Old 04-17-2013, 09:25 AM   #1
sconnors
sconnors's Avatar
Default Re: Shocks: Necessity or luxury?
Originally Posted by sconnors View Post
Saw these in the Snyder's catalog, and I need some on the front of my pickup because I only have them on the rear. Are these worth it???
http://www.snydersantiqueauto.com/5684
Just saw in the 2013 Snyder's catalog they have stopped selling these due to "quality issues"
sconnors is offline   Reply With Quote
Old 04-16-2013, 07:16 PM   #2
roccaas
roccaas's Avatar
Henry thought they were a necessity!
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 04-17-2013, 08:58 AM   #3
Elcastor
Elcastor's Avatar
Stay away from having M&S rebuilding your originals. I had nothing but leaking shocks after having mine done there. I even took some of them back to be redone, and they still leaked. No problems with Rob Paul rebuilds.
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 04-17-2013, 10:33 AM   #4
gwhite
gwhite's Avatar
What should I look for when trying to find 'rebuildable' shocks?
gwhite is offline   Reply With Quote
Old 04-17-2013, 10:41 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Remove the fill plug and if powdered rust falls out, it's only good for a paper weight.
Also if the square shaft too much side clearance they are too worn for use.
Old 04-17-2013, 04:33 PM   #6
sconnors
sconnors's Avatar
I have rear shocks on mine now. Do they need to be oiled or have some kind of fluid in them? I'm new to this so excuse me if that's a stupid question.
Old 04-17-2013, 06:22 PM   #7
Tom Wesenberg
It depends on the shocks, as some aren't refillable. If you have the original shocks or Bill Sipes, then they are refillable, and should be checked once in a while.
Old 04-17-2013, 11:16 PM   #8
Kahuna
Kahuna's Avatar
On my 32 B, I used MGB rear shocks, and added the ball to the lever. They are excellent shocks, rebuildable, and affordable... Plus, the mounting holes line up perfectly on a 32.
Maybe something to consider for a Model A
Kahuna is offline   Reply With Quote
Old 04-18-2013, 08:06 AM   #9
Hudsn47
I'm helping a guy with his model 1929 Model A Tudor Sedan. He currently doesnt have shocks on the car. He has the shocks but they need rebuilt. Is it better to have the shocks on the car even if they need rebuilt than to have no shocks on at all? Thanks.
Hudsn47 is offline   Reply With Quote
Old 04-18-2013, 09:42 AM   #10
al's28/33
al's28/33's Avatar
YES put them on, it's a safety issue. Henry said so back in '27.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 04-18-2013, 10:23 AM   #11
sidhartha
sidhartha's Avatar
I've been looking at the shock issue for a long time. I bought my 31 Tudor without shocks. Not realizing their importance. Truth is I just assumed they were an option of the day. (I have learned so much by browsing this forum) I would like to put originals on mine but I'm on a budget and just don't think I can swing $8-1,200.00 for a complete set. I would love to have a set made by Bill but I just can't spend that much. What I've found so far is a number of kits that either require you to drill a hole in the front axle or rear cross member. Snyder's has a kit that clamps on the front axle but drills the rear cross member. Pete and Jakes has a kit that mounts the rear using the rear bumper mount holes and drills the axle. Has anyone encountered problems with these? Although I have no problem using some modern technologies on my 31 Tudor, I do have problems drilling holes in it. I though about Kahuna's idea with MGB shocks but have questions on them. MGB's are lighter than an A. Would they be sturdy enough? Cost for 4 rebuilt ones would be around $400.00 plus fabrication for the ball. In researching this style I've found that they sell conversion kits for them as well. So I'm assuming that MGB owners are having troubles with them as well. At this point I'm looking at the kit from Snyder's and perhaps fabricating a rear mount like Pete & Jakes.
sidhartha is offline   Reply With Quote
Old 04-18-2013, 10:58 AM   #12
Pat Martone
Pat Martone's Avatar
I do not have first hand experience, because my car came to me with existing, original-type but functioning Houdaille shocks, but I have heard good things about the Ken Davis shocks kit (http://www.kendavismodela.com) designed specifically for Model A use, and they cost about $250 for a set of 4. Ken Davis shocks are tube-type and not "correct" for judging, but fine if your car is a driver. If money is not object, I recommend the correct and quality made Bill Stipe "Houdaille" shocks; they are reknowned to be the best, correct, fully-adjustable, refillable, and beautifully machined.
Pat Martone is offline   Reply With Quote
Old 04-18-2013, 06:13 PM   #13
sconnors
sconnors's Avatar
Well I broke down and ordered two front shocks from Bill Stipe today! Can't wait to get them on!!!
Old 04-18-2013, 07:48 PM   #14
Banky
What about new friction shocks? Any experience with these? No one mentioned them, so I fear I'm going to get lit up for even suggesting them. So let's just say I'm posting this question for a friend
Banky is offline   Reply With Quote
Old 04-18-2013, 07:56 PM   #15
Mitch//pa
tell your friend a lot of guys run them
Old 04-19-2013, 08:30 AM   #16
fritznbud
fritznbud's Avatar
I must say that i too, thought shocks were an option since my Huckster has none. And it handles just fine without them. No bouncing out of control, chuck hole tossing front end action like i'm reading here. No flex at all, turns just fine, stops as expected. The rear takes bumps very hard but the only damage i get is in my backside. You guys really had me going last night as i researched these horror stories. MAFCA member has gone 110K miles and ten years driving without shocks.
fritznbud is offline   Reply With Quote
Old 04-19-2013, 08:48 AM   #17
jkeesey
jkeesey's Avatar
fritz, driving without shocks is also one of the leading factors in the illusive cracked front crssmember.
jkeesey is offline   Reply With Quote
Old 04-19-2013, 09:12 AM   #18
sidhartha
sidhartha's Avatar
My Tudor handles fine with no shocks. I just feel better about having some on it. I think I'm going to go with the Ken Davis shocks. They seem to be cost effective and have good revues. Still not crazy about drilling holes in the car. As much as I would like to have some from Bill Stipe, I just can't spend that much.
Old 04-19-2013, 09:51 AM   #19
CarlG
CarlG's Avatar
Ken Davis shocks are great. Don't require any drilling for the rears, and on the fronts if you don't want to drill the one hole (each side), one friend just welded the bracket on, another made a clamp. I just opted to drill the hole.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-19-2013, 10:15 AM   #20
sidhartha
sidhartha's Avatar
Drilling a hole in the axle has been a concern. Mostly that it will weaken it. The bolt on mounts on the rear is a definate selling point for me. I want to be able to make all original in the future if I choose.
