Old 04-30-2026, 08:42 PM   #561
The Art Doctor
The Art Doctor's Avatar
Default Re: What did you do today that was flathead V8 related?
Saw some green drips on the garage floor. Then found that I was down about two inches of coolant. Replaced a leaky engine block petcock. Cleaned up the mess on the underside. Neither Home Desperate nor Lowest Lowes had one, but ACE Hardware to the rescue!
File Type: jpg e77c4a60-c0fd-4900-8a88-a77d753687cb.jpg (107.4 KB, 188 views)
The Art Doctor is offline   Reply With Quote
Old 04-30-2026, 08:52 PM   #562
petehoovie
petehoovie's Avatar
Old 05-01-2026, 11:18 AM   #563
flatford8
flatford8's Avatar
Put the frame back under my ‘51 Tudor…..I may do a half a$$ed build thread if I can remember to take more pictures ….Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
flatford8 is online now   Reply With Quote
Old 05-01-2026, 11:31 AM   #564
petehoovie
petehoovie's Avatar
Old 05-02-2026, 08:18 PM   #565
SoCalCoupe
SoCalCoupe's Avatar
Had to be towed home about 6 weeks ago when the Columbia on my '41 Ford Special Business Coupe failed to shift. Wouldn't go into high, wouldn't go back into low. Car no go. Parked it in the driveway and didn't look at it for a month. Looked at it last weekend and found that the bolts were loose on the vacuum valve assembly. The actuator never acutated because it was so out of alignment. Tightened the bolts and realigned it last weekend. Got it back in gear so it would drive. Too beat to test shifting. Today (this weekend) I took it for a test drive and shifted it twice back and forth from low to high. Everything perfect. Glad to have my car back!
SoCalCoupe is offline   Reply With Quote
Old 05-02-2026, 09:49 PM   #566
Newc
Newc's Avatar
V8er drug home a '34 bb chassis- took photos. any good parts? has a 37/38 21 stud engine and a non-script bed. in Oregon Corvallis area. Newc
Old 05-02-2026, 10:31 PM   #567
petehoovie
petehoovie's Avatar
Old 05-06-2026, 06:24 PM   #568
bobsmanstuff
bobsmanstuff's Avatar
A few days ago replaced the battery with a new one. next day the new battery was dead. decided to replace the regulator. I have negative ground so polorized it. Ran rough I had a spare rebuilt generator put that on and replaced belts as long as I was in there. ran rough and flooded. Left it to the next day wouldn't start. Put a different coil and condenser readjusted the carburator , turned the key it popped right off. Happy day.
bobsmanstuff is offline   Reply With Quote
Old 05-07-2026, 10:41 AM   #569
Als48
Originally Posted by slowforty View Post
After getting sticker shock on Rebuilders and Decent Flathead engines for sale. I am putting the 40 Ford Tudor Deluxe up For Sale even though it needs an engine.
Lets see what happens after 36 years of happy motoring.
Hi, Slowforty,
Do you still have your '40 Sedan? Is it for sale? I'm thinking I heard that you had sold it. I am interested if still for sale.
Al Hook
Als48 is offline   Reply With Quote
Old 05-07-2026, 12:55 PM   #570
RalphM
RalphM's Avatar
Body work on the front clip of the 47 coupe. It’s starting to look better.
RalphM is offline   Reply With Quote
Old 05-07-2026, 01:55 PM   #571
petehoovie
petehoovie's Avatar
Old 05-08-2026, 08:01 AM   #572
Kens 36
Kens 36's Avatar
Originally Posted by Als48 View Post
Hi, Slowforty,
Al Hook
Al,
He sold that car last fall.
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 05-27-2026, 11:50 PM   #573
Brian
Brian's Avatar
Today i stripped a C69A that I built up for a friend a number of years ago.We went to a swap meet last Sunday, I followed his 39 Merc in my little 35. I noticed his car smoking a little bit from time to time, but following him down a mountain pass , every time he put his foot on the throttle, man, the smoke was horrendous!! I thought he'd blown some rings. Pulled the engine on Monday, finally got it stripped today. Transpires, gudgeon pin circlips on both rear cylinders had broken, both rear cylinders need to be resleeved, new pistons required, full floaters on that journal hammered out; no bearing material left.... 239 engine bored .125" over. It'll need bits....
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old Today, 11:04 AM   #574
ndnchf
ndnchf's Avatar
Out for a test drive after working on the carb. Just had to stop and see if it was true what they say about their hot dogs :-)
Restored Ford 6 & 12 volt generators
ndnchf is offline   Reply With Quote
Old Today, 11:27 AM   #575
petehoovie
petehoovie's Avatar
Old Today, 12:31 PM   #576
flatford8
flatford8's Avatar
And???…….dont keep us in suspense Steve!………..Mark
Old Today, 02:03 PM   #577
ndnchf
ndnchf's Avatar
World's best? That would be a stretch. But they were good. Nathan's all beef on a steamed bun with mustard, onions and relish. Pretty darn tasty!
Old Today, 07:32 PM   #578
hueyhoolihan
i spent some unproductive time on two things.
1) i'm getting popping (unburnt fuel igniting somewhere between the heads and the muffler) in the exhaust. i can actually faintly feel it with my hand at the exhuast tip when it pops. i suspect it's in the crossover pipe but i can't see it. but no matter...i've order a brand new exhaust system and when installed i can eliminate the exhaust system as the cause if it persists.
2) the aftermarket turn signals on my '41 are flakey. i'm trying to convert to LEDs but it's been a struggle. i think i made some progress today in that it was intermittant and now i've got them to the point they don't work at all. you may think that this is a step back, but it will be easier to diagnose the problem now that i have some consistency!
hueyhoolihan is offline   Reply With Quote
