Old 12-24-2014, 09:30 PM   #41
rob63mess
rob63mess's Avatar
Default Re: Tips For Model A's
Don't get rid of your spare parts...I've given away a ton of parts (and probably will continue to do so) only to find out later that I could use them on the next project that comes along. Trading parts is a great way to keep the cost of restoration down while meeting the guys on the forum.
rob63mess is offline   Reply With Quote
Old 12-24-2014, 11:10 PM   #42
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Talking Re: Tips For Model A's
Originally Posted by fredski View Post
My model a is parked beside ,my 63 corvette should I be worried??
Fredsk
Nah, the corvette is made out of plastic
Old 12-25-2014, 05:58 AM   #43
C26Pinelake
Originally Posted by Tim Armstrong View Post
Old gas is your enemy. Never cook bacon with out a shirt on.
I agree with both!
Wayne
C26Pinelake is offline   Reply With Quote
Old 12-25-2014, 06:43 AM   #44
colin1928
colin1928's Avatar
Buy and read books about your car (do not forget repair manuals )
colin1928 is offline   Reply With Quote
Old 12-25-2014, 09:57 AM   #45
JBill
After timing, don't forget to replace the timing pin correctly.
JBill is offline   Reply With Quote
Old 12-25-2014, 10:54 AM   #46
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by forever4 View Post
Then order a new muffler.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-25-2014, 12:28 PM   #47
caboose
caboose's Avatar
Be very thankful if your mate shares your love of old cars and is willing to crawl under them to help you.
caboose is offline   Reply With Quote
Old 12-25-2014, 02:40 PM   #48
ronn
always sell your A for a few dollars more then you paid........... brag to the wife as to how smart
you are and she will love you for it!
better then being told no, when you go to buy your next A......................
Old 12-25-2014, 02:42 PM   #49
Mitch//pa
keep your issued box of depends under the seat in the storage compartment so nobody see's them
Old 12-25-2014, 04:39 PM   #50
Synchro909
Synchro909's Avatar
Originally Posted by Dan Partain View Post
For those who haven't seen this before - To chase dirty or rusty threads, grind bolts with the same thread and run them into the holes that need cleaning. The sharp leading edge of the threads will do a pretty good job, and not ruin a good tap from grease/dirt combo. Regular hardware bolts work good for this and are cheap to replace when the threads get worn. I try to not use good A bolts if I can help it.
I've been doing this for years. Nowadays, I spend a little time getting the best edge on the treads as I can, then heat the bolt to bright red hot, almost yellow. Then drop it into a METAL container of oil.
This case hardens the bolt so long as it is a reasonable quality one in the first place and not one of those muck metal Chinese ones. You'll get much longer life out of it but makes sharpening it with a file pretty hard on the file (grind only).
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 03-02-2015, 10:49 PM   #51
kevinwalshe
Originally Posted by Marshall57 View Post
Next tip.
When changing out an oil Pan or an engine, you will put a quart down the distributor hole and then use the rest of the five quarts to fill it up.
I know this is old but I am changing my head to a Snyders high compression head and have mine all apart right now. So what you are saying is that after I put the head on, (drained all oil and new pan gasket) to put a QUART of oil down the dizzy hole, then the 4 quarts in the filler spout? Like most of you said:
"read, read, read, ask questions, read some more." So that's the plan!
Thanks,
Kevin
kevinwalshe is offline   Reply With Quote
Old 03-02-2015, 11:11 PM   #52
Bill in SoCal
Bill in SoCal's Avatar
Take lots of pictures with your digital camera. Pictures, the way everything is now - everything. Pictures, when you take things apart. Pictures, when you put it back together. You can't take enough pictures. When your mind gets foggy - you will be so glad you took those pictures. My mind get foggy a lot and pictures have saved me time and time again. Have fun, Bill
Bill in SoCal is offline   Reply With Quote
Old 03-02-2015, 11:32 PM   #53
kevinmac/toledo
Cool Re: Tips For Model A's
Fredsk
my 31 coupe is resting beside my 71 convertable big block
kevinmac/toledo is offline   Reply With Quote
Old 03-03-2015, 12:17 AM   #54
Chuck Sea/Tac
Thanks,
Kevin
This is for when the engine has NO oil period. The quart down the distributor fills the oil galley and dipper trays, to prevent a "dry" start.
Sorry missed the all apart oil pan off.
Old 03-03-2015, 03:27 AM   #55
Charlville
Charlville's Avatar
Locate your local Barner, I'm lucky here in the UK to have Juke Joint Johnny nearby
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 03-03-2015, 06:21 AM   #56
willobs
My best tip, always move spark lever up when turning off engine!
willobs is offline   Reply With Quote
Old 03-03-2015, 09:45 AM   #57
George Miller
George Miller's Avatar
My 1928 Sport coupe is parked next to my 1966 Corvette. They get a long because the Corvette has 40 years seniority.
George Miller is offline   Reply With Quote
Old 03-03-2015, 09:49 AM   #58
mshmodela
mshmodela's Avatar
Think before you dive into a problem, you may make things worse.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 03-03-2015, 11:04 AM   #59
Skeezixx
Skeezixx's Avatar
I always install slide terminals in the headlamp and horn wires. In the event you need to replace the radiator you won't have to discombobulate the headlights and horn.
Crimp them on the wires with about 1 inch between them so you can still fish them through the conduits.
Skeezixx is offline   Reply With Quote
Old 03-03-2015, 12:12 PM   #60
johnbuckley
johnbuckley's Avatar
When visiting the pub try to park facing down hill, or if it's flat reverse into parking bay and make sure you have a clear exit path. That way it makes bump starting easier when after a few drinks you realise you've got a flat battery because you left the lights on.
Oh and fit a battery master switch.
johnbuckley is offline   Reply With Quote
