Old 09-07-2010, 10:05 PM   #41
TechNova
Default Re: Featherfill high build primer
Originally Posted by dlshady View Post
Paint products and techniques have changed a lot since 'back in the day', and a lot of folks have a tough time getting that concept. Gone are the days of filler on bare metal, then lacquer primer, and then "thirty coats of hand rubbed lacquer" on the top.
The point that many here are trying to convey is that each brand and each product has different recommended procedures, and for the best results you need to follow them. For example, one particular PPG epoxy product that we use has a recoat window of something like 48 hours. If you spray your epoxy primer today and then the part sits in the corner of your garage for a few weeks before you get around to working on it, PPG recommends that it be scuffed and re-coated with the epoxy primer before you coat it with high build primer. Most people would say "Awww, just scuff it with some Scotch-Brite and prime it. It'll be fine..." and it might well be, but since PPG recommends against that, how lucky do you feel. Personally I'm not willing to gamble on such things, not when I already have several thousand dollars invested in materials and especially not when its a customer's car.
The old Sherwin Williams Ultra-Fill II was another product that would yield great results when used properly but required you to follow the directions. Aparently it would "skin over" if it sat more than a couple days and the sand scratches would actualy "heal" themselves leaving little for the next layer to bond to. Sherwin Williams recommended that if it sat more than a few days it would need to be re-sanded(or scuffed with Scotch-Brite) before re-coating.
So the thing to learn from all this is that a quality paint job not only required a good metal man, a good body man and a good paint man, but also requires some thought and planning. It ain't rocket science but it does take some atention to detail. Oh, and the old addage still applies in that you get what you pay for. If you buy your paint from Tractor Supply because its cheaper, well then, you know the rest...
Deron
Good post.
There is alot of misinformation in this thread, mainly from people not knowing any better because of believing poor information they have read. People also want to find an easier way and believe that improper methods are OK because they have worked before.
I read postings about K36 being epoxy,thankfully the poster corrected his error. Others not knowing the difference between K36P and K36S or the difference between a primer, a primer surfacer and a primer sealer, even throw the poly primes in there for confusion. Sanding epoxy???? I have done that only a handful of times in my life yet read on many boards about people sanding it as if it's a surfacer. It is very easy for someone to inadvertantly steer someone else wrong.
I am working on some articles explaining primers better, in the meantime Brian Martin (MartinSR) has soem excellant "basics" articles under the tech section of Autobody101.com.
BTW, I am PPG certified and PPG water certified with 25+ years in collison and resto repairs. Doesn't make me an expert, but I have learned how to keep things simple and understandable thru teaching classes for newbies.
TechNova is offline   Reply With Quote
