#41 |
#42 |
Since the original exhaust ports are not used with this conversion Jimmy Stevens pumped cooling water into the original flathead exhaust ports. He also machined iron round stock into valve pockets with integral valve seats for the exhaust ports. He then cut into the sides of these new valve ports from the top of the intake deck. The engine details were written in the Bonneville Racing News. A bunch of forward thinking pretty much the best back yard hot rodding you can find when it comes to modifying a Ford flathead block for all power.
#43 | |
#44 |
Notice I said "max HP". Looks to me that on a stock exhaust, it has to make a 270 degree turn. There has to be a reason for these guys to spend all of the time and effort to put it in. I don't see much "complication in the induction system either.
#45 |
I can believe this helps a blown engine very much. Un blown somewhat.
#46 | |
Now am I saying to ignore the exhaust ports? He'll no! I have never built a Flathead Ford without cleaning out rough edges and sharp turns in the exhaust passages. Even for stock rebuilds. I'm just saying that I think the intake process is the main obstacle to gaining power in a Flathead Ford. In my humble opinion I say until the intake system is improved upon enough to overcome the capability of the exhaust side you don't need radical exhaust modifications. When you supercharge you are essentially "fixing" the intake problem and then at that point the emphasis must shift to the exhaust side. There are photos on the Internet of Flathead Ford blocks with the decks machined away and into the exhaust port passages. Except for the entrance and exit points the ports are smooth and beautifully designed. The center ports in the heat riser area is most concerning to me. In an all out engine I say that heat riser chamber should be filled to a point where it forms a back wall to those center ports with a small and smooth deflector directing the exiting gasses down and out. |
