Old 11-13-2020, 01:47 AM   #461
V8COOPMAN
V8COOPMAN's Avatar
Default Re: photo1-1-window
T5 S-10
Click Links Below __
T5 W/TORQUE TUBE
Old 11-14-2020, 02:46 PM   #462
V8COOPMAN
V8COOPMAN's Avatar
COIL VOLTAGE/OHMAGE:
____________________________________________
_______________________________________________
__________________________________________________
What is often called a 6v coil will work fine on 12v, positive or negative ground. As you posted, it is the current in the circuit that needs to be controlled in the 3 to 4 amp range. With a "6v" (really one in the 1.5 ohm range) you need a ballast resistor (also in the 1.5 ohm range) for use with 12v. So, you are looking for ~3.0 ohms of resistance for a 12v ignition circuit. Or, you can use what is referred to as a 12v coil, really a 3.0 ohm resistance coil, as it provides the 3.0 ohms of resistance without a ballast resistor. The polarity of the coil needs to match the polarity of the rest of the system, so a negative ground system has the negative terminal of the coil going to the distributor points & capacitor and the positive terminal of the coil connected to the ignition switch.
T5 W/TORQUE TUBE
Old 11-15-2020, 02:03 PM   #463
V8COOPMAN
V8COOPMAN's Avatar
Test
T5 W/TORQUE TUBE
Old 11-18-2020, 12:33 PM   #464
V8COOPMAN
V8COOPMAN's Avatar
RHD (RIGHT HAND DRIVE) AUSSIE
T5 W/TORQUE TUBE
Old 12-02-2020, 01:26 AM   #465
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by v8coopman View Post
charlie ny and contact info
charles schwendler
5845 cole rd.
Orchard park n.y.
14127
Cell: 716-440-8952
Cell #: 716-440-8952
T5 W/TORQUE TUBE
Old 12-03-2020, 11:54 AM   #466
V8COOPMAN
V8COOPMAN's Avatar
ENGINE STAND
T5 W/TORQUE TUBE
Old 12-05-2020, 02:16 PM   #467
V8COOPMAN
V8COOPMAN's Avatar
Solenoid
T5 W/TORQUE TUBE
Old 12-06-2020, 01:32 AM   #468
V8COOPMAN
V8COOPMAN's Avatar
BROKEN BELL
T5 W/TORQUE TUBE
Old 12-06-2020, 01:35 AM   #469
V8COOPMAN
V8COOPMAN's Avatar
'40 TRANS
T5 W/TORQUE TUBE
Old 12-13-2020, 03:48 AM   #470
V8COOPMAN
V8COOPMAN's Avatar
Lights
T5 W/TORQUE TUBE
Old 12-17-2020, 01:55 PM   #471
V8COOPMAN
V8COOPMAN's Avatar
4-CYL BELLHSNG
T5 W/TORQUE TUBE
Old 12-22-2020, 03:55 PM   #472
V8COOPMAN
V8COOPMAN's Avatar
GRUB SCREW
T5 W/TORQUE TUBE
Old 12-23-2020, 03:58 AM   #473
V8COOPMAN
V8COOPMAN's Avatar
One thing you learn from history....is that nobody learns from history!
T5 W/TORQUE TUBE
Old 12-23-2020, 04:47 PM   #474
V8COOPMAN
V8COOPMAN's Avatar
BANJO DRAIN HOLE
T5 W/TORQUE TUBE
Old 12-23-2020, 05:06 PM   #475
V8COOPMAN
V8COOPMAN's Avatar
TRUCK OPEN BANJO
T5 W/TORQUE TUBE
Old 12-29-2020, 01:37 PM   #476
V8COOPMAN
V8COOPMAN's Avatar
'32-'34 Banjo
T5 W/TORQUE TUBE
Old 12-29-2020, 01:39 PM   #477
V8COOPMAN
V8COOPMAN's Avatar
SHOCK Mounts
T5 W/TORQUE TUBE
Old 12-31-2020, 02:28 PM   #478
V8COOPMAN
V8COOPMAN's Avatar
Pan
T5 W/TORQUE TUBE
Old 01-01-2021, 06:22 AM   #479
V8COOPMAN
V8COOPMAN's Avatar
Fan Thread....CLICK
https://www.fordbarn.com/forum/showp...9&postcount=12
T5 W/TORQUE TUBE
Old 01-02-2021, 02:49 AM   #480
V8COOPMAN
V8COOPMAN's Avatar
49-50 Merc Pics
T5 W/TORQUE TUBE
