29 PM   #43
31 Model A
31 Model A's Avatar
Seems like just yesterday..........
Nov 2014....
May 2016
Old 05-21-2016, 07:29 PM   #44
Ed H.
Originally Posted by 31 Model A View Post
If anyone remembers earlier photos that showed the firewall, it was full of holes...not no more.
Mine is also, how did the holes get repaired so nice. Cant tell they were ever there. Nice car, be proud, you saved a piece of history from the rodders and junk man.
If you see a bomb technician running, do everything in your power to keep up with him.
United States Navy
Ed H. is offline   Reply With Quote
Old 05-23-2016, 03:34 PM   #45
Bill in SoCal
Bill in SoCal's Avatar
It looks like the front shocks are not connected. If they are working, you might want to get some links and connect them. That will make the ride smoother. you sure have a beautiful coupe. Bill
I should have read the other posts past the first page - like the others said - connecting the shocks will improve the ride.
Last edited by Bill in SoCal; 05-23-2016 at 03:39 PM. Reason: I should have read past the first page
Bill in SoCal is offline   Reply With Quote
Old 05-24-2016, 08:13 AM   #46
31 Model A
31 Model A's Avatar
Originally Posted by KGBnut View Post
Ed,
That's very kind of you to offer. I will send you a PM shortly. I hope I can return the favor some day.
Ken
Ken, your tubing is going out to you today...........it's package and ready to go. Leaving for the Post Office shortly.
Ed
